Thread started 01 Sep 2012 (Saturday) 22:52
Phottix Odin (in studio)
Stickman
Sep 01, 2012 22:52 |  #1
Anyone using these to trigger their studio lights? I'm getting a clean 1/250th in studio.
If anyone knows how to make them cheat and go a little higher, it would open up a world of options for outside the studio.
Anyone able to synch higher with AB 1600s or something else?
Thanks!
ETA- I didn't put this in the other Phottix thread as that one was geared towards ETTL.
Stick
http://www.flickr.com/​photos/stickgunner/ (external link)
Moppie
Moderator
Gallery: 19 photos
Joined Sep 2004
Sep 01, 2012 23:34 |  #2
I really should give it a go with my Elinchroms, could be interesting to see what I can get out of them.
Have you Calibrated your Monkey lately?
Stickman
Sep 02, 2012 00:17 |  #3
Moppie wrote in post #14936696 (external link)
Agreed, with other units being able to HSS (or a variant of HSS), I would think Phottix could make that mod through firmware and sell it as an upgrade if they really wanted to.
Either that or its already possible, and we just haven't heard about how to do it.
Stick
Moppie
Moderator
Gallery: 19 photos
Joined Sep 2004
Sep 02, 2012 05:02 |  #4
I've heard of people making it working using HSS on the odins, just haven't tried it.
elv
Sep 02, 2012 05:08 as a reply to  @ Stickman's post |  #5
Yes its already possible, all you do is put the TCU in HSS mode and start using any shutter speed.
Results will vary depending on lights and camera and its usually best to use full power on the monolights. Works best with lights with long flash duration, the AB1600 should go ok.
FLASHHAVOC.COM (external link)
sempaidavid
Sep 02, 2012 18:24 |  #6
I have got HHS to work with my AB and Einsteins.
5D mkIII, 1D mkIV, Tokina 16-28 f/2.8, EF 24-70L, EF 70-200 f/2.8L II IS, EF 100-400L, EF 85 f/1.8, Sigma 50 f/1.4, EF 24-105
http://www.davidcostap​hotography.com (external link)
Stickman
Sep 02, 2012 18:55 |  #7
sempaidavid wrote in post #14939508 (external link)
That is good to hear, using which camera body or bodies? In manual or TTL?
Stick
sempaidavid
Sep 02, 2012 22:56 |  #8
Stickman wrote in post #14939601 (external link)
There is no TTL on AB, or any strobes that I know of. I tested it on my my 7d. I should test on my 1d mkIV and 5d mkIII now. I just have got around to it.
Stickman
Sep 02, 2012 22:59 |  #9
sempaidavid wrote in post #14940322 (external link)
Obviously not on the strobes.... how would the a strobe see "TTL"? I should have phrased it differently, my bad. :D
Stick
elv
Sep 02, 2012 23:47 as a reply to  @ Stickman's post |  #10
It doesn't matter if you have the TCU on ETTL or manual.
I set it to manual just out of logic, but it was sempaidavid's comments earlier that made me realise it makes not difference. Just turn HSS on, on the TCU and you're good to go.
sempaidavid
Sep 03, 2012 17:50 |  #11
So I just tried to achieve this again so I could post examples and it was a no go. Not sure if it has anything to do with me recently updating my Odins firmware.
lukx
Sep 04, 2012 01:34 |  #12
I though Odin works only with hotshoe flashes ?
www.lukx.com (external link) :: cgi
Stickman
Sep 04, 2012 02:13 |  #13
sempaidavid wrote in post #14943473 (external link)
I got mine to work, and now it won't. I can't figure out if I changed a setting or what happened.
Stick
anshum_m
Joined Jun 2010
Apr 28, 2014 22:29 as a reply to  @ Stickman's post |  #14
Sempaidavid, Stickman... I used my phottix odin's with my elinchrom master rx strobes a week back and was able to perfectly sync even at 1/8000. And yet yesterday when I tried the same in an actual shoot situation, it failed. Seems u both faced the same problem. Were you able to find out why it occurred or how to overcome it? I know this is now a really old thread but i really need to hear back on this. Thanks in advance!
chris_holtmeier
Joined Sep 2011
Apr 28, 2014 22:33 |  #15
Wow, necro-bump.
anshum, I know this sounds like a stupid question, but did you have the transmitter in HSS mode?
https://www.facebook.c​om/FotonFoto (external link)
4,657 views & 0 likes for this thread
Latest registered member is Ellie.outram2002
1056 guests, 299 members online
