I use the Image Processor in Bridge (CS6) to create jpegs after I process the RAW's in ACR. It opens and works thru PS. Lately I've been trying out the Export to Hard Drive in Bridge. It seems to work a little faster, doesn't open PS, with pretty much the same options. I have noticed that a few, not all, of the file sizes will be slightly different depending on which of the two methods I use. The only other difference that jumps out is using Image Processor tags them with 300 ppi where the Export doesn't which shouldn't matter. Does anyone know if these two methods are basically the same as far as results? Any advantage of using one over the other?
