Thread started 11 Sep 2012 (Tuesday) 17:32
FoCal, what version do you suggest?
pyro1
Gallery: 93 photos
Joined Feb 2012
Sep 11, 2012 17:32 |  #1
I don't know if I really need this, but since I got my 70-200 f/2.8L II, I'm not sure that it doesn't need to be micro adjusted a bit. It just seems a little soft compared to my other L lenses.
It seems like using this software to do the micro adjust on all my lens would be the best way to make sure they all are set up right with my 5dMKII.
What are your thoughts & experience with this software and micro adjusting your lens? Thanks for your suggestions.
jeff
1DX MKIII, Twin 1DX, 5D mk III - EF 16-35 f/2.8L II USM - EF 24-105 f/4L IS USM - EF 70-200 f/2.8 L IS USM II - EF 100-400 f/4.5 L IS USM - EF 100 f/2.8 L Macro IS USM - EF 85mm f/1.2 L II USM - Tam 24-70 f/2.8 Di VC - 580EXII - Einsteins & CyberSync System - Vagabond Mini -
My smugmug (external link) My Facebook (external link)
doidinho
Sep 11, 2012 17:55 |  #2
I bought the software a few months back and used it on all my lenses. It's fast, accurate, and the results are reproducable. IMO everyone that has a supported camera and isn't shooting to have everything from the foreground to background in focus should use the software. There was an extended discount offered a while back; you may want search around and see if it's still active.
Robert McCadden
My Flickr (external link)
MM (external link)
5DMKII, Rebel xti, 24-105 f/4L, Canon 70-200 f/4L, Canon 17-40.
DDL
Sep 11, 2012 19:22 |  #3
I went for the PRO version to get the extra bells and whistles; a PDF report showing the before/after test results with actual screen shots at different MA values, being able to compare results at different aperatures, etc.
It gives great consistent results in a much shorter time frame that also take my eyeballs out of the equation (which are unfortunately required when using LensAlign Pro, etc.).
However, for some lenses I found that the MA at 50FL (regardless of method used) gives blurry results at longer subject distances so you should test at varying distances to see if there is a focus shift and what the best compromise over near to far would be. Or if you know at various focus distances what the MA is then you can change to be closer for the distance you need to shoot a lot at.
Highly recommended!
DDL
GearList
svassh
Joined Dec 2011
Sep 11, 2012 20:56 |  #4
Great product, if all you want to do is MA I would consider the Plus version. Quite a bit less as I recall and they will let you upgrade in the future for only the price difference to the Pro if you find you need more.
Samsung NX1, NX 500, 16-50S, 50-150S, 12-24mm, 45 1.8
MMp
Gallery: 46 photos
Sep 11, 2012 21:24 |  #5
What exactly does the Pro version gain?
I have the LensAlign Pro, but I feel like the size of the target is too small to do the tests at the recommended 25x-50x focal length. I don't get very consistent results.
With the impending forum closure, please consider joining the unofficial adjunct to the POTN forum, The POTN Forum Facebook Group (external link), as an alternate way of maintaining communication with our members and sharing/discussing the hobby.
pyro1
Gallery: 93 photos
Joined Feb 2012
Sep 11, 2012 22:21 as a reply to  @ MMp's post |  #6
Well, I made the jump. I figured for what I have tied up in glass, I'd go with the Pro version. Downloaded and installed. I'll post some results when I have the tiem to set it up and give it a go.
Jeff
MMp
Gallery: 46 photos
Sep 11, 2012 22:24 |  #7
pyro1 wrote in post #14979509 (external link)
Jeff
I'm reading mixed reviews on how reproducible the results are. Looking forward to see how you make out.
Canon ­ Bob
Sep 12, 2012 03:07 |  #8
mannetti21 wrote in post #14979518 (external link)
I would imagine that if we're all using the same software, controlling the same range of cameras and lenses then we should all be able to attain the same level of consistency....as far as the utility goes.
If it works well for some and not for others then it would seem to suggest an external influence....tripod stability, lighting quality or user setup.
I've used it on a whole raft of lenses on 5 different bodies and only found one combination that is inconsistent.....and even that inconsistency is consistent!
