Thread started 07 Sep 2012 (Friday) 00:38
Help with white balance on newly "tuned" 50D by Canon
carpenter
Gallery: 12 photos
Sep 07, 2012 00:38 |  #1
I just sent my 50D and 580EX in for repair as the flash was not firing consistently. They replaced the hot shoe foot on the flash. They also at no cost, despite being out of warranty by several years, fixed the USB port that was inoperable on the camera, and cleaned the sensor and gave the camera an overall cleaning. I got it back today and there seems to be an issue with white balance in that no matter what w/b setting I select the photos are the same. With either the 580EX II or the pop up flash I get blue hue/tint to the photos. I can cycle through all the WB settings to include AWB and each photo is identical. Shooting the same picture without flash the colors are pretty accurate, but again if I cycle through all the WB settings each photo is identical. I've looked though the settings on the camera and can't see anything that would cause this. Everything appears to be correct. Any ideas on what I can try? Thanks in Advance!
5D Mk IV | 24-105L | 85 1.8 | 70-200L 2.8 IS MkII | 100-400L MkII
rrblint
Gallery: 84 photos
Joined May 2012
Sep 07, 2012 00:46 |  #2
Don't know what could cause this in camera, but if you shoot raw, you can adjust the white balance in post processing...Not really a solution, but a workaround.
Mark
carpenter
Gallery: 12 photos
Sep 07, 2012 00:49 |  #3
rrblint wrote in post #14958269 (external link)
yeah I do shoot RAW mostly, and if needed that would work, but definitely would like to know what happened. I hate to have to send it in again and be another 2 weeks without a camera. I am about 3 weeks away from shooting fall LaCrosse as well where I won't use RAW.
Laramie
Still livin' the cowboylife
Sep 07, 2012 00:49 |  #4
I have no idea if this would change anything so I'm just throwing out ideas but did the camera get reset from Canon and changed from raw to jpeg?
5DIII | 40D | 17-40 f4L | Tamron 28-75 2.8 | 50 1.4 | 70-200 2.8L | Oly Zuiko 50 macro | Tamron 1.4x
carpenter
Gallery: 12 photos
Sep 07, 2012 00:51 |  #5
Laramie wrote in post #14958277 (external link)
All settings including CF settings were still in tact. I tried in both RAW and JPEG. Identical results. Just for the heck of it I tried changing the WB from both the WB button on the camera (with no change) and then through the menu settings just in case one or the other was wonky for some reason That didn't do anything different either.
iMAGEN ­ STUDIOS
Joined Aug 2012
Sep 07, 2012 00:52 |  #6
The only thing that i could think of is your WB shift my be shifted towards the blue spectrum. check your WB shift.
rrblint
Gallery: 84 photos
Joined May 2012
Sep 07, 2012 00:54 as a reply to  @ carpenter's post |  #7
Does the 50D have in-camera RAW processing?
Mark
carpenter
Gallery: 12 photos
Sep 07, 2012 00:56 |  #8
rrblint wrote in post #14958285 (external link)
I believe the 60D was the first.
rrblint
Gallery: 84 photos
Joined May 2012
Sep 07, 2012 01:01 |  #9
carpenter wrote in post #14958288 (external link)
Oh well...I was going to say to try a RAW exposure and then change WB around in camera on that single exposure to see what happens...But I guess not.:(
Mark
Laramie
Sep 07, 2012 01:03 |  #10
If they didn't touch the sensor and image processor, and only replaced the hotshoe and usb port, I'm trying to think of what else could have been changed or affect the WB. That's a head scratcher.
carpenter
Gallery: 12 photos
Sep 07, 2012 01:28 |  #11
Laramie wrote in post #14958308 (external link)
On the 50D paperwork it says they replaced a pcb board and adjusted focus. I will check in tomorrow. Time for bed for now
1,782 views & 0 likes for this thread, 4 members have posted to it.
2770 guests, 158 members online
