Hey... I see I can get a Yongnuo flash for a lot less than Canon.
If I was looking for a used 430exII, should I instead go for a equal Yongnuo ? Or even a model up?
Thanks for the advice;
D
DanKearley Senior Member 426 posts Likes: 32 Joined Aug 2012 More info | Sep 01, 2012 19:02 | #1 Hey... I see I can get a Yongnuo flash for a lot less than Canon.
Sep 01, 2012 19:22 | #2 I suppose the YN565EX is the one I'd look for?
nes_matt Goldmember 1,022 posts Likes: 14 Joined Aug 2010 More info | Sep 01, 2012 19:25 | #3 I have a Yn560 which I bought before the ettl yn565 came out. It's a good flash. Lots of people here like them, especially those of us that don't do this for living. Before I knew about Yongnou I was hemming and hawing over getting a 430exII and not wanting to spend the money - especially since I didn't really know what a flash was going to do for me... turns out it does a lot! Go figure! Canon 6D & Rebel T1i | Tokina 11-16 F2.8 | Sigma 18-50mm F2.8 EX DC Macro | Nifty-Fifty |85mm f1.8 | Canon 24-105 F4 | Sigma 70-200mm f/2.8 EX DG OS HSM
Sep 01, 2012 19:35 | #4 I ordered the YN565EX. Can't wait.
Sep 01, 2012 19:36 | #5 For anyone else interested, this looks like a great resource:
5280Pics Goldmember More info | Sep 01, 2012 19:41 | #6 I have two older Yongnuo flashes that have worked flawlessly for the last few years (admittedly, I don't use them a lot) I would take a look at the new 568EX! Lots of bells and whistles for the price, including HSS! Conversation here. . . https://photography-on-the.net …/showthread.php?t=1220090 _______________
glumpy Senior Member 388 posts Likes: 1 Joined Jul 2010 More info | Sep 01, 2012 19:42 | #7 Permanent banI bought my 2nd 565 this week. From RDKirk: First, let me check the forum heading...yes, it does say "Business of Photography" and not "Hobby of Photography." Okay. So we're talking about making money, not about hobbies. By "business" I am presuming activities that pay expenses and produce a profit over the long term.
Juvenall Junior Member 21 posts Joined Jan 2012 Location: #!/usr/bin/Detroit More info | Sep 01, 2012 19:46 | #8 I have the 468 II that I picked up from Amazon and it's been great, but the lack of high speed sync was sort of a bummer. They've apparently launched a brand new model (568EX) Gear: 5D Mk III | 7D | Sigma 35mm f/1.4 | Sigma 50mm f/1.4 | 24-70mm f/2.8L | 70-200mm f/2.8L Mk II | 100mm f/2.8L Macro
kboater Member 195 posts Joined Nov 2011 More info | Sep 01, 2012 22:30 | #9 nes_matt wrote in post #14936154 I have a Yn560 which I bought before the ettl yn565 came out. It's a good flash. Lots of people here like them, especially those of us that don't do this for living. Before I knew about Yongnou I was hemming and hawing over getting a 430exII and not wanting to spend the money - especially since I didn't really know what a flash was going to do for me... turns out it does a lot! Go figure! You can get a YN565 for about $150. It is supposed to be the power equivalent of the big Canon flash (but doesn't have the ettl command capability - if you don't know what this is you didn't need it). You'll never regret having an extra stop of power available. If you decide you need the canon later on, you'll still have this as a back up for only $150. And then you can try doing some multi flash work. Im new to flashes too, can someone explain to me what the diff is between ettl (like canon flashes) and ttl like these Yongnuo?
nes_matt Goldmember 1,022 posts Likes: 14 Joined Aug 2010 More info | Sep 01, 2012 22:46 | #10 The canon 580 can control other flashes that are not mounted to the camera. Other than that it's just semantics. Canon 6D & Rebel T1i | Tokina 11-16 F2.8 | Sigma 18-50mm F2.8 EX DC Macro | Nifty-Fifty |85mm f1.8 | Canon 24-105 F4 | Sigma 70-200mm f/2.8 EX DG OS HSM
kboater Member 195 posts Joined Nov 2011 More info | Sep 01, 2012 23:18 | #11 nes_matt wrote in post #14936597 The canon 580 can control other flashes that are not mounted to the camera. Other than that it's just semantics. TTL means "through the lens" metering so ettl?
