Thread started 03 Sep 2012 (Monday) 16:23
Question: anchoring foam board to wall
Sebastian ­ Riel
Joined Mar 2011
Sep 03, 2012 16:23 |  #1
The foam board is 3/16 inches thick. I don't want to matt it. Anyone have experience or any idea's. I of course don't want to puncture the foam board.
https://youtu.be/izdrD​d0v1lE (external link)
Baby sharks are cute, so are baby rotti's.
tonylong
...winded
Gallery: 60 photos
Sep 03, 2012 17:20 |  #2
Crafts stores have things such as double-sided tape used to mount things to walls.
Tony
recrisp
Gallery: 196 photos
Sep 03, 2012 18:09 as a reply to  @ tonylong's post |  #3
They make a thing just for that, it's called, Blu-Tack (external link), I've not used it before, but from what I have read it works. (I am not sure the weight of your picture though)
Randy
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Sep 03, 2012 18:14 |  #4
recrisp wrote in post #14943545 (external link)
Randy
^^^That stuff. Just roll some small balls of the stuff in your fingers, put one at each corner and one or two in the center of the board and press it to the wall. Should stick just fine.
Otherwise, the double-sided tape mentioned by another post should work, too; but that can leave residue on plasterboard and/or peel paint when removed.
René ­ Damkot
Sep 04, 2012 05:54 |  #5
I'd glue a frame behind the board.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
recrisp
Gallery: 196 photos
Sep 04, 2012 09:09 |  #6
René Damkot wrote in post #14945538 (external link)
Really, that makes the most sense, even if the Blue-Tack is made for it, I'd hate to see that your picture came down after a while because it wasn't strong enough to hold.
Good idea, just make sure that the glue you use doesn't seep through to the front side of the photograph. I use silicone a lot for these types of things, not that I have ever used it on photographic paper though.
Randy
bsmotril
Gallery: 11 photos
Joined Feb 2006
Sep 04, 2012 11:56 |  #7
I'd hot glue a small 1.5" square of of soft plywood about 3/16" thick to each corner and top center, then tack a hanger loop to the top center one.
Galleries: http://www.flickr.com/​photos/smopho/ (external link) --- http://billsmotrilla.z​enfolio.com/ (external link)
Rimmer
Joined Nov 2010
Sep 04, 2012 13:53 |  #8
bsmotril wrote in post #14946596 (external link)
This sounds like a good idea. If you were to make a wooden frame all the way around you might have a problem with the wood warping due to changes in humidity and temperature. A good choice for glue would the the aliphatic type (yellow carpenter's glue) as it is very compatible with both the paper surface of the foam core board and with wood.
Ace Rimmer -- "What a guy!"
"Smoke me a kipper, I'll be back for breakfast." ;)
Sebastian ­ Riel
Joined Mar 2011
Sep 04, 2012 19:39 as a reply to  @ Rimmer's post |  #9
Mounting on plywood; that's a good idea; thanks bsmotril. Thanks guys for your feedback; much appreciated :D
Mark1
Sep 04, 2012 21:57 |  #10
There are metal triangles that are attached to a small sticky pad. They are just for things like this. I don't have a name or brand at the moment to share. But I have used them in the past. The sticky pad is pretty permanent so it may have to stay on it if you change your mind on how to hang it.
Mark1
Sep 04, 2012 22:00 |  #11
Not exactly what I had in mind, but a Quick search found these...
http://www.allproducts​.com …plastic_hanger_​print.html (external link)
2,860 views & 0 likes for this thread, 8 members have posted to it.
1522 guests, 132 members online
