Thread started 11 Sep 2012 (Tuesday) 14:20
Canon E-145C Lens Cap for EF 300mm f/2.8L IS II
Jahled
Sep 11, 2012 14:20 |  #1
Any of you guys know if this fits the EF300L version I?
I hate the leather cap of the original model, and use a Lenscoat replacement, but this doesn't work if you travel with the hood reversed.
Many thanks if any of you can help :)
James
Snow Leopards of Leafy London- The magic begins 5th November 20:00 hours on Animal Planet :) | Gear
Canon ­ Bob
Sep 11, 2012 14:30 |  #2
There was a similar thread on FM last month asking the same question and the answer was "yes".
Bob
1Dx2 (2), 5DSR, 1Ds3, 1D4, 5D2(590nm), 5D2(720nm) EF600 EF400 EF300-II EF300 EF200 EF200-II EF180L EF135L EF100 EF85-II EF50L TS-E17/4 TS-E24L-II TS-E45 TS-E90 MP-E65 EF70-200-II EF24-70/2.8-II EF16-35/4 EF8-15/4 EF11-24/4 Zeiss 15/2.8 21/2.8 25/2 28/2 35/1.4 35/2 50/2 85/1.4 100/2 135/2 T/C's L-SC & a WIFE!
Jahled
Sep 11, 2012 14:37 |  #3
Canon Bob wrote in post #14977533 (external link)
Bob
Ah nice one mate :)
James
Jahled
Oct 26, 2012 16:39 as a reply to  @ Jahled's post |  #4
Anyone aware of a third party copy that doesn't cost eighty quid like the official Canon Canon E-145 C Lens Cap?
Canon take the biscuit some times :eek:
James
RAW ­ RAW ­ RAW
Joined Mar 2011
Oct 26, 2012 18:47 |  #5
I have one of these www.donzecklenscap.com (external link) I got it with my 300 MK II when I brought it used. They are a bit expensive but what the hell, its a great cap and works perfectly. I am happy to recommend it as far as function and quality are concerned, only you can decide if its worth the money.
Cheers, RAW
edit; The cap is very well built, it fits perfectly and is practically bullet proof.
Jahled
Oct 26, 2012 18:50 as a reply to  @ RAW RAW RAW's post |  #6
have one of them, hoping for better coverage
But thanks :)
James
RAW ­ RAW ­ RAW
Joined Mar 2011
Oct 26, 2012 18:58 |  #7
Better coverage? This cap covers the lens. Can you explain what you mean?
Jahled
Oct 26, 2012 19:06 as a reply to  @ RAW RAW RAW's post |  #8
I want a hood over the entire lens when it's off on it's travels.
A very weird question
James
RAW ­ RAW ­ RAW
Joined Mar 2011
Oct 26, 2012 19:12 |  #9
My apologies, I thought you wanted a replacement lens cover. I use the case but it is bulky. I would suggest getting some neoprene wet suit material and some velcro and making exactly what you want. My guess is that will be quicker, cheaper and easier that trying to find something already made.
bmw-slangen
Joined Mar 2013
Mar 20, 2013 17:33 |  #10
Bob
I have a similar question, but with a twist.
I have the 300 2.8 L USM (the NON-IS) lens, and my question is - does the E-145C fit on my lens?
As far as I understand these are the different accessories, see below. Based on the numbers, the E-145C might fit but have a somewhat loose fit on my 300 2.8 NON-IS lens. Anyone tried?
EF 300 2.8 L USM
- lens cap E-137
- lens hood ET-118 / ET-118 II
EF 300 2.8 L IS USM
EF 400 4.0 DO IS USM
- lens cap E-145
- lens hood ET-120
EF 300 2.8 L IS II USM
- lens cap E-145C
- lens hood ET-120(W II)
AntonLargiader
Feb 25, 2023 18:26 |  #11
Old thread but I'm looking for a lens cap for my 300 IS. Most of them seem way too expensive.
The Hoodie actually seems like a great solution. They recommend the XX Large for this lens; the lens hood is 5.75" diameter on each end so it's right in the middle of the stated range of 5.5 to 6.25 whether the hood is normal or reversed. It's not clear to me if the cover has a notch to fit over the hood clamp, but for $17.50 I can make a hole if it needs one.
Without the hood the lens is about 5.25" so if you want to carry the lens that way you might want to try the X Large, which has a stated diameter range of 4.75-5.25.
I suppose a potential downside to the Hoodie (and an advantage for the Etsy product) is that the hoodie may be flexible enough to be pushed in and contact the front element which is 3/4" recessed from the front rim of the lens.
Image editing and C&C always OK
Gear list plus: EF 1.4X II . TT1/TT5 . Bogen/Manfrotto 3021 w/3265 ball-mount
5,144 views & 0 likes for this thread, 5 members have posted to it.
1301 guests, 135 members online
