FORUMS Photography Talk by Genre Macro Talk
Thread started 10 Sep 2012 (Monday) 18:08
Canon MT-24EX or Macro Bracket?
General_T
Joined Aug 2011
Sep 10, 2012 18:08 |  #1
Hi,
Trying to determine if I would be better served by spending $800 dollars now for a MT-24EX or spend $300 dollars for a cable flash and macro bracket?
I'm worried that if I fork out the $300 now I may lose on that if I upgrade to the MT-24EX later? Would it be better to get the MT-24EX now?
Is there any real advantage to the MT-24EX or a bracket? I know the MT-24EX has variable light output (also needs an adapter for the 100L - nice oversight Canon!).
I'm new to macro - but always hate buying something that I will end up upgrading in the not to distant future.
Thanks for your thoughts.
TB
Canon 5D Mk III | 24-105 F4 L IS USM | 100 F2.8 L Macro IS USM | 70-200 MK II F2.8 L IS USM|580 EX II
ceriltheblade
Sep 11, 2012 01:14 |  #2
are you aiming to shoot up to 1:1 with the 100 macro? more? less?
just remember that if you are buying a mt ex 24 to mount on the 100L, you will also need to get a macrolite 67c adapter ring which is not included with the flash.
7D/5dIII
50 1.8 II, MP-E65, 85 II, 100 IS
8-15 FE, 10-22, 16-35 IS, 24-105, 70-200 f4IS, 100-400 ii, tamron 28-75 2.8
600 ex-rt, 055xproB/488rc2/Sirui k40x, kenko extens tubes
General_T
Joined Aug 2011
Sep 11, 2012 08:35 |  #3
ceriltheblade wrote in post #14975349 (external link)
Hi,
Yes. 1:1 macro as well as using it for general photography.
I thought the adapter was included with the purchase of the MT-24EX?
TB
ceriltheblade
Sep 11, 2012 08:55 |  #4
while i do not have the mt ex 24, nor the 100L - i think it can be safely said that at this point you can get macro bracket (for a lot less than $300 BTW) and try it out before splurging. Look on the boards for the RAM mount - i forgot which thread it is in - as one of many examples
there are those who would suggest that using the mt ex 24 on "solely" 1:1 is less than optimal and there are planty of examples of posters using their regular flashes. Look up LordV's kit in the thread of macro rigs or many others and the plenty of fine examples that it can bring.
With that said - many people are more supportive of the macro dual flash for 2-3:1 and more for many reasons - both ergometrics as well assome of its features (e.g. modelling light).
Anyway, the mt ex 24 can mount without additional adapters to the 100 non L USM and the mp-e-65each of which has a filter size of 58mm. the 100 IS L needs the macrolite adapter (available in adorama and B&H if not many other places)
hope this helps
7D/5dIII
LordV
Sep 12, 2012 00:54 |  #5
Agree with above- think a bracket mounted normal flash is probably better than an MT-24 for upto 1:1 shooting. The MT-24 comes into it's own with the MPE-65.
Brian v.
Macro Hints and tips
General_T
Joined Aug 2011
Sep 12, 2012 19:19 |  #6
Hi,
Thanks for the replies.
Was looking at the Wimberley macro brackets, but when I add up all I would need (F-2 macro bracket / M-8 Perpendicular plate /P-5 Camera plate) it comes to $306 bucks and then I have to add on the remote cable - another $100+ dollars. So I am already half way to the MT-24EX.
Will have to keep looking for a cheaper alternative - maybe one of those pringles cans?:lol:
ceriltheblade
Sep 14, 2012 01:30 |  #7
the RAM mount details can be seen
http://forums.dpreview​.com …orum=1025&threa​d=22089389 (external link)
though indeed the pringles can is cheaper and - a bit tastier :)
7D/5dIII
chrisa
Gallery: 132 photos
Sep 14, 2012 08:35 as a reply to  @ ceriltheblade's post |  #8
I have a ram mount set up, I think a smaller canon flash would be better though, maybe the new 90EX. I have a 430 on mine and it's a bit cumbersome at times.
General_T
Joined Aug 2011
Sep 15, 2012 11:24 |  #9
Hi Ceriltheblade and Chrisa,
Do you screw the 1" ball directly into the camera base or onto some sort of connector. Unfortunately the pictures are no longer avail at that link.
Does this give enough length to get the flash all the way to the front of the lens?
How do you connect the flash (580ex) to this?
Any chance of a picture of your setup to see what it looks like?
TB
chrisa
Gallery: 132 photos
Sep 16, 2012 16:00 as a reply to  @ General_T's post |  #10
PHOTOBUCKET EMBEDDING IS DISABLED BY THIS MEMBER.
Photobucket sends ads instead of embedding photos from their free galleries.
Click the link (if available) below to see the image in a gallery page.
http://i111.photobucke​t.com …14976f73b5e52dd​72379d.jpg (external link)
General_T
Joined Aug 2011
Sep 16, 2012 16:15 |  #11
Hi Chrisa,
thank you for the picture. I see you have some sort of bracket to attach the Ram to. I guess I will call them on Monday to see what they may have to attach to the camera.
chrisa
Gallery: 132 photos
Sep 16, 2012 16:43 as a reply to  @ General_T's post |  #12
It' s just a piece of aluminum that I bent and drilled holes in.
chrisa
Gallery: 132 photos
Sep 16, 2012 16:49 |  #13
A better pic
http://i111.photobucke​t.com …592e60e3b61a31a​d1f44c.jpg (external link)
Seapup
Joined Aug 2012
Sep 17, 2012 08:52 |  #14
chrisa wrote in post #14999801 (external link)
A better pic......
^^^ Sweet setup!
IMAGE: http://seapup.com/Web_Tools/thumbsup2.GIF
Canon 5D2 | 60D | A620 | SD850 IS | SD4000 IS
Canon 10-22 f/3.5-4.5 | 17-55 f/2.8 IS | 50 f/1.4 | 100 f/2.8L Macro IS | 70-200 f/2.8L IS II | 100-400 f/4.5-5.6L IS
ceriltheblade
Sep 19, 2012 07:17 |  #15
an additional note:
I have used this with the screw from the ball coming out of one of those plastic ebay tripod rings and it worked realtively well an even coming from the tripod screw under the camera. I like that possibility less because the camera then cannot sit flat, but in a pinch - it worked.
Chrisa I see used a different piece of the ball and screw (Chrisa's has the plate), mine on the other hand, is just a ball with a 1/4-20 screw extruding from it. Just a factual difference.
good luck with yours, if you so decide to go in that direction.
7D/5dIII
6,802 views & 0 likes for this thread
Latest registered member is rush1981
784 guests, 347 members online
