Thread started 01 Sep 2012 (Saturday) 19:39
My first attempt
JGunn
Joined Aug 2012
Sep 01, 2012 19:39 |  #1
Hi all,
I am really just getting started in dSLR photography and wanted to give some HDR landscape photos a try.
IMAGE: http://i1146.photobucket.com/albums/o533/jedgunn/Photos/IMG_1177_hdr.jpg
I am not overly pleased with the result, but was hoping to get some feedback. The photos were taken with the camera balanced on a rock. I think this is what led to the lack of sharp focus throughout.
Do you have any suggestions on compact tripods? Ideal length when closed is around 16-18 inches.
Thanks!
J.Gunn - Macon, GA, USA
1D X; 1D MkIV | 16-35mm f/2.8L; 100mm f/2.8L IS; 400mm f/2.8 IS; 2x extender; Kenko DG Ext Tubes
paul-t
Location: The deep south, that's the deep south of England.
Sep 02, 2012 01:02 |  #2
Would also depend on F stop used, the hdr bit is not overdone. As for the tripod have a look at the Velbon Sherpa 500 series, light but sturdy and can be used low/high level also the legs have multi position.
rick_reno
Sep 02, 2012 10:50 |  #3
nice shot, like the color/perspective. i'd turn down the HDR a little bit, the clouds look over cooked
JGunn
Joined Aug 2012
Sep 02, 2012 18:08 |  #4
rick_reno wrote in post #14937923 (external link)
Thank you. I agree with the cloud comment, as well. I will keep practicing.
paul-t wrote in post #14936871 (external link)
I had f/9 set with 1/60 exposure. The rock wasn't the most stable of things to use as a base.
Also, I reviewed the Velbon Sherpa 555R. It meets all requirements perfectly, except I am concerned over the rated load capacity. Is 3kg sufficient?
Laramie
Still livin' the cowboylife
Sep 02, 2012 18:15 |  #5
Did you sharpen during PP? AT least to my eyes, I'm not noticing a lot of camera shake or softness. I think the HDR might be robbing you of some detail.
5DIII | 40D | 17-40 f4L | Tamron 28-75 2.8 | 50 1.4 | 70-200 2.8L | Oly Zuiko 50 macro | Tamron 1.4x
JGunn
Joined Aug 2012
Sep 02, 2012 18:23 |  #6
Laramie wrote in post #14939470 (external link)
Processing apart from the HDR was minimal. The main area I notice the detail loss is in the leafs on the left hand side. Everything else seems to be quite crisp.
Laramie
Sep 02, 2012 18:28 |  #7
Was the wind blowing? Is this a single shot tone-mapped or 3 bracketed shots?
JGunn
Joined Aug 2012
Sep 02, 2012 18:33 as a reply to  @ Laramie's post |  #8
It is a three shot overlay.
There wasn't much wind, but with three shots, although rapid there would be some differences. Is this where you were heading?
Laramie
Sep 02, 2012 18:35 |  #9
Yes, Just wondering if the ghosting is causing the lack of detail on the upper left side. Did you look closely at a single shot before merging to see if there's a difference?
JGunn
Joined Aug 2012
Sep 02, 2012 18:39 as a reply to  @ Laramie's post |  #10
No, I never really did closely examine the shots. I liked the view, had been reading a little about HDR photos, so decided to give a whirl.
Thanks for the help!
Laramie
Sep 02, 2012 18:50 |  #11
No probem. I've had the most trouble with small leaves in my HDRs. Just due to any little movement it will cause them to ghost and cause softness when you do the merge.
paul-t
Sep 02, 2012 22:45 |  #12
Hi there, I use the sherpa with a gripped 50d and lens up to my Canon 35-350 L with no problems. Just make sure you get a good head.
JGunn
Joined Aug 2012
Sep 03, 2012 03:41 |  #13
paul-t wrote in post #14940286 (external link)
Thanks, that would be the most I'd ever have on it.
digidiva
Sep 03, 2012 08:43 |  #14
Regardless of any scene movement issues, I think the HDR processing is way overdone.
BUYING A CANON DOESN'T MAKE YOU A PHOTOGRAPHER, IT MAKES YOU A CANON OWNER.
POST HOC, ERGO PROPTER HOC
JGunn
Joined Aug 2012
Sep 04, 2012 15:09 |  #15
digidiva wrote in post #14941434 (external link)
I appreciate your opinion. Any suggestions?
3,499 views & 0 likes for this thread, 8 members have posted to it.
My first attempt
1210 guests, 110 members online
