Thread started 24 Dec 2005 (Saturday) 08:19
Any tricks to getting a filter off a lens?
d_rafferty
Dec 24, 2005 08:19 |  #1
I have a Quantaray 100-300mm (junky I know but it's my backup lens)
The lens took a little fall, the uv filter chipped inside and there is a piece of the UV filter glass floating inside. The lens works fine but I cannot get that darn filter unscrewed!!! I have tried wrapping a rubber band around the filter only but it still won't come off.
Is there a secret trick to get it off???
Donna
Canon EOS Digital Rebel
Canon EF 75-300mm f4.5-5.6 IS USM
Canon 18-55mm f 3.5-5.6
Canon Speedlite 420EX
Canon RC-1 remote
Canon Powershot A75
sdommin
Joined Dec 2002
Dec 24, 2005 09:03 |  #2
Its going to be difficult if you bent the outer ring of the filter or lens. Try using one of those round, flat pieces of rubber that they sell for loosening jar lids. If it doesn't come off fairly easily, you might need to send your lens somewhere for repair.
Scott
http://www.pbase.com/s​dommin/favorites (external link)
jaypie77
Joined Aug 2004
Dec 24, 2005 09:45 |  #3
I had this problem once and basically, I just kept trying and trying until it worked. It is important for you not to put direct pressure on any lens components though, so be careful. Just be persistent. If worst comes to worst, crack the filter carefully and use plyers to remove the ring. Or you could use a dremel tool.
SkipD
Joined Dec 2002
Dec 24, 2005 09:50 |  #4
Worst case scenario - break the filter glass (very carefully, of course) and then slice through most of the filter's threaded ring using either a very fine (jeweler's or razor) saw or a Dremel tool with a carborundum cutoff wheel. Then use a small but rugged pair of pliers to start bending the filter's ring inwards (towards the center of the lens) at the cut. Once you get it started, you can complete the cut and just pull the ring out. You may find that you also damaged the lens' filter threads.
Skip Douglas
malla1962
Joined Jul 2004
Dec 24, 2005 10:05 as a reply to  @ SkipD's post |  #5
Buy a filter clamp.:D
gasrocks
Dec 24, 2005 10:43 as a reply to  @ malla1962's post |  #6
Put a rubber band around the filter, don't let it overlap onto the lens itself and twist it off.
Eagle
Gallery: 62 photos
Dec 24, 2005 11:38 as a reply to  @ gasrocks's post |  #7
Never tried this but get one of them plastic cable ties. Put a rubber band around the filter then the cable tie, then you may get more leverage pulling the end of the cable tie. That is if this makes any sense to you. Just be sure you are just grabbing the filter and are turning it the right way. Lefty Loosy, Righty Tighty.
7D MKII ■ 10-22 ■ 15-85 ■ 28-135 ■ Σ 50-150 ■ 70-200 f4L ■ 100-400L ■ 580EX II
Gear-PCSmugMug (external link) ShutterStock (external link) Alamy (external link) Eagle's Nest Photography (external link)
Mark_Cohran
Joined Jul 2002
Dec 24, 2005 11:55 |  #8
A filter clamp (a specialized tool) is the safest bet. Take it to a camera repair shop and they'll remove if for you for free (or for a very nominal fee).
Mark
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Forty years of shooting and still learning.
My Twitter (external link) (NSFW)
Follow Me on Instagram (external link)
foxbat
Joined Jan 2005
Dec 24, 2005 14:06 |  #9
Can you leave it somewhere very cold e.g. under an air con unit set to its coldest setting? This happened to me and it was because the filter was made of a different material to the thread and the thread expanded in hot weather.
Andy Brown; South-east England. Canon, Sigma, Leica, Zeiss all on Canon DSLRs. My hacking blog (external link).
JohnCollins
Joined Nov 2005
Dec 24, 2005 14:14 |  #10
I had this trouble on a lens where the filter hadn't been off in 25 years. I put a thick rubber band on it and used a large channel lock pliers very carefully of course, and that worked.
pfogle
Joined Dec 2004
Dec 24, 2005 14:40 |  #11
Easy and foolproof - screw something big, like a lens hood, into the front of the filter, not too tight, and then tape it on to the filter with a strip of gaffer tape. Make sure the tape doesn't stick to the lens. Now you've something BIG to grip when you turn it.
Phil Fogle
5Dmk2; Zenitar 16mm, 17-40 f4L, 50 f1.4, Samyang 85 f1.4, 70-200 f4L
cspratt
Joined Mar 2004
Dec 24, 2005 17:27 |  #12
Strange but true - Try to "tighten" it a tad before trying to undo it with the above mentioned remedies. Tighting it slightly can help to "unfree" it.
Chris. Spratt
Victoria, BC
In the game of life, Mother Nature bats last. Happy ninth inning.
armelec
Dec 25, 2005 03:31 as a reply to  @ Eagle's post |  #13
damn it i thought i made that up..
no one else i know uses it lol
lefty loosy righty tighty
1dmk2
sum lenses
flash
laptop
and a great 900w microwave
rklepper
Dignity-Esteem-Compassion
Joined Dec 2003
Dec 25, 2005 09:56 |  #14
Filter wrench.
Doc Klepper in the USA
I
zebedee
Dec 25, 2005 14:11 |  #15
Cant remember where I saw this tip, but wear a washing-up rubber glove and position the filter in the palm of your hand. Never neaded to try it myself, but it sounds as though it might help get more grip on it. Good luck.
EOS20D
Canon EF 18-55mm, Canon EF 75-300 f/4-5.6 USM
Sigma 10-20 F4-5.6 EX DC HSM, Sigma 18-50 F2.8 EX DC, Sigma 70-200 F2.8 APO DG HSM, Sigma 80-400mm F4-5.6 EX APO OS DG
RSP, Paint Shop Pro 8, Adobe Photoshop CS2
4,109 views & 0 likes for this thread, 19 members have posted to it.
2000 guests, 126 members online
