While shooting football for the local news paper last week my 300 2.8 started having focusing issues. The problem is intermittent and AF will in most cases start working again if the focus ring is activated or if you lightly tap on the side of the lens. I am wondering if it’s a possible connection issue at the AF motor or a motor going out. The lens is an older unit with a date code of UJ1223.
Can anyone recommend a lens repair facility in the US that still works on these older lenses that are no longer supported by Canon. I think the lens could be repaired from a technical standpoint however the big issue will be parts availability.
Unfortunately I was just getting ready to add some new equipment possibly the 1D X or the 400 2.8, however it looks like I will be replacing the broken 300 2.8 instead of adding the additional gear. If anyone can recommend a lens repair facility I would certainly appreciate the input.
