I want to try using a SDHC Wi-Fi card in a CF/SD Adapter.
But I am a little concerned that the power [volts and or current] draw might be too much for the camera's CF interface ; especially as I have seen reports of some 'Eye-Fi' getting hot.
I hope someone who is electrically trained would know if the power supply interface in the 7D's CF interface is up to it?
Appreciate there may be many who have tried it [and got away with it] but I'm more interested in a technical assessment. Or the views of someone who is electrically trained.
My concerns are:-
1. The CF Type I and II standards state:- max draw of 70mA and 500mA respectively and that the a CF card may operate on either 3.3.V or 5V - but not both at the same time.
2. The SDHC Standards are I think either 1.8V or 3.3V 'Nominal' Voltage but I can't find the SD Association''s standards for the max permissible current drain. One site suggests this might be max 200mA, with SD cards generally being between 45 to 100mA. [NB in this case this is for the card alone, i.e. without the added draw of the Adapter jacket if there is any?]
Hence my concern that a poorly designed adapter could allow the SD card to draw say 100mA out of the Type I CF card supply, which is rated at a max. of 70mA. [could account for some of these reports saying it's getting hot]. Obviously if they tapped into the 500mA source then that would be OK.
Likewise I'm not sure how they would handle the differences in voltage, hopefully they tap into the 5V source and step it down to 3.3V or a bit more.
Yet again I am a little concerned as the Toshiba FlashAir card's specs say it's 2.7V to 3.6
So if the Adapter used the CF interface's power supply of 3.3V would that be OK? or would it overload it?
More importantly I would want to use the card in 'Wireless Access Point' mode i.e. where the card broadcasts a signal for direct [not over a network] connection to an iPad or Laptop. So I guess in this mode the card would tend to be consuming more power as it has to do its job as a data card and also braodcast the WLAN signal.
Any views from the technically orientated much appreciated.
As the 7D is UDMA capable I'm hoping as this is a faster card set, that it might need a more powerful electrical supply to handle that - but then I am just guessing.
Fundamentally if there was any concern I give it a miss as I don't want to wreck my new 7D
Please don't move this thread to Accessories as its specifically related to the capabilitiy of the 7D's camera body not the SDHC card.
