The manual for most Canon DSLR's mentions that video recording can shut down if the sensor overheats. From my understanding that only happens after 15-20 minutes but could be sooner if you are repeatedly recording videos, even in segments.
As others have pointed out, a class 10 card should be OK, but keep in mind that there are a tremendous number of counterfeit cards in the on-line marketplace. They may be labeled 10 but could be something altogether different. Get your memory from a reputable source, read that not eBay!
Also, be aware there are some limitations on how much you can record, even with the best of memory cards. More than 12 minutes can be recorded but there are some limitations. When the file size reaches 4 GB on most Canon DSLR's, recording will automatically stop. That means that at 1920x1080 dpi and 1280x720 dpi the maximum recording time of a single movie clip is about 12 minutes. At 640x480 dpi it is about 24 minutes. Check your specific T4i manual.
The capacity of the card differs in recorded time; at 1920x1080 dpi or 1280x720 dpi you can stuff 44 minutes total of video onto a 16 gig card. At 640x480 dpi or crop 640x480 dpi this goes up to 1 hour 32 minutes. However, from the 60D manual, "the maximum recording time of one movie clip is 29 min. 59 sec. Depending on the subject and the increase in the camera's internal temperature, the movie shooting might stop sooner than 29 min. 59 sec." This, except for the temperature point, is for legal reasons as someone pointed out.
This is not just the Canon line, Pentax for instance states "Like competing DSLRs, the Pentax K-5 also monitors sensor temperature during recording, and will halt capture if the temperature rises beyond a certain threshold." A reputable source also states "This limitation is due to the different (European) import duty rates for still and video cameras." There is no reference made to differing duty rates of product entering the United States however. So there may really be two limitations, one the 29 min 59 seconds limitation imposed legally, and a sensor temperature issue that might also be reached in some rare circumstance.
By the way, the shutdown due to temperature can be a real drawback, hence my recommendation to heed the advice of those that stated rent a true video device. At a recent horse show I was recording almost continuously and my 60D stopped based on sensor temperature. I had to wait several minutes before I could restart. Obviously if you are filming surgery, then that might come at a critical moment you desire to capture.
