lannes wrote in post #14978321
It's always the CF card that it is to blame, the cheaper brands have lower manufacturing tolerances and quality control, so there is a greater chance of bending pins in the CF slot. Pay a bit extra for the well known CF card brands and you can protect against this problem
Don't really understand how a card reader can damage a card unless it wore away it's guides creating some play when it was slotted into another unit ?
I don't know if it's "always" the case, but I suspect lower quality cards are the problem at least some of the time. I've seen examples of cards on the Internet, that have poorly formed sockets on the end and caused problems.
Knock on wood, I've made literally hundreds of card changes over the years in a lot of different cameras and in/out of various readers, and never bent a pin myself. Maybe it's just good luck or because I mostly use good quality cards (mostly Sandisk or Lexar).
The only place I have any trouble is an Expresscard CF reader that I use with my laptop. It's a bit tricky to get the card lined up... but it's very fast downloading so I put up with it when I need to download on location.
Inspect the socket closely with a flashlight if you suspect a bent pin. Look for any sign or an electrical short.... that can happen if the bent pin grounds ouot onto something it shouldn't. I've got a dead Digital Rebel/300D I bought for a few bucks to try to fix, the only problem with it was a bent pin. But it's going to get used as a CLP trade in now because I found out pretty quickly that the pin shorted out something. There's obvious signs of that around the pin and circuitry.
If it's just a bent pin, you might be able to straighten it yourself. It has to be pretty much perfect, though, or it will simply bend again the next time you insert a card. If there has been a short, chances are it will need professional attention and some components replaced.