Consigliere Member 112 posts Joined Aug 2010 More info | Sep 02, 2012 05:13 | #12 kboater wrote in post #14936663 so ettl? i just moved up to a 5d mkii, have not got into flashes yet obviously. can my 5d mkii wirelessly (off camera) fire a flash? or do i have to have a trigger or flash (like canon 580) mounted to the camera to trigger an off camera flash? thanks 5DMkII wont be able to control a flash wirelessly unless you have a trigger attached to the hotshoe. 7D and T3i can trigger flashes remotely as they do have wireless capability. 550D, 5DMk II, 85 f/1.8, 70-200 f/2.8 IS II, 24-105 f/4, 580EX II.
nes_matt Goldmember 1,022 posts Likes: 14 Joined Aug 2010 More info | Sep 02, 2012 07:49 | #13 kboater wrote in post #14936663 so ettl? i just moved up to a 5d mkii, have not got into flashes yet obviously. can my 5d mkii wirelessly (off camera) fire a flash? or do i have to have a trigger or flash (like canon 580) mounted to the camera to trigger an off camera flash? thanks e-ttl = evaluative ttl Now with that background it is easier to understand the evolution of Canon flash from TTL to E-TTL to E-TTL-II: TTL: Metering in earlier Canon film cameras was done using light reflected off the film when the shutter opened exposing it. Canon designates these cameras "Type B" and calls the metering "TTL". TTL is also a generic term applied to any camera or flash which utilizes "through the lens" metering.The earlier EZ series of flashes were designed to work with TTL film cameras; they will not work with digital cameras. However the Canon 580ex can be made backward compatible with TTL "Type B" cameras by setting its C.FN 03 to "1". E-TTL: DSLR cameras prior to the 20D meter exposure using light from the viewfinder in the camera. A multi-zone sensor above the viewfinder reads the light prior to the shutter opening. When flash is used the pre-flash occurs when the shutter button is half-pressed to lock focus. The main flash occurs just after the shutter button is fully depressed and the shutter opens. On camera bodies with E-TTL metering the active AF point is used when calculating the amount of flash needed. The time lag between pre-flash and main flash may produce unpredictable results if the camera is focused on one spot to lock focus, then moved to recompose the shot before the button is fully pressed. This practice, which is necessary when using the center AF, can lead to erratic flash exposures. For E-TTL "Digic" era cameras Canon recommends moving the AF rather than recomposing or using Flash Exposure Lock (FEL) which unlinks the focusing and pre-flash. E-TTL II: The 20D and more recent cameras with Digic II processors use an exposure method designated as E-TTL II. E-TTLII flash exposure has two modes: evaluative and averaging. When the shutter button is fully depressed,The E-TTLII system takes an ambient reading (separate from the one controlling the shutter in Av mode) then fires the pre-flash which allows it to meter and compare both ambient and pre-flash in the split second before the shutter opens and the main burst of flash fires. E-TTLII also uses focus distance information transmitted by some USM lenses to determine flash power, but only if the flash is used directly in the 0° horizontal position. When the flash head is tilted for bouncing or diffuser use there is no longer any direct correlation between distance and exposure and the metering relies entirely on the comparison of the ambient and pre-flash at full shutter press over the 35 or more metering zones on the viewfinder. Canon 6D & Rebel T1i | Tokina 11-16 F2.8 | Sigma 18-50mm F2.8 EX DC Macro | Nifty-Fifty |85mm f1.8 | Canon 24-105 F4 | Sigma 70-200mm f/2.8 EX DG OS HSM
kboater Member 195 posts Joined Nov 2011 More info | Consigliere, thank you.
nes_matt Goldmember 1,022 posts Likes: 14 Joined Aug 2010 More info | Sep 02, 2012 16:00 | #15 kboater: if you're buying your first flash, you have nothing to worry about. Get which ever you prefer. Canon 6D & Rebel T1i | Tokina 11-16 F2.8 | Sigma 18-50mm F2.8 EX DC Macro | Nifty-Fifty |85mm f1.8 | Canon 24-105 F4 | Sigma 70-200mm f/2.8 EX DG OS HSM
| Latest registered member is semonsters 1352 guests, 137 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
