Thread started 23 Dec 2005 (Friday) 06:36
Is it me? Filter Sizing
Oldie
Dec 23, 2005 06:36 |  #1
Hi,
Any help appreciated! I'm a newbie to DSLR upgrading from a compact ready to start next stage of appreticeship.
I bought a EF-S 17-85 for my 20D. The lens size is 67mm so naturally at the same time bought a Hoya Cir-Polarizer 67mm filter, but it does not fit the lens.
Is there a reducer, thread type or some other adapter I need or is it a case of a larger filter? The lens hood I had to buy as an extra seems to be a twist and click fit rather than a thread...so now I'm confused..........:confused:
SkipD
Joined Dec 2002
Dec 23, 2005 06:44 |  #2
Oldie wrote:
Hi,
Why do you say the filter does not fit the lens? Is it possible that you aren't aware that the filter itself can rotate in the threaded mount? If you're holding only the ring that is supposed to be able to rotate when the filter is mounted to the lens, it is possible that there is not enough friction to make the threads engage. You need to put your fingers around the threaded ring to screw the filter onto the lens.
Many of Canon's hoods mount to the lens body, not the filter threads. This is a good thing, because when you whack the hood against something the force is transferred to a much more robust body than to moving portions of the lens assembly.
Skip Douglas
Kennymc
Joined May 2003
Dec 23, 2005 12:03 as a reply to  @ SkipD's post |  #3
Skip is correct, so make sure you fit the filter before the lens hood or you might not get the leverage to screw it on...
www.kennymc.com (external link)
Equipment http://kennymc.com/Inf​ormation/equipment.htm​l (external link)
http://www.kennymc.com​/equipment.htm (external link)
Oldie
Dec 24, 2005 15:21 |  #4
It`s me!! Thanks for the help guys ... great to find a forum where people are helpful and don`t rip newbies to shreads! I didn`t realise the filter is threaded inside and out, also helps if you offer it up to the lens the right way!! Skip was spot on, the filter turns in the housing which confused me...mind you that's not hard to do!
651 views & 0 likes for this thread, 3 members have posted to it.
1779 guests, 133 members online
