Thread started 04 Sep 2012 (Tuesday) 18:56
what is ETTL?
ConCon
Joined Mar 2011
Sep 04, 2012 18:56 |  #1
This may be a bad question, but it is confusing me. Is ETTL something that only applies to external flashes, or does the pop-up flash on a 60D also use ETTL metering? I am considering buying a cheap external flash but I don't really understand much about them. Probably something like a YongNuo 468 II.
Craign
Gallery: 17 photos
Sep 04, 2012 19:02 |  #2
This will add to your confusion: http://en.wikipedia.or​g/wiki/Canon_EOS_flash​_system (external link)
More info: https://photography-on-the.net/forum/showthre​ad.php?t=171657
A lot more: http://photonotes.org/​articles/eos-flash/ (external link)
Canon 7D Mark II w/Canon BG-E16 Battery Grip; Canon EOS 50D w/Canon Battery Grip; Canon SL1; Tokina 12mm - 24mm f/4 PRO DX II; Canon EF 24-105mm f/4L IS; Canon EF 70-200mm f/2.8L IS; Canon 70-300mm f/4-5.6L IS; Sigma 85mm f/1.4 EX DG HSM; Canon EF 300mm f/4L IS; Canon EF-S 18-135mm f/3.5-5.6 IS STM; Canon Extender EF 1.4x II; Canon Extender EF 2x II; Canon Speedlite 430EX II Flash
Image Editing Okay
frugivore
Gallery: 11 photos
Sep 04, 2012 19:55 |  #3
It's the equivalent of the camera's 'automatic' exposure mode. In auto, the camera guesses what the exposure should be. In ETTL mode, the flash guesses what its light output should be, which determines part of the exposure. I found that I learned more quickly when using manual for both camera and flash. The YN-560s are good cheap manual flashes.
apersson850
Obviously it's a good thing
Gallery: 35 photos
Sep 05, 2012 02:45 as a reply to  @ frugivore's post |  #4
"Guesses" is perhaps to take it a bit far. It meters the light according to certain presumptions about subject reflectivity.
E-TTL works with a pre-flash, just before exposure, where the camera meters the flash. The camera will then tell the flash how much power to put into the real flash, when the actual exposure occurs. As with all reflective light metering, it's convenient and works well for many subjects, albeit not all of them.
Anders
MikeWa
Gallery: 89 photos
Joined Apr 2012
Sep 06, 2012 11:48 |  #5
Electronic Through The Lens metering.
Mike
Mike...G9; 7D; 7D Mark II; EF-S 10-22mm; EF-S 18-135mm IS STM; EF 28-300mm F3.5-5.6L; EF 70-300mm IS USM; EF 70-200mm F2.8L IS-II; EF 100-400mm f4.5-5.6L IS; EXT 1.4-II & 2.0-III; The more I learn the less I know.
WaltA
Gallery: 10 photos
Joined Feb 2006
Sep 06, 2012 12:45 |  #6
Evaluative Thru The Lens metering
Walt
400D, 5D, 7D and a bag of stuff
TSchrief
Joined Aug 2012
Sep 06, 2012 12:57 |  #7
MikeWa wrote in post #14955444 (external link)
Mike
WaltA wrote in post #14955644 (external link)
'Fraid Walta is right here. ETTL is Canons way of deciding how much flash you want. It functions differently in each of the 4 modes, M, Av, Tv, and P. Take the same shot with each of these modes and you will likely get a completely different flash and ambient exposures. I find it to be most predictable in P mode. Something I don't use very often. Manual is better. Best to leave Av and Tv alone when shooting with a flash. It can be full of surprises.
The best way to use flash is in Manual mode, the flash not the camera. That way YOU get to decide what the equipment is going to do. Couple that with manual exposure control for ambient and you are in total control of what you get.
WaltA
Gallery: 10 photos
Joined Feb 2006
Sep 06, 2012 13:11 |  #8
Yeah, I'm not totally comfortable with Manual and Flash yet so I've found that if I'm worried about not getting a good shot with a flash I'll drop it into P mode and take a backup shot. Seems to always work "OK".
Walt
rrblint
Gallery: 84 photos
Joined May 2012
Sep 06, 2012 13:19 as a reply to  @ TSchrief's post |  #9
I agree with TSchrief...Manual everything IS the way to be assured of getting exactly what you have envisioned.
However, when shooting on the fly(at weddings and other events) I have found ETTL to be useful if not essential for nailing shots that I simply don't have time to set up perfectly. It works very nicely using P or Tv modes. Av is problematic in that the shutter speed can drop below hand holdable levels(though this can be limited via custom function on some cameras).
The system is not perfect and will give unexpected results in some situations, but I've found that in most instances it provides adequate results when time is at a premium.
To answer your questions:
1.) Yes ETTL is applied with the on board flash.
2.) I don't own them so I can't speak from experience, but I've read elsewhere that the YongNuo flashes don't have ETTL capability.
Mark
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Sep 06, 2012 13:25 |  #10
And yes, the pop-up flash can also use ETTL metering. It's just not a very effective flash unit.
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Sep 06, 2012 13:28 |  #11
rrblint wrote in post #14955758 (external link)
It depends on the model. They have some that are manual only, but most of the newer ones have ETTL and similar functionality to canon's flashes. Not to equate them in build quality however.
rrblint
Gallery: 84 photos
Joined May 2012
Sep 06, 2012 13:32 |  #12
gonzogolf wrote in post #14955795 (external link)
Thanks for the info Gonzogolf.:)
Mark
11,588 views & 0 likes for this thread, 10 members have posted to it and it is followed by 2 members.
what is ETTL?
2665 guests, 168 members online
