Hey guys, i'm looking at buying the Rokinon 8mm fisheye to mount on my 5D mark ii.
mainly going to be used for videography and photography of fast moving BMX
any pros and cons to this lens and if so, is there a better option?
jpdunn Member 31 posts Joined Jul 2012 Location: Cairns, Australia More info | Sep 06, 2012 06:46 | #1 Hey guys, i'm looking at buying the Rokinon 8mm fisheye to mount on my 5D mark ii. http://jpdunn.daportfolio.com/
shinksma Senior Member 710 posts Joined Jul 2011 More info | Sep 13, 2012 20:21 | #2 Wow, I was searching for related stuff, and saw this orphaned post. 5DII | T3i | EF 17-40 L | EF 24-105 L | EF 24 1.4 L II | EF 28 1.8 | EF 85 1.8 | EF 70-200 2.8 L IS II | EF 100-400 L | EF-S 15-85 IS USM | EF-S 17-55 2.8 IS USM | EF-S 10-22 USM | EF 100 2.8 Macro USM | EF-S 18-55 IS | EF 35-80 III | EF-S 55-250 IS | Rokinon 8mm FE | EF 75-300 non-USM III | SMC Takumar 50mm f/1.4 | Tamron 70-210 | 430EX II | Kenko 2x MC4 and 1.4x Pro300DGX TC
NZed Member 115 posts Joined Mar 2011 Location: Victoria, Canada More info | Sep 13, 2012 22:09 | #3 If you read on B and H photo, it says the lens is made for APS-C format sensor
jblaschke Goldmember More info | Opteka has a new version--exact same optics--with a detachable hood. Still has massive amounts of vignetting on the sides of a full frame, maybe 3/4 circular, but it'll work if that's what you want. The Wife bought one to use with her 50D backup body at weddings. She played with it on her 5DII but it's not terribly pretty unless you crop heavily. Canon 7D | Canon 50D IR modified | Canon EF 70-200mm 2.8 IS L | Canon FD 500mm 8.0 Reflex | Canon EF 85mm 1.8 | Canon EF 50mm 1.8 mk I | Canon EF-S 10-22mm | Tamron 28-75mm f/2.8 | Meade 645 (762mm f/5)
Sep 14, 2012 01:02 | #5 NZed wrote in post #14988502 If you read on B and H photo, it says the lens is made for APS-C format sensor There is a new version, with a removable hood, for both but it has this warning " Rand
Sep 14, 2012 03:41 | #6 agv8or wrote in post #14989052 There is a new version, with a removable hood, for both but it has this warning " Note! Produces a circular, vignette image on full-frame sensors or 35mm film": http://www.bhphotovideo.com …8mm_f_3_5_HD_Fisheye.html There is also a new Cine version: http://www.bhphotovideo.com …m_f_3_8_Fisheye_Cine.html If you are looking for a fisheye look then I would suggest either the Canon EF 15mm fe or the Sigma 15mm fe. I have owned both and they are both very good quality. I currently own the Canon. If you are looking for just a super wide lens for the 5D II then I would go with either the 13mm Vivitar or the 14mm Rokinon. I think B&H has discontinued the Vivitar bit it can be found on Amazon while the two following Rokinons are listed on B&H. http://www.bhphotovideo.com …tra_Wide_Angle_f_2_8.html The new Cine version: http://www.bhphotovideo.com …_14mm_T3_1_Cine_Lens.html
x.pozhr Goldmember More info | Sep 14, 2012 10:28 | #7 jpdunn wrote in post #14989306 Thanks for all the feedback guys I was planning on getting the one with the detachable hood as i'm not too keen on "shaving" off the hood myself, and also canon has discontinued the 15mm FE so I decided this would be the cheaper option instead of the 8-15 L.
flickr
| Latest registered member is icebergchick 1406 guests, 153 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
