Thread started 31 Aug 2012 (Friday) 07:54
Selective Sharpening
RandMan
Joined Mar 2012
Aug 31, 2012 07:54 |  #1
Good Morning,
I've read here and there about the concept of sharpening (or applying noise reduction on the contrary) to an image but excluding it from certain areas. It makes a lot of sense to me and is something I would like to incorporate into my workflow--sharpening an image everywhere except for the shadows and highlights so that those areas do not accentuate noise and get grainy.
Is there an easy method to doing this without sharpening the entire image with a mask and then painting in (or out) areas of sharpening? Like some sort of one-click-trick to basically apply your sharpening only to midtones?
-Randy
Canon eos7D | Canon 50mm 1.4 | Canon 17-55mm 2.8 | Sigma 70-200mm 2.8 | Yongnuo 565ex | Yongnuo yn-468 II | Canon ef28-135mm 3.5/5.6 | Canon ef-s 55-250mm 4.0/5.6
stsva
Gallery: 45 photos
Aug 31, 2012 09:55 |  #2
You could try this:
https://photography-on-the.net …/showthread.php​?t=1099897
Some Canon stuff and a little bit of Yongnuo.
Member of the GIYF
Club and
HAMSTTR
٩ Breeders Club https://photography-on-the.net …=744235&highlig​ht=hamsttr Join today!
Image Editing OK
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Aug 31, 2012 10:30 |  #3
That's an excellent Tut! For simpler images, a feathered selection works fairly well, too: Selection for sharpening illustration.
Unregistered.Coward
Aug 31, 2012 10:57 |  #4
You wanna make it real easy, look at Nik Dfine / Sharpener.
....the best camera is the one you have on you at the time.
pknight
Gallery: 39 photos
Joined Feb 2006
Aug 31, 2012 12:53 as a reply to  @ Unregistered.Coward's post |  #5
Much (all?) of what the above tutorial does can be done with the sharpening mask in LR. I assume that ACR has the same capability, although I have not used ACR nor Bridge since adopting LR.
Digital EOS 90D Canon: EF 50mm f/1.8 II, EF 50mm f/2.5 Compact Macro, Life-Size Converter EF Tamron: SP 17-50mm f/2.8 DiII, 18-400mm f/3.5-6.3 DiII VC HLD, SP 150-600 f/5-6.3 Di VC USD G2, SP 70-200 f/2.8 Di VC USD, 10-24mm f/3.5-4.5 DiII VC HLD Sigma: 30mm f/1.4 DC Art Rokinon: 8mm f/3.5 AS IF UMC
RandMan
Joined Mar 2012
Aug 31, 2012 14:25 |  #6
pknight wrote in post #14931479 (external link)
I do use the sharpening mask regularly in ACR, but my native image always goes into Photoshop next for further adjustments. I'm referring to a method in Photoshop itself (I use cs5) for final output sharpening. Also, the sharpening in ACR is limited to edge detail and doesn't allow luminosity masking.
macroimage
Sep 01, 2012 00:57 |  #7
A quick method that works well for many images is to sharpen the whole picture, then use the history brush to quickly remove the effect wherever it isn't desired.
Photo Gear
tonylong
...winded
Gallery: 60 photos
Sep 02, 2012 03:23 |  #8
For those promoting Photoshop and Nic sharpening, maybe a Before/After, especially after using ACR/LR to get a Before, and maybe providing us with a Raw file to compare???
Tony
Lowner
"I'm the original idiot"
Sep 02, 2012 03:54 |  #9
I still use the old way, sharpening a seperate layer and simply erase it away where its not wanted. I'm a simple soul and it suits the way I think!
Richard
proximustherogue
Joined May 2011
Sep 02, 2012 05:16 |  #10
I tried this and it seems to do what you are asking but its not one click. you could make an action to do it for you though.
duplicate layer ( CTRL +J)
filter -> Sharpen -> unsharp mask ( 300/3.0/0 ) I always exaggerate for testing purposes. you should use whatever you feel is necessary.
right click layer 1, blending options
last block on the bottom: blend if Grey.
Change the underlying layer to something that works for your image
80 -90 seemed to get me out of the shadows (left slider)
133 or so seemed to get me away from the highlights ( right slider)
you can split the sliders apart to smooth the transition out a bit. I used about 20 or 30 on either side. alt click on the slider to split them up.
hopefully that gets you close to what you are trying to do.
get out and shoot
RandMan
Joined Mar 2012
Sep 04, 2012 08:24 |  #11
proximustherogue wrote in post #14937215 (external link)
Yup, I just read about this one over the weekend and I'm going to start trying it out. The only thing I'll do different is change that sharpening to "Luminosity" blending mode so that it only affects the luminance tones and not the color.
And yes, once it's an Action it's one click--love it!
Lowner
Sep 04, 2012 09:32 |  #12
I see sharpening as very dependant on the particular image. I certainly don't think "one size fits all" which is what an action would surely do?
Richard
proximustherogue
Joined May 2011
Sep 04, 2012 10:20 |  #13
Lowner wrote in post #14946066 (external link)
I agree but when i make an action I dont just make it one setting and forget about it, rather I use it as a guage with a base setting and then sub actions with different settings that can be changed at the click of a button. since I use my actions in button mode.
Action-> Create sharpening layer.
Action sub setting -> Select sharp layer and change settings to X
Action sub setting -> Select sharp layer and change settings to Y
Action sub setting -> Select sharp layer and change settings to Z
where X-Y or Z could be different settings in the blending mode or opacity or even changing a mask on a layer. maybe it wont get you exactly what you need but it can give you a better start point faster I feel.
I'm just learning to use actions like this but its making my life alot easier doing it this way.
EDIT: I will make an action set later so you can see what I mean.
get out and shoot
RandMan
Joined Mar 2012
Sep 04, 2012 11:20 |  #14
Correct, but with one click it can merge all visible layers, change the new layer to Luminosity Blending Mode, Run an Unsharp Mask, and go to the "Blend If" parameters and set them to avoid sharpening the shadows and highlights. And then you can start tweaking for the particular image without going through all the rudamentary motions at first.
Bsmooth
Sep 04, 2012 11:31 as a reply to  @ RandMan's post |  #15
You ca also do it in Lab mode as well, highlighting and sharpeming only the lightness. Then apply it to only areas you would like to, similar to using the luminosity blend mode.
Bruce
3,542 views & 0 likes for this thread, 11 members have posted to it.
1061 guests, 103 members online
