Thread started 01 Sep 2012 (Saturday) 10:03
Good exemples of the DoF difference between FF and crop.
Earwax69
Joined Jul 2012
Sep 01, 2012 10:03 |  #1
Here a test made on Nikon that show the DoF difference between equivalent situations (50mm on crop, 85mm on FF, 85 on crop, 135 on ff)
http://tonycorrea.com …portrait-lens-comparison/ (external link)
Have fun!
Canon 6D | S35mm f1.4 | 135mm f2 The rest: T3i, 20D, 15mm f2.8, 15-85mm, 24mm f2.8, 50mm f1.8, 85mm f1.8, 90mm f2.8 macro, 55-250mm.
So long and thanks for all the fish
chris_holtmeier
Joined Sep 2011
Sep 01, 2012 10:28 |  #2
I knew there was a difference, but that's more than I was expecting.
https://www.facebook.c​om/FotonFoto (external link)
Earwax69
Joined Jul 2012
Sep 01, 2012 10:34 |  #3
kinda double...:(
However if you prefer wide DoF and more reach, crop is all good.
I wanted to get a 135L for my t3i but now I am quite hesitating. Not sure it is worth it if I cannot mimic the narrow DoF I see everywhere on this forum. Might be better to keep that money for a 5D mark II down the line...
chris_holtmeier
Joined Sep 2011
Sep 01, 2012 10:43 |  #4
I took my 135L out on my T3i right before I sold it. It was ok, but nothing compared to that lens on a 5D or 5DII.
SoCalTiger
Joined Jul 2012
Sep 01, 2012 10:49 |  #5
Wow... that is a big difference. Apparently I need to upgrade...
Laurence (external link) :: 6D + Lens
Player9
Sep 01, 2012 10:53 |  #6
The comparison is not exactly apples to apples, but it's close enough given that there is usually no prime lens that, when used on a crop camera, would provide the exact same field of view as another prime lens on a FF camera (and using zoom lenses introduces other variables when they are focused at different distances).
The difference is easily visible and is probably even bigger for Canon, as the Nikon is a 1.5x crop (slightly closer to the size of FF than the Canon 1.6x crop). If you need that "look," FF is the way to go.
RP, 60D, RF 24-105mm f/4-7.1 IS, RF 35mm f/1.8 IS, RF 50mm f/1.8, EF-S 10-22mm f/3.5-4.5, EF-S 18-135mm 3.5-5.6 IS, EF-S 55-250mm f/4-5.6 IS, Tamron 17-50mm f/2.8, EF 28mm f/1.8, EF 50mm f/1.8, EF-S 60mm f/2.8 macro, EF 85mm f/1.8, El-100, 430ex, 220ex, Alien Bee B400 (2), Alien Bee B800 (2)
jimewall
Sep 01, 2012 11:48 as a reply to  @ Player9's post |  #7
Looks about right.
Thanks for Reading & Good Luck - Jim
GEAR
sebr
Sep 01, 2012 12:09 |  #8
Interesting example! Thanks for sharing!
Sebastien
5D mkIII ; 17-40L ; 24-105L ; 70-200L II ; 70-300L ; 35L ; Σ85/1.4 ; 135L ; 100macro ; Kenko 1.4x ; 2x mkIII ; 580EXII
M5 ; M1 ; 11-22 ; 18-150 ; 22/2.0 ; EF adapter; Manfrotto LED
Benron Tripod; ThinkTank, Lowepro and Crumpler bags; Fjällräven backpack
DreDaze
Gallery: 49 photos
Sep 01, 2012 12:33 |  #9
i would've liked to have seen 50mm on a crop, and then 50mm on a FF moved forward to obtain the same framing
Andre or Dre
gear list
Instagram (external link)
archer1960
Gallery: 6 photos
Sep 01, 2012 12:48 |  #10
DreDaze wrote in post #14935156 (external link)
It will give you basically the same result.
Gripped 7D, gripped, full-spectrum modfied T1i (500D), SX50HS, A2E film body, Tamzooka (150-600), Tamron 90mm/2.8 VC (ver 2), Tamron 18-270 VC, Canon FD 100 f/4.0 macro, Canon 24-105 f/4L,Canon EF 200 f/2.8LII, Canon 85 f/1.8, Tamron Adaptall 2 90mmf/2.5 Macro, Tokina 11-16, Canon EX-430 flash, Vivitar DF-383 flash, Astro-Tech AT6RC and Celestron NexStar 102 GT telescopes, various other semi-crappy manual lenses and stuff.
DreDaze
Gallery: 49 photos
Sep 01, 2012 15:26 |  #11
archer1960 wrote in post #14935192 (external link)
Not quite...you'd have to get a bit closer with the FF camera yielding less DOF
Unless you meant the same result as the link...
Andre or Dre
gear list
archer1960
Gallery: 6 photos
Sep 01, 2012 18:23 |  #12
DreDaze wrote in post #14935625 (external link)
Yes, that's what I meant.
Earwax69
Joined Jul 2012
Sep 01, 2012 18:26 |  #13
I think it would be a bit similar as the 85mm now used produce more bokeh than the 50mm. Thus the 50mm closer would be quite similar to the 85mm farther. Still I would like to see that too.
xarqi
Sep 01, 2012 18:28 |  #14
Earwax69 wrote in post #14934721 (external link)
Have fun!
Like most of these analyses, it demonstrates the effect of differences in focal length on DoF, not the effect of differences in format.
(Yes, I'm doing it again.)
Wilt
Sep 01, 2012 18:43 |  #15
To do a proper comparison, you need to mount the SUITABLE FL for the format size on each camera to frame the same amount of subject space on both format cameras, at the identical camera position for both!
For example, at subject distance of 10' using f/2 on the lens
  • the 50mm lens on APS-C body has 2.9' x 4.4' within frame, and DOF zone of 0.75'
  • the 80mm lens on FF body has 2.95' x 4.4' within frame, and DOF zone of 0.46'
The difference in DOF is neutralized when one uses an f/stop which is 1.6x larger on the APS-C body,
  • so f/1.23 on 50mm lens on APS-C give same DOF as f/2 on 80mm on FF
  • so f/2.48 on 50mm lens on APS-C give same DOF as f/4 on 80mm on FF
5,759 views & 0 likes for this thread, 20 members have posted to it.
2667 guests, 159 members online
