Thread started 04 Sep 2012 (Tuesday) 09:46
Editing 16 bit in ACR vs. Photoshop cs5
RandMan
Joined Mar 2012
Sep 04, 2012 09:46 |  #1
Hello All,
I find myself buried in yet another state of post processing confusion. I do my raw processing in ACR and always have it set to Adobe RGB and 16 bit mode. I use those same exact settings in cs5 as well. So from what I've learned, it's always best to do as much editing as you can in raw, because that's where the most information from the original image is accessible and available. I love using Photoshop, however, because of its vast amount of versatility and flexibility. So if I adjust a raw file in ACR, and then open it in Photoshop, it still opens it in cr2 format (and still in Adobe RGB 16 bit). With that being said, wouldn't any edits done inside of Photoshop be acting on the same exact image information as in raw? In other words, if I don't do any curves or contrast adjustments etc. in raw but do them in Photoshop instead, how is it any different? If I switched to 8 bit mode once inside of cs5 then I would understand, but if bit mode and color space are the same am I losing anything?
Canon eos7D | Canon 50mm 1.4 | Canon 17-55mm 2.8 | Sigma 70-200mm 2.8 | Yongnuo 565ex | Yongnuo yn-468 II | Canon ef28-135mm 3.5/5.6 | Canon ef-s 55-250mm 4.0/5.6
René ­ Damkot
Sep 04, 2012 10:17 |  #2
RandMan wrote in post #14946116 (external link)
It says so, but at that point it really is not, since it's rendered by ACR. It's like any other file in PS. Comparable to for instance a 16bpc .psd file.
Edit:
http://www.luminous-landscape.com/tutorial​s/expose-right.shtml (external link)
LL wrote:
All non-linear processing is done in the RAW converter.
and a long discussion here;
http://www.luminous-landscape.com/forum/in​dex.php?topic=25031.0 (external link)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
885 views & 0 likes for this thread, 2 members have posted to it.
1061 guests, 103 members online
