Thread started 29 Aug 2012 (Wednesday) 09:02
Eyeglasses - on or off?
KirkS518
Joined Apr 2012
Aug 29, 2012 09:02 |  #1
I have glasses. I don't wear them, ever. I have adjust the dioptic adjustment to where it looks the sharpest to me, but I really just rely on the AF to be correct. The problem is when I'm manually focusing. Should I be wearing my glasses? If I wear the glasses, then the adjustment I made to the viewfinder makes it difficult to see.
What do you guys that wear glasses do? Wear them, or not?
If steroids are illegal for athletes, should PS be illegal for models?
Digital - 50D, 20D IR Conv, 9 Lenses from 8mm to 300mm
Analog - Mamiya RB67 Pro-SD, Canon A-1, Nikon F4S, YashicaMat 124G, Rollei 35S, QL17 GIII, Zeiss Ikon Ikoflex 1st Version, and and entire room full of lenses and other stuff
jmark252
Aug 29, 2012 09:45 |  #2
I've always worn mine. Just easier for me.Can't see without them as I am very farsighted.
rick_reno
Aug 29, 2012 10:23 |  #3
i leave mine on
recrisp
Gallery: 196 photos
Aug 29, 2012 11:17 as a reply to  @ rick_reno's post |  #4
I don't know if I fully understand the question you ask, but...
I wear glasses when I drive and watch T.V., (not at the same time! heheh) but when I am doing any photography, I wear ONE contact, not two. The reason I do that is, I can see close up with my right eye, so I have the Diopter set for that. I use the contact in my left eye, that way I can still see what I need to, when I need to. It's pretty weird at first adapting to that, especially driving, it's not dangerous, (at least for me) so I am fine with it.
Both eyes are the same visually, if that helps. I never, ever wear TWO contacts, not ever...
Also, I can't watch T.V. or look at my monitor with only ONE contact, it drives me crazy. :)
Randy
Joe ­ Ravenstein
Aug 29, 2012 11:26 |  #5
I wear my glasses everywhere but in the water or in bed. If I lost my glasses I'd be driving by braille.
Canon 60D,18-55mm,55-250mm,50mm compact macro, AF ext tubes. Sigma 8-16mm uwa, 18-250mm, 85mm F1.4, 150-500mm
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Aug 29, 2012 18:39 |  #6
I wear glasses and wear them when I shoot. If you need glasses wear them - Adjust the viewfinder to work with your glasses, problem solved.
Dan Marchant
Paolo.Leviste
Aug 29, 2012 19:37 |  #7
Joe Ravenstein wrote in post #14922149 (external link)
bw!
And, same here. I have gotten used to it, and just tend to wipe my glasses down with my shirt hem if things get smudgy. Besides which, I might miss the shot if I have to pop my glasses off/up and then get my camera.
...Actually, with how bad my vision is, I'd have to get my camera THEN pop my glasses off/up.
[Canon 5DII/30D | 24-70 f2.8L | Σ 30 f1.4 | Σ 50 f1.4 | 70-200 f4L | 580EX II ]
3.Hundred.6.SIX (external link)
SmugMug (external link)
RDKirk
Adorama says I'm "packed."
Joined May 2004
Aug 29, 2012 19:44 |  #8
Dan Marchant wrote in post #14923688 (external link)
Indeed.
sweetpea44
Joined Jul 2011
Aug 29, 2012 20:21 |  #9
Yep .... agreed.
My Blog (external link) My Flickr (external link)
T3i // Canon 10-22mm f3.5-4.5 USM // Tamron 17-50mm f2.8 non VC // Canon 55-250mm f/4-5.6 IS // Canon 50mm f/1.8 II // Canon 40mm f2.8 STM // 430ex :cool:
mike_d
Aug 29, 2012 22:34 |  #10
Contacts are my first choice. Wearing glasses makes it harder to get my eye close enough to the viewfinder to see the corners well. If the diopter adjustment in the viewfinder could correct for my near-sightedness, I'd do that and skip the glasses. But since it can't I have to wear glasses.
stsva
Gallery: 45 photos
Aug 30, 2012 12:32 |  #11
I wear glasses full time - I use a Hoodman glasses model eyecup on the camera.
Some Canon stuff and a little bit of Yongnuo.
Member of the GIYF
Club and
HAMSTTR
٩ Breeders Club https://photography-on-the.net …=744235&highlig​ht=hamsttr Join today!
Image Editing OK
RDKirk
Joined May 2004
Aug 30, 2012 12:55 |  #12
mike_d wrote in post #14924634 (external link)
I used to wear contacts--all the way back to the 70s, when they were hard plastic.
That created a special problem for me, because they could not be worn for more than 8 hours because they cut off oxygen to your corneas...and left your corneas slightly swollen for hours after that. The problem was that after a long shooting day, I'd have to remove the contacts and then go into the darkroom to print the day's take. Shucks! Swollen corneas meant my vision in spectacles wasn't as sharp as it should have been for printing. So I often wore spectacles when I knew I was headed for a long day.
But I wore soft contacts until I began to need bifocals about ten years ago. I went through a variety of different bifocal contact types until I finally realized that bifocal contacts are not for people who want to see well, they're for people who want to look good. So now I'm wearing spectacles.
JohnThomas
Joined May 2012
Aug 30, 2012 13:33 |  #13
I can't see at all without my glasses or contacts - my vision is close to 20/500 uncorrected. I prefer my glasses, but when I shoot I need to wear my contacts. Using a camera with glasses is way too annoying (for me, anyway).
You can call me JT
jsantiniphotography.co​m
dodgyexposure
Gallery: 14 photos
Joined Jul 2012
Aug 30, 2012 17:28 |  #14
I'm lazy. I leave my glasses on all the time, even though I don't need them for closeup. The thought of taking them off when I go out smacks of planning and forethought (bah! who needs it?) and I'd go nuts if I tried to put them on and off every time I put the camera to my eye.
Cheers, Damien
RachelLyndsey
Joined Aug 2012
Aug 30, 2012 17:31 |  #15
I find my glasses to be uncomfortable when I'm shooting for a long time, so I usually wear contacts just for those days when I will be.
Have: 5d Mark II / 24-85mm / 50mm 1.4
Want: 17-40mm L / 35mm L / 85mm L / 135mm L
Facebook (external link) Website (external link)
4,073 views & 0 likes for this thread, 27 members have posted to it.
1801 guests, 121 members online
