Thread started 29 Aug 2012 (Wednesday) 10:08
Question about "recovering" smart objects
RandMan
Joined Mar 2012
Aug 29, 2012 10:08 |  #1
Hello,
I'm still trying to get accustomed to what exactly smart objects can and cannot do. What I absolutely love about them is the ability to double click and go back into RAW and import those adjustments back into Photoshop while keeping all layers and adjustment intact--truly phenomenal.
When you are forced to rasterize the smart object in order to do certain adjustments that they do not accomodate, can you rasterize the smart object, then do your adjustments, then convert it back into a smart object, and still be able to go back into RAW as mentioned above?
What if you open a file into Photoshop as a standard "Background" layer (not smart object) and then add a bunch of layers and adjustments; can you at that point convert to a smart object and get back into RAW from it?
And lastly, and most importantly for me, is there any way to create Actions with a smart object as your base image? Or do all actions need to be based off of rasterized "Background" layers?
Please help! So confused,
Randy
Canon eos7D | Canon 50mm 1.4 | Canon 17-55mm 2.8 | Sigma 70-200mm 2.8 | Yongnuo 565ex | Yongnuo yn-468 II | Canon ef28-135mm 3.5/5.6 | Canon ef-s 55-250mm 4.0/5.6
René ­ Damkot
Aug 30, 2012 06:34 |  #2
RandMan wrote in post #14921784 (external link)
No.
What adjustments are you referring to? And what version PS?
There might be other workarounds…
No. You then get a SO that contains all those (adjustment)layers. If you double click on it, PS will open the SO as a .psb document that contains all those (adjustment)layers.
Sure, why not? Depends on what you want the action to do I'd say.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
René ­ Damkot
Aug 30, 2012 06:58 |  #3
Some links about SO's:
http://www.creativepro​.com …smart-about-smart-objects (external link)
http://xeler8r.com …scs2/s_objects/​index.html (external link)
http://simplephotoshop​.com …smart-object-via-copy.htm (external link)
http://www.graphics.co​m …&op=viewarticle​&artid=739 (external link)
tonylong
...winded
Gallery: 60 photos
Aug 30, 2012 14:56 |  #4
A note here:
Smart Objects can work with Adjustment Layers and Smart Filters and so keep their Raw data intact -- in other words you can open the Raw in PS as a Smart Object and add an Adjustment Layer and/or a Smart Filter, tweak those, then double-clck the Smart Object icon and Camera Raw will open with the Raw data, with the original Raw adjustments intact. That's the power of the non-destructive editing with Smart Objects.
But if you change the Smart Object to a "regular" image format and do adjustments directly to it, then, well, once you apply those adjustments then you are no longer able to go back to processing the Raw data (unless you Undo without saving the new file/image or go back in the History).
Tony
jack880
Gallery: 13 photos
Joined Apr 2011
Aug 30, 2012 16:09 |  #5
One thing I find really frustrating is I haven't found a way to apply smart filters to a cropped smart object - if you crop it, then go to "lens correction" and add a vignette it only applies the vignette to the edges of the uncropped object.
https://www.flickr.com​/photos/jackhenriques/ (external link)
1DX, 7D, 20D, G7X II, 70-200 f/2.8 L IS II, 24-70 f/2.8 L, 16-35 f/2.8 L II, 50 f/1.8 II, 50 f/1.4, TS-E 17 f/4 L, 8-15 f/4 L, Sigma 17-50 f/2.8, Sigma 8-16 f/4.5-5.6, Sigma 150 f/2.8 macro, x1.4 extender II, Kenko extension tubes, 430 EX II x 2, DJI Mavic Air
tonylong
...winded
Gallery: 60 photos
Aug 31, 2012 00:42 |  #6
jack880 wrote in post #14927697 (external link)
OK, I don't have CS6, Lightroom 4 lets you apply vignetting after cropping and I assume the same applies to Camera Raw...?
As to cropping a Smart Object in the Photoshop editor and then applying vignetting, don't know, haven't played with it!
Tony
RandMan
Joined Mar 2012
Aug 31, 2012 07:37 |  #7
René Damkot wrote in post #14925557 (external link)
No.
