If I take a framed full image with a 7d then take the same subject from the same position with the 5d; what will be the IQ differences when the 5d image is cropped to be identical to the uncropped 7d image?
beesley Hatchling 1 post Joined Sep 2012 More info | Sep 05, 2012 05:52 | #1 If I take a framed full image with a 7d then take the same subject from the same position with the 5d; what will be the IQ differences when the 5d image is cropped to be identical to the uncropped 7d image?
Eric Goldmember 1,253 posts Joined Dec 2006 Location: MA More info | Sep 05, 2012 06:06 | #2 Are you debating which camera to buy? Eric Darlington Photography
apersson850 Obviously it's a good thing More info | You convert the 5D Mark III to a 40D. Anders
Sep 05, 2012 06:37 | #4 Not again.... http://natureimmortal.blogspot.com
Eiro Goldmember 1,368 posts Likes: 27 Joined Dec 2009 Location: U.S. More info | Sep 05, 2012 06:42 | #5 What an awesome way to start of Tuesday morning.Great question. Save your money, get a 7D.When you yourself can answer the very same question you've just asked, then it will be time to upgrade to the 5D series if you are interested. Get out and shoot
MCAsan Goldmember 3,918 posts Likes: 88 Joined Jun 2010 Location: Atlanta More info | Sep 05, 2012 06:47 | #6 If the budget allows, and you don't have to have the 1.6x crop factor or slighty higher FPS from a 7D, then the 5DIII is a no brainer.
Scooby888 Senior Member 264 posts Joined Jun 2012 More info | Sep 05, 2012 07:07 | #7 I almost want to suggest a pair of 7D's over the 5DIII just for a laugh lol 5DII Gripped, 7D Gripped, Canon 60D, Tokina 11-16 f2.8, Canon 17-55 f2.8, Tokina 50-135 f2.8, Canon 24-70 f2.8 L, Canon 24-105 L f4, Canon 70-200 f4 L IS, Canon 70-200 f2.8 L IS, Canon 100-400 f4.5-5.6 L, Canon EF 100 L Macro f2.8, Canon 50mm f1.4, Canon 1.4tc mkii, Speedlite 580ii, 2x Speedlite 430ii, Monfrotto tripods
Sep 05, 2012 07:18 | #8 beesley wrote in post #14949847 If I take a framed full image with a 7d then take the same subject from the same position with the 5d; what will be the IQ differences when the 5d image is cropped to be identical to the uncropped 7d image? No, it'll be worse because the 7D image will have higher resolution and sharpness. The 7D compresses a similar amount of pixels into a smaller area. Canon 5D Mark III - Leica M240
TeamSpeed 01010100 01010011 More info | Sep 05, 2012 08:16 | #9 Mornnb wrote in post #14950003 No, it'll be worse because the 7D image will have higher resolution and sharpness. The 7D compresses a similar amount of pixels into a smaller area. However true this might be, it doesn't really come into play depending on what you print, for example, 8x10s or even a bit larger, you really won't see any of the advantages you list for the 7D. Past Equipment | My Personal Gallery
ScullenCrossBones Senior Member 842 posts Joined May 2009 Location: Keller, TX More info | Sep 05, 2012 08:22 | #10 A camera is just a tool. Consider hammers. A cheap hammer will drive a nail just a well as an air gun. Drive lots of nails with a cheap hammer and you'll be looking for a better tool pretty quickly. :p Gear
| Latest registered member was a spammer, and banned as such! 2665 guests, 168 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
