Thread started 23 Dec 2005 (Friday) 22:19
What is Infrared Index?
chakras
Joined Jun 2005
Dec 23, 2005 22:19 |  #1
Going through the manual for my newly acquired EF70-200mm f/4L, what is Infrared Index? Manual mentions it relates to IR film, but does it have any significance when using a IR filter?-?
Suvendra
PacAce
Joined Feb 2003
Dec 23, 2005 23:10 |  #2
The IR index is the mark at which objects focus when shooting infrared using an IR filter. Ordinarily, if you have an object sitting, say, 20 feet away from the film (sensor) plane, you would align the 20 ft. mark on the lens to the focus index mark. However, if you are shooting IR, then you have to align the 20 ft. mark to the IR index mark.
...Leo
chakras
Joined Jun 2005
Dec 24, 2005 01:25 |  #3
Thanks for your clarification, Leo. But I am still kind of confused. Ideally, I would be turning the focussing ring to get the best possible focus. Now, if I rotate the ring to set this distance to IR mark, won't the image be OOF? ???
Suvendra
tiha
Dec 24, 2005 05:59 as a reply to  @ chakras's post |  #4
Light refracts differently depending on wavelength and the focal length of your lens (and therefore the proper focus setting) depends on it. That's why you need to shift focusing point to IR index marked on the lens. Image in the viewfinder, which is result of visible light, will look OOF, but recorded image produced by IR light will be sharp. That was procedure back in film camera days. I guess it is the same for digital.
EOS 5D, EOS 30D, EOS 3, PowerShot G6
EF 50mm f/1.4 USM, EF 85mm f/1.8 USM, EF 100mm f/2.8 Macro USM, TS-E 90mm f/2.8, EF 15mm f/2.8 Fisheye, EF 70-200mm f/2.8L IS USM
Speedlite 580EX, Speedlite 430EX, Macro Ring Lite MR-14EX, Transmitter ST-E2
PBase: http://www.pbase.com/v​_tihomir (external link)
sdommin
Joined Dec 2002
Dec 24, 2005 09:15 as a reply to  @ chakras's post |  #5
It might appear that way, but visible light and infrared light focus at different points. Since you can't see infrared light, you really can't tell if the infrared image is in focus or not. Ideally, you would focus on something with no filter, then move the focus ring to the IR mark, attach your filter and take the picture (its very hard to see, much less focus, through the viewfinder when an IR filter is attached).
As a practical matter, you can usually ignore this whole thing altogether. Most infrared shots are wide-angle landscapes with small apertures, where the slight difference in focus will be taken care of with DOF.
Scott
http://www.pbase.com/s​dommin/favorites (external link)
chakras
Joined Jun 2005
Dec 24, 2005 11:55 |  #6
Ah... that makes sense. :D Thanks for clarifying.
Suvendra
2,845 views & 0 likes for this thread, 4 members have posted to it.
1779 guests, 133 members online