As far as adjustments go, I can't name exact ones off the top of my head, but it's those certain tools and functions that can only work on rasterized layers--they kind of hit me surprise when I go to use them and realize I can't (from what I've read about SO's I'm guessing it's anything that affects actual pixels). I'm using Photoshop CS5.
As for the Actions: Let's say I have a SO open in Photoshop. For example--I'll hit record for a new action, then maybe add a channel mixer adjustment layer for a b&w conversion, then clip a Curves adjustment layer above that, then duplicate the base image (the Smart Object) and do a High Pass/Overlay blend mode for sharpening. Then I'll hit stop.
If I play the action back on a different image, I get a series of error dialogues interuppting the action and saying that certain layers and images cannot be found.
René ­ Damkot
Aug 31, 2012 08:04 |  #8
Actions record Layer names when you click a layer. So if you Click "Layer 1 copy", the action will only play back on an image that contains a "Layer 1 copy".
To avoid that, use shortcuts Alt[and Alt] for "previous" and "next" layer, or Alt, and Alt. for "bottom" or "top" layer.
I think it should work then.
If you must use a filter that won't work on a SO, then do a Shift Cmd Opt E (merge all layers into a new layer), then run the filter.
RandMan
Joined Mar 2012
Aug 31, 2012 12:34 |  #9
René Damkot wrote in post #14930307 (external link)
Aaahh, ok. Now I understand the first part about the layer names, and the last part about merging into a new layer, but can you elaborate on the "Alt" part in the middle? I understand what you're getting at and the reason behind it, but it's not a command or shortcut that I've used. Does it mean holding down Alt while clicking on a layer? That's the only confusing part to me.
Thank you for the help!
René ­ Damkot
Sep 01, 2012 07:03 |  #10
No mouse involved: Press Alt and the key, so Alt+[, Alt+] (square brackets), Alt+, (comma) or Alt+. (period)
Side note: Cmd+] and Cmd+[will move a layer up or down, Cmd+Shift+] or [will move a layer top to or bottom.
RandMan
Joined Mar 2012
Sep 04, 2012 08:47 |  #11
René Damkot wrote in post #14934293 (external link)
Oh, I see--I'd never heard of those shortcuts. So just to make sure I'm clear:
Alt [Move down one layer (to select it)
Alt] Move up one layer (to select it)
Alt , Jump to bottom layer (to select it)
Alt . Jump to top layer (to select it)
Cmd [Switch currently selected layer with the one directly above
Cmd] Switch currently selected layer with the one directly below
Cmd Shift [Move currently selected layer to top of layer stack
Cmd Shift] Move currently selected layer to bottom of layer stack
Yeah?
René ­ Damkot
Sep 04, 2012 09:53 |  #12
Yep.
D ­ Thompson
Sep 11, 2012 13:13 as a reply to  @ René Damkot's post |  #13
Just saw this from Dr Russell Brown and it looks interesting. Click Dr Brown's Scripts (external link) then go down to the Edit Layers in ACR 1.1.6 panel.
Dennis
Canon 5D Mk III 5D 20D
I have not yet begun to procrastinate!
RandMan
Joined Mar 2012
Sep 12, 2012 11:38 |  #14
René Damkot wrote in post #14946142 (external link)
Yep.
So I created an action this morning to set up an edge mask for sharpening. Copied image into a new channel, ran the find edges filter, blur, levels etc. Within the action I utilized the "Alt ." keystroke to select the top layer in the stack before creating a new layer that would be a merged copy of everything below it.
When I ran the action on a different image to test it, the action interrupted at that stage with an error box that said that the top layer was not found. I clicked continue and the action finished out, but it did not do anything at all.
Can you diagnose the diagnosis?
René ­ Damkot
Sep 13, 2012 14:47 |  #15
I guess the "copy to a channel" doesn't work (or works differently?) with a SO.
Try using "Apply image", or add a step: ShiftOptCmdE (ShiftAltCtrlE) to merge everything to a new layer (name it!) and delete that merged layer after you've used it to do what you want to do.
See this thread: https://photography-on-the.net …97&highlight=re​ally+smart
2,986 views & 0 likes for this thread, 5 members have posted to it.
1061 guests, 103 members online