Bob
1Dx2 (2), 5DSR, 1Ds3, 1D4, 5D2(590nm), 5D2(720nm) EF600 EF400 EF300-II EF300 EF200 EF200-II EF180L EF135L EF100 EF85-II EF50L TS-E17/4 TS-E24L-II TS-E45 TS-E90 MP-E65 EF70-200-II EF24-70/2.8-II EF16-35/4 EF8-15/4 EF11-24/4 Zeiss 15/2.8 21/2.8 25/2 28/2 35/1.4 35/2 50/2 85/1.4 100/2 135/2 T/C's L-SC & a WIFE!
pyro1
Gallery: 93 photos
Joined Feb 2012
Sep 12, 2012 05:15 as a reply to  @ Canon Bob's post |  #9
After reading everything last night, I really believe it's consistency depends entirely on our consistency, mainly lighting & doing everything precisely the same way each time.
I look forward to setting it up and giving it a go.
cueball
Sep 13, 2012 18:26 |  #10
Just ordered the Pro version last week for my birthday. Finally got a chance to use it with my 5D3 this evening and it worked wonderfully. My two primes have just always seemed to fall a little short since I got the 5D3 and after tonight I know why. Ran each lens through twice with the "Many" settings and target validation. Results came out with a consistent -6 for my 28 f1.8 and -9 for my 85 f1.8. The target shots on the 85 in particular were night and day.
I also did my 24-105 and it showed +2 on the short end and +3 on the long end. I will do the 70-200 tomorrow and then all four lenses with my 1D3 (although the zooms will have to be averaged). I'm going to try and play around with the other tools it offers this weekend. The PDF printout is great to go back and view your results from different tests. Definitely worth the money IMO.
Canon: 5D Mark IV, EOS R, 35 f1.4L II, 85 f1.4L IS, 16-35 f4L IS, 24-70 f2.8L II, 70-200 f2.8L IS II, 100-400 f4.5-5.6L IS II, 100 f2.8L IS Macro, 2X III, 1.4X III, 580EX II, 430EX
Feedback: https://photography-on-the.net …=12723614&postc​ount=27889, https://photography-on-the.net …=13303433&postc​ount=30051
n1as
Sep 13, 2012 18:37 |  #11
I recommend not using the SW. I bought it and achieved worse results than with my manual MA procedure. The FoCal SW took many, many frames then reported that the lens wasn't consistent enough to be adjusted.
I've have great results with a tripod, focus target, tape measure and computer to review the images.
My copy of FoCal sits unused. I wish I had saved the $50 and not bought it.
- Keith
http://darwinphoto.zen​folio.com (external link)
cueball
Sep 14, 2012 08:35 |  #12
Was your lighting in the recommended range while testing? Mine dropped/fluctuated in the middle of one of the tests. FoCal warned me once about the light but I was stubborn and continued. Then the focus results weren't what the software expected so it threw another warning. I provided more light for the target and everything worked perfectly afterwards.
Bikeboyjr
Sep 14, 2012 09:07 |  #13
Has anyone bought the software to then find out that their lenses didn't need MA or it was very minor +/- 1? That's my fear, I spend the ~$75 hoping my lenses are sharper, to then find out that they are already as sharp as they get...
80D | 24 f2.8 EF-S STM | 50 f1.8 STM | 10-22 f3.5-4.5 EF-S | 17-55 f2.8 EF-S | 70-200 f2.8L IS II | 100-400 f4.5-5.6L IS II | 430EXIII
n1as
Sep 14, 2012 16:45 |  #14
cueball wrote in post #14989867 (external link)
FoCal said the lighting was OK. The only thing I can think is that I was using a target printed on my computer as my ink cartridge was getting low. Maybe it created a sub-standard target?
Having to tether a laptop to the camera was one more strike against it. I could not make it work with JPG images I took and then loaded on the computer.
- Keith
jerbear00
Joined Mar 2011
Sep 15, 2012 00:42 |  #15
No problems. I get great results in good light. Tape the target to your Garage door and use golden hour light. Use the distance you like most for that lens. I stick with the 50x canon recs. I also like aperture sharpness and AF consistency tests. Great to see change in sharpness over apertures.
5d3 & Lens CoLLector
Gear List/Feedback
4,350 views & 0 likes for this thread, 13 members have posted to it.
1592 guests, 136 members online
