I just received my Dell U2410. It is amazing monitor and the colors look great. How many of you still calibrate the monitor?
chenga732 Senior Member 465 posts Likes: 4 Joined Jan 2011 More info | Sep 08, 2012 11:08 | #1 I just received my Dell U2410. It is amazing monitor and the colors look great. How many of you still calibrate the monitor? Xsi|24-105mm f4.0|70-200mm f4.0|85mm f.18
Sep 08, 2012 12:37 | #2 Most people see over-bright and over-saturated colors and say "that looks great", even though its not accurate. I would calibrate any monitor.
Sep 08, 2012 23:35 | #3 I've never calibrated my monitor, and I just received a Dell UltraSharp U2412M a few days ago. Craig5D4|50D|S3iS|AF:Canon 28-135 USM IS|MF:Tamron SP 28-80|Tamron SP 60-300|Soligor 75-260|Soligor 400|Soligor C/D 500|Zuiko 50 f/1.8|others
Sep 08, 2012 23:48 | #4 SkedAddled wrote in post #14966256 Read some reviews and adjustment guides about your new monitor, adjust it accordingly, and you can then dismiss mike_d's knee-jerk elitist comments, most likely.
Sep 08, 2012 23:53 | #5 Uh-huh. Craig5D4|50D|S3iS|AF:Canon 28-135 USM IS|MF:Tamron SP 28-80|Tamron SP 60-300|Soligor 75-260|Soligor 400|Soligor C/D 500|Zuiko 50 f/1.8|others
Sep 08, 2012 23:57 | #6 SkedAddled wrote in post #14966304 Uh-huh. So I'm an elitist for saying that monitors should be calibrated for color accuracy?
Sep 08, 2012 23:59 | #7 If you really care about color and tones you need to calibrate any monitor. http://www.colorblindedphoto.com
Sep 09, 2012 00:06 | #8 mike_d wrote in post #14964237 Most people see over-bright and over-saturated colors and say "that looks great", even though its not accurate. I would calibrate any monitor. mike_d wrote in post #14966311 So I'm an elitist for saying that monitors should be calibrated for color accuracy? OK. ![]() Nope. Craig5D4|50D|S3iS|AF:Canon 28-135 USM IS|MF:Tamron SP 28-80|Tamron SP 60-300|Soligor 75-260|Soligor 400|Soligor C/D 500|Zuiko 50 f/1.8|others
bigpow Senior Member 708 posts Likes: 15 Joined May 2002 More info | Sep 09, 2012 00:34 | #9 Plenty of monitors have pro color calibration performed at the factory, but none of them are anywhere near the price of a Dell 2410. [5DM2: 50L, 100L, 24-105L, 70-200/2.8IS L II, Zeiss 2/35 ZE]
Sep 09, 2012 01:19 | #10 SkedAddled wrote in post #14966336 Nope. You're an elitist for suggesting that no monitor could ever be accurate without calibration. And how would you know it were accurate without calibrating it? Even a factory-calibrated monitor isn't going to stay calibrated forever.
hihohito Member 225 posts Joined Oct 2010 More info | Sep 09, 2012 02:28 | #11 mike_d wrote in post #14966503 And how would you know it were accurate without calibrating it? Even a factory-calibrated monitor isn't going to stay calibrated forever. If you don't print your photo's you don't need to calibrate your monitor. They look off color on other monitors but maybe that's not important to him.
elogical Goldmember 1,217 posts Joined Aug 2010 Location: St Paul, Minnesota More info | Even if you don't print them, what about the colors other people see when sharing photos online, etc? What if your brightness was set too high without realizing it and your photos are losing detail when viewed by others? What if your colors are shifted? There's no way to know.
p6889k Member 225 posts Likes: 1 Joined Sep 2009 More info | Sep 09, 2012 10:10 | #13 I can see how many can be satisfied with just factory calibration settings or simply adjusting the monitor by eye. Not everyone has the same demands. Yet at the same time, there's no way to have correctly calibrated monitor without actually using a calibrator. Even very high end monitors need to be custom calibrated to be accurate and then re-calibrated periodically. Spending even $100 for a cheap HW calibrator can make a big difference. Regarding U2410, I would be especially concerned about its factory sRGB emulation - I would certainly recommend a HW calibrator that can handle wide gamut monitors - e.g. the excellent I1 Display Pro. I believe the regular Spyder calibrators have problems with wide gamut monitors. 5D IV, EOS-1V
happy2010 Looking for the light first 559 posts Likes: 99 Joined Feb 2011 More info | Sep 09, 2012 11:03 | #14 To calibrate or not to calibrate – obviously your choice. I definitely recalibrate periodically as I want consistency in all my images be it for: monitor viewing, communicating via email or internet, or printing from my own printers or outsourced subcontracted printer organizations (all of which I have found has slightly different results without calibration). MARY
Sep 09, 2012 11:54 | #15 hihohito wrote in post #14966645 If you don't print your photo's you don't need to calibrate your monitor. They look off color on other monitors but maybe that's not important to him. I print my pictures and want them to be as I see them on my monitor. So I calibrate my monitor every 14 day's. I don't happen to agree with this. Yes, it's true that a very small minority of the people in the world have calibrated their monitors and probably a smaller group have a monitor that even when calibrated will do a decent job of displaying a meticulously prepared image. http://www.colorblindedphoto.com
| Latest registered member is semonsters 1505 guests, 137 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
