mannetti21 wrote in post #14983001
I don't understand why so many people try to draw up aperture equivalents between sensors. An aperture of f/2.8 is f/2.8 no matter what camera body it is on. The same amount of light enters no matter which way you try to cut it. The lens doesn't suddenly gain an improvement in light gathering if you take it off a 450D and put it on a 5D3.
Well, here is why. The way the camera works in making images is really affected by the size of the sensor. And when you have a really small sensor a lot of things (depth of field, low light capability) are just like having a much smaller aperture.
In a lot of ways, cameras with very small sensors like most P&S are great illustrations. A Panny LX5 (or whatever) may have a 5mm-30mm f/2.8 lens, but you are never going to take the same photo with that tiny sensor P&S as you would get with a larger sensor dSLR and standard zoom.
So I am one of those people that will tell you that having a 24-105L on a 5D Mark III body is very much like having a mythical 15-64 f/2.5 IS zoom on a body such as the 7D. Here is why.
Field of view is first and simplest. 24-105 on FF gives the same field of view that 15-64 gives on a 1.6X sensor.
DOF is second. Suppose I take a shot at 105mm and f/4 using the 24-105L on the 5D. To take the same photo with the same DOF with a 7D I need to shoot at 64mm focal length and f/2.5 aperture. Because I use a shorter focal length for any given framing and perspective with the smaller sensor, I need a larger aperture to arrive at the same DOF.
Finally, we have light gathering capability. Obviously, when it comes to transmission through the lens f/2.8 is f/2.8 the world over. But in general a FF camera of a certain generation will have less noise than a 1.6X camera of the same generation. The result is that I can use slower lenses on FF while compensating via higher ISO while not getting more noise.
So yes, the FF equivalent to the 17-55 IS is indeed the 24-105L, except it is wider, longer and effectively faster.
