I'm trying to figure out the best way to get a shot like this:
I have a 60D with all the lenses listed below. Can anyone advise me on how I can achieve this please?
Nino
ninobrn99 Senior Member 731 posts Likes: 7 Joined Jul 2006 Location: Manama, Bahrain More info | Sep 02, 2012 14:45 | #1 I'm trying to figure out the best way to get a shot like this: I have a 60D with all the lenses listed below. Can anyone advise me on how I can achieve this please? Nino 5D MK3 | iPhone 6s Plus
Sep 02, 2012 17:50 | #2 Find the filter thread diameter for the J.C penny 28mm lens and get a reversing ring and an adapter that will match the diameter of the j.c. penny thread. The reversed 28mm will easily give you the image above Wes
ninobrn99 THREAD STARTER Senior Member 731 posts Likes: 7 Joined Jul 2006 Location: Manama, Bahrain More info | Sep 02, 2012 18:01 | #3 So I guess the answer is to use a wide lens reversed. Guess I'll order an adapter 5D MK3 | iPhone 6s Plus
ninobrn99 THREAD STARTER Senior Member 731 posts Likes: 7 Joined Jul 2006 Location: Manama, Bahrain More info | Sep 02, 2012 18:14 | #4 Did a trial run holding the lens myself. Even with the 28 reversed, it isn't quite as close as I would like.
Any other ideas? Nino 5D MK3 | iPhone 6s Plus
AntonLargiader Goldmember More info | Sep 02, 2012 19:34 | #5 What main lens were you using with the 28? Image editing and C&C always OK
ninobrn99 THREAD STARTER Senior Member 731 posts Likes: 7 Joined Jul 2006 Location: Manama, Bahrain More info | Sep 02, 2012 20:20 | #6 Just the 28 reversed. Not attached to anything. Would bellows with a reversed lens be my best option? 5D MK3 | iPhone 6s Plus
SimonParadis Member 59 posts Joined May 2010 Location: Québec More info | Sep 02, 2012 20:31 | #7 Best would be to buy Kenko extension tubes, they are cheap and very effective. However you'd have to crop maybe 50% to get closer. You'd have to buy the amazing MP-E65 macro 1-5x lens, 2-3x would be more than enough but you'll need a steady tripod and good lighting 5D3 | 35 ƒ1.4 | 85 ƒ1.4 | 24-70 ƒ2.8L | 70-200 ƒ2.8L USM | Tokina 11-16 ƒ2.8
ninobrn99 THREAD STARTER Senior Member 731 posts Likes: 7 Joined Jul 2006 Location: Manama, Bahrain More info | Sep 02, 2012 20:40 | #8 SimonParadis wrote in post #14939902 Best would be to buy Kenko extension tubes, they are cheap and very effective. However you'd have to crop maybe 50% to get closer. You'd have to buy the amazing MP-E65 macro 1-5x lens, 2-3x would be more than enough but you'll need a steady tripod and good lighting Yeah, I was looking at that MP-E65. Too expensive for occasional use. Sadly, 5x still isn't enough. I use a 20x loupe to examine the nibs when I'm working on them and that's not always close enough. 5D MK3 | iPhone 6s Plus
recrisp Goldmember More info | Sep 03, 2012 11:23 | #9 ninobrn99 wrote in post #14939928 Yeah, I was looking at that MP-E65. Too expensive for occasional use. Sadly, 5x still isn't enough. I use a 20x loupe to examine the nibs when I'm working on them and that's not always close enough. I'm also thinking about a microscope camera (a cheaper one). I wonder what my other options are.... Thanks for the help so far folks. Nino If you are wanting to get what the pictures that you posted, you may want to consider getting the camera that took them. The camera is a Nikon E990
ninobrn99 THREAD STARTER Senior Member 731 posts Likes: 7 Joined Jul 2006 Location: Manama, Bahrain More info | Sep 03, 2012 11:47 | #10 recrisp wrote in post #14942035 If you are wanting to get what the pictures that you posted, you may want to consider getting the camera that took them. The camera is a Nikon E990 You may not be able to find one exactly like it, but, more than likely, it's successors are very similar in the Macro area. If that is something that interests you, there are always cameras like that on Craigslist or e-Bay, pretty cheap too. Another way is to get Diopter lens that screw onto your existing lenses, I have gotten some very good results with those. Hopefully that helps, it's way cheaper to do than buying an expensive lens. EDIT: This is not the exact camera as I mentioned, it is really, but the difference is that it has a plastic tripod screw hole, not a metal one like the 990... (This is in Houston too) http://houston.craigslist.org/bar/3204596298.html The Coolpix name is also something that you would want to look under, the 990 is a Coolpix, it was the first one, now, there's a lot of them, they will 'probably' have the same 'stuff' that you'd need to get that macro shot you need. Here's the Houston area Craigslist search under, "Coolpix"... http://houston.craigslist.org …&minAsk=&maxAsk=&hasPic=1 Randy Randy, 5D MK3 | iPhone 6s Plus
recrisp Goldmember More info | If that is a route that you would want to try, here's another one that will take even almost as close in macro shots...
| Latest registered member is Marcsaa 505 guests, 127 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
