Thread started 11 Sep 2012 (Tuesday) 22:44
40D err99 shutter/mirror problem
aparis99
Sep 11, 2012 22:44 |  #1
I only have about 18K clicks on my 5 year old 40D. I was shooting the other day and had a err99, thought the CFcard was full, put in a new one and it worked fine. Today it didn't work at all. Here's what it's doing: http://www.youtube.com​/watch?v=3lps8IcB-8o (external link)
Has anyone had similar issues and dealt with Canon? Since it's out of warranty they say it has to be checked out before they give me a cost estimate... Anyone had a similar issue and care to share what it cost to fix?
My Site - www.apimagery.com (external link)
Canon R5 (x2), Canon RF 15-35 f/2.8L IS, Canon RF 24-70 f/2.8L, Canon RF 70-200 f/2.8L, Canon RF 100-500L, Sigma Art 35 f/1.4, Canon 85 f/1.8, Canon 100 f/2.8L Macro
HyperCams
Gallery: 6 photos
Sep 11, 2012 23:01 |  #2
Bad shutter..?
That looks like a bad shutter issue/error, but TYPICALLY the mirror would move even if the shutter was bad...
Since the mirror is not moving, it could be:
the mirror box
drive motor(the mirror and shutter share the same motor IIRC)
or it is just a coincidence that the mirror is not moving..
I hear a click, but nothing moves..
most times, to me, that would mean that something broke off, as in the little "arm" that the shutter is moved with..is there a rattle inside the camera?(more so than what would normally be heard)
I have done shutter repairs to several 40Ds, and it only cost me $50 for the new shutter...
but, if you send it to Canon, I would expect a bill of ~$200-230 or so..and it will be done right, or everything will be checked out..so I will always recommend using Canon service for things like this..
But, at ~$230, is it even worth it..? I think I would look into Canon CLP with it, or at the very least look around at other service centers for possibly lower cost(Toshio, Pro Camera Repair, etc, I have no affiliation or experience with anyone other than Canon Service Centers...)..
Tough luck..sorry!
Hope you get it back up and running.. :)
Brent Oliver
HyperCams & Mods (external link)/Oliver Digital Images
My Flickr (external link)
Feedback and Gear
chrismarriott66
Gallery: 14 photos
Joined Jan 2012
Sep 12, 2012 06:16 |  #3
My 50d had a shutter problem, and it gave an Error 30, so I don't know if this is something slightly different, or at least the camera might not actually know what's wrong!
Chris Marriott Photography (external link)| Facebook (external link)
Complete Gear | 1ds iii | 5d iii | 50d | EF 16-35 f2.8 L USM ii | EF 24-70 f2.8 L USM | Σ 70-200 f2.8 ii EX DG HSM | Σ 35mm f1.4 Art | EF 50mm f1.4 USM | EF 85mm f1.8 USM | EF 85mm f1.2 L USM ii | 600EX-RT | 580EX ii | 430EX ii | YN622Cs |
John ­ from ­ PA
Joined May 2003
Sep 12, 2012 08:42 |  #4
Error 99 has several potential causes and these are the steps that Canon recommends to isolate the cause. Follow them carefully or you might not get good info on the cause. For instance, right after step 5 you retest the camera without a lens attached and no memory card. If you get the error at that point it is likely a camera issue needing repair. If you don't get the error, then you proceed to clean the lens contacts and mount a lens...
Again follow directions for the best info on the real problem.
To isolate the cause of the issue, we suggest that you do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99″ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99″ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99″ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99″ with a different Canon lens attached, then the camera should be serviced.
butcherman
Joined May 2011
Sep 12, 2012 08:49 |  #5
That is exactly what happened to my 40D last summer. Was recommended a camera repair place in the midwest as they were supposed to be cheaper than Canon. Can't remember their name. Talked to the tech there and after describing the symptoms, he estimated it would cost $300. Had the camera insured through State Farm and when I called them and told them what the tech said, the just issued me a check and I bought a 60D.
Canon 7D, Canon 50mm F1.8 STM, Canon EF-S 55-250mm f/4-5.6 IS STM, Sigma 17-50mm f/2.8 OS HSM , Yongnuo YN560 IV
butcherman
Joined May 2011
Sep 12, 2012 08:58 |  #6
Name of the place was United Camera in Bensensville, Ill. They have a website if you are interested: UnitedCamera.com The $300 quote was for shutter repair and mirror box.
ksbal
Gallery: 374 photos
Best ofs: 9
Sep 12, 2012 09:10 |  #7
I believe there is an internal 'date' battery separate from the obvious battery you use and charge all the time. I would investigate and replace that before I shipped it off to the repair shop.
Godox/Flashpoint r2 system, plus some canon stuff.
4,960 views & 0 likes for this thread, 6 members have posted to it.
1458 guests, 137 members online
