I just received my x-rite Colorchecker Passport and could use some help creating custom DNG profiles. Here's what I've done:
1. Set a custom white balance for the scene. Not a requirement for making a custom profile according to x-rite, but doesn't hurt either.
2. Shot an image outdoors in sunlight (no clouds) using sunny 16 (f/16, ISO 200, 1/200s) to ensure good exposure. The histogram for the resulting image is decent.
3. Brought the RAW file into ACR and created a DNG.
4. Dragged the DNG into the window on the Colorchecker Passport software and created the custom profile.
The problem is that when I go back into ACR with an image of the Colorchecker Passport and try different profiles on the calibration tab, Adobe's "Camera Neutral" profile seems to match some of the actual color swatches better than the new profile created using the x-rite software.
I then downloaded the Adobe DNG Profile Editor (beta 3) and created a custom profile using that software using the same DNG image used for the x-rite software. The result is a bit different and appears to be slightly closer for some of the actual color swatches than the one created by the x-rite software, but off on others. Following are my results. I'd really appreciate knowing from the color gurus here which one looks to be the closest match to the Gretag Macbeth color swatches. To me none of them do a great job.
Using profile created by Colorchecker Passport software:
Using profile created by Adobe Profile Editor (beta 3): *** Edit **** Removed since I screwed up and was in dual illuminant mode. The image produced using Adobe DNG Profile Editor is identical to the one produced by the x-rite software (see post 4 and 5 below).
Using ACR's Camera Neutral profile:
