I am looking to do some pictures of my newborn in a few weeks and was looking into gettting a quality lens.
Any recommendations.
Thank you
russ925 Member 223 posts Likes: 1 Joined Dec 2011 Location: Long Island, NY More info | Sep 07, 2012 09:13 | #1 I am looking to do some pictures of my newborn in a few weeks and was looking into gettting a quality lens. T3 gripped / Tamron 17-50 2.8 / Tamron 70-300 VC / Rokinon 8mm fisheye / Canon 430EXII Flash
Sep 07, 2012 09:36 | #2 You really have what you need. A flash and a fast prime. Learn how to bounce the flash and/or pick up the Stofen Omni-bounce diffuser for it. Cameras: 7D2, S100
Brendo666 Goldmember 1,538 posts Likes: 4 Joined Dec 2010 Location: Renton, WA More info | Sep 07, 2012 09:42 | #3 What are you looking to spend? How much room do you have to work with? People normally gravitate towards the 35L for hospital room shots as there is not much working distance. And depending on the size of your house/size of your shooting area you can use any lens you want. Just like in math you have to know what you are solving for before you can start the equation. So figure out exactly what you want, how much you want to spend and how much room you have to shoot in and then find the best lens that fits your needs. -Brendan B.
Most of the shots will be done indoors , either in bedroom or 12x 12 empty room. T3 gripped / Tamron 17-50 2.8 / Tamron 70-300 VC / Rokinon 8mm fisheye / Canon 430EXII Flash
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Sep 07, 2012 10:04 | #5 russ925 wrote in post #14959544 Most of the shots will be done indoors , either in bedroom or 12x 12 empty room. Will be using some props, etc. Budget is probably round $750 -$1000 Thanks I see no reason at all to go out and buy a lens at this time. What you have will do the job very well. The 18-55 is probably the best choice for you to start with. Skip Douglas
artyH Goldmember 2,118 posts Likes: 32 Joined Aug 2009 More info | Sep 07, 2012 10:10 | #6 I'd get the 35F2 or a similar lens. This will let you take photos in low, natural light and cramped quarters. There are times when a longer lens won't work, and I don't care for flash shots of newborns.
kboater Member 195 posts Joined Nov 2011 More info | ive never used one, but sigma 30 1.4 seems to be a popular choice for indoors on a crop camera. assuming you get a good copy that is
MattD Senior Member 944 posts Likes: 39 Joined Dec 2007 Location: Norwich UK More info | Sep 07, 2012 10:12 | #8 |
A friend of mine has a 35L 1.4 that he will lend me - think I will use that and use the $$$ for the 70-200 I want. T3 gripped / Tamron 17-50 2.8 / Tamron 70-300 VC / Rokinon 8mm fisheye / Canon 430EXII Flash
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Sep 07, 2012 10:35 | #10 russ925 wrote in post #14959642 A friend of mine has a 35L 1.4 that he will lend me - think I will use that and use the $$$ for the 70-200 I want. Thanks!! You have to remember that lighting is the most critical component of good portraiture. If you're going to use your Speedlite, make sure that you bounce it off a large surface area reflector to soften the lighting. You could use white foam board or anything similar. You can even use white foam and make a large scoop-shaped reflector that you would fasten to the Speedlite (with it aimed up). Skip Douglas
Sep 07, 2012 11:19 | #11 russ925 wrote in post #14959642 A friend of mine has a 35L 1.4 that he will lend me - think I will use that and use the $$$ for the 70-200 I want. Thanks!! The 70-200 is going to get limited use, at least for children photography until they get older. I would get a 17-55 or a Sigma 17-50/2.8 now if you are using it as an excuse to spend money. But Skip is right, you don't need anything now. Babies are very easy to shoot because they don't move for 6 months or so. Canon 7D/350D, Σ17-50/2.8 OS, 18-55IS, 24-105/4 L IS, Σ30/1.4 EX, 50/1.8, C50/1.4, 55-250IS, 60/2.8, 70-200/4 L IS, 85/1.8, 100/2.8 IS L, 135/2 L 580EX II, 430EX II * 2, 270EX II.
The 70 - 200 is not for newborn photography, I had rented it a while ago and loved it ever since. T3 gripped / Tamron 17-50 2.8 / Tamron 70-300 VC / Rokinon 8mm fisheye / Canon 430EXII Flash
tkbslc Cream of the Crop 24,604 posts Likes: 45 Joined Nov 2008 Location: Utah, USA More info | Sep 07, 2012 11:38 | #13 artyH wrote in post #14959616 I'd get the 35F2 or a similar lens. This will let you take photos in low, natural light and cramped quarters. . So will the 50mm f1.8 that the OP already owns. As for "cramped quarters" they will be shooting a newborn less than 2 feet tall in a 12' room. I doubt that will be an issue. Taylor
Sep 07, 2012 12:01 | #14 I'd maybe look into a macro lens such as the 60mm. Macro shots of newborns are always nice as well. For anything wider, as others have said, you're fine. ~Steve~
schris Member 163 posts Joined Apr 2012 Location: Chicago, IL More info | Sep 07, 2012 12:05 | #15 As someone who just had a baby, I have to agree that 50mm on crop is a little awkward sometimes for baby pics. They can't sit up, which means most pictures have to be taken from above unless someone's holding the kid up for the camera. I've gotten much better shots from my 28mm lens than from my 50mm. To the OP: good luck with the 35L - be super careful with it! - and congrats on the baby. 70D | Rokinon 8mm | 15-85mm | Sigma 30mm | 85mm 1.8 | 55-250mm | 430EX
| Latest registered member is semonsters 887 guests, 133 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
