Thread started 08 Sep 2012 (Saturday) 00:07
Quick Canon 430EX II Pilot Light Question
xeodragon
Joined Aug 2011
Sep 08, 2012 00:07 |  #1
Hi everyone!
Sorry just had a quick question - I've noticed that when I turn on my Canon Speedlight 430EX II and the pilot light is on, it doesn't always shoot a test flash. It's only after a few presses of the pilot light that it'll start working. Just wanted to see if this was normal? Thanks in advance!
Nature ­ Nut
Joined May 2012
Sep 08, 2012 00:21 |  #2
If by working you mean flashing then your fine. If the pilot light is solid then that means the flash fully charged and is ready for use. Mine flash turns on and shortly there after my pilot light is on and constant. I dont shoot in rapid succession with flash so I've never had it in charging (flashing) when I was looking.
Adam - Upstate NY:
xeodragon
Joined Aug 2011
Sep 08, 2012 03:50 |  #3
Nature Nut wrote in post #14962662 (external link)
Thanks for your reply Nature Nut! What happens is I turn on my flash, my pilot light goes on, and when I want to do a "test flash" using the pilot light by pressing it, nothing happens. It's only after I keep pressing the pilot light that after maybe 3 seconds does it actually fire a "test flash". Then it'll "test flash" whenever I press the pilot light. Just wondering if that was normal.
Nature ­ Nut
Joined May 2012
Sep 08, 2012 10:12 |  #4
It takes a few seconds to charge up initially, then after that you should be able to use the pilot button for the test flash at leisure with only a quick press. The only thing I might suspect in lieu of a faulty button is maybe the batteries. I run eeneloops myself in mine so I don't know how regular batteries would respond.
Adam - Upstate NY:
xeodragon
Joined Aug 2011
Sep 08, 2012 12:39 |  #5
Nature Nut wrote in post #14963743 (external link)
I'll double check mine, thanks!
Submariner
Joined May 2012
Sep 13, 2012 04:26 |  #6
xeodragon wrote in post #14964247 (external link)
I think I did read a critisism somewhere of the 430EXII that you have to press the red illuminated button quite firmly to get the test flash. Mine is OK but I wouldn't say it was perfectly easy. Try pressing it very 'definitely' and see if it fires.
Personally I wasnn't too bothered as I test fire it off the camera test button.
Canon EOS 5DS R, Canon EF 70-200 F2.8 L Mk II IS USM, Canon EF 70-300 F4-5.6 L IS USM, EF 40mm F2.8 STM , RC6 Remote. Canon STE-3 Radio Flash Controller, Canon 600 EX RT x4 , YN 560 MkII x2 ; Bowens GM500PRO x4 , Bowens Remote Control. Bowens Pulsar TX, RX Radio Transmitter and Reciever Cards. Bowens Constant 530 Streamlights 600w x 4 Sold EOS 5D Mk III, 7D, EF 50mm F1.8, 430 EX Mk II, Bowens GM500Rs x4
apersson850
Sep 13, 2012 07:32 as a reply to  @ Submariner's post |  #7
The flash' test fire button doesn't work until enough time has passed since you half-pressed the trigger button last time. Normally six seconds later it will be OK, which probably is when you have pressed the pilot light/test switch three times.
Anders
9,007 views & 0 likes for this thread
Latest registered member is rondimar
1058 guests, 343 members online
