Thread started 14 Sep 2012 (Friday) 06:47
TO 7D OR NOT TO 7D MAYBE 5DMK2
Eddy-go-lucky
1 post
Joined Sep 2012
Sep 14, 2012 06:47 |  #1
Hello all
I am returning to photography (5 yrs out)and after some research have chosen 2 bodies they are the 7d and the 5d mk 2 the lens will be a tamron 17mm to 50mm and they will be used mostly for landscapes,portraits and wildlife which Norfolk has a lot of.
Other lenses added later,So what 1 do i choose as i will be selling prints upto A3 size so need to make the right decision,how good is the 7d at landscapes i hear rumours it is not great at low light.
Any help would be greatly received.....
Deetrini
Joined Dec 2011
Sep 14, 2012 06:53 |  #2
Best advice is to rent both and try them out if you can. That way you have "feel" for it, people will just give you biased opinions.
"Watermarks ruin photos" - anonymous
blackjack999
Gallery: 73 photos
Joined Feb 2012
Sep 14, 2012 07:11 |  #3
Here you can see what the 7 is capable of in terms of landscape:
https://photography-on-the.net …/showthread.php​?t=1197369
Deetrini gave you a good advice: try them out first and make your own decision.
X-Pro2 + 23mmF1.4
jpdunn
Joined Jul 2012
Sep 14, 2012 07:14 |  #4
It all depends what you are shooting...but as Deetrini said it all comes down to personal preference basically.
I currently use the 5D2 and it is absolutely stunning, sure the auto focus does miss sometimes(not that often to make it a big issue though), but with each camera there is bound to be a few drawbacks.
If you are able to rent them both then by all means do that, but if you cannot rent(like me) then it isn't too much of an issue anyway as they are both stunning cameras, however the 7D tends to lean more towards video and fast moving subjects.
http://jpdunn.daportfo​lio.com/ (external link)
stsva
Gallery: 45 photos
Sep 14, 2012 07:27 |  #5
If you plan to only shoot landscapes and basically nothing else, the 5DII has an advantage over the 7D since it has slightly higher sensor resolution and somewhat better (about one stop) high-ISO image quality. For portraits, other than the 5DII's full frame advantage of allowing narrower depth of field (which may or may not be important to you), I'd say the two come very close. For wildlife, the 7D wins, as it has both the high-density sensor crop "reach" advantage in focal length-limited shooting situations and significantly better autofocus for shooting moving subjects.
Some Canon stuff and a little bit of Yongnuo.
Member of the GIYF
Club and
HAMSTTR
٩ Breeders Club https://photography-on-the.net …=744235&highlig​ht=hamsttr Join today!
Image Editing OK
lannes
Sep 14, 2012 07:41 |  #6
Nikon D600, is a good alternative that has a good combination of features
Scott ­ M
Gallery: 111 photos
Sep 14, 2012 07:44 |  #7
The Tamron 17-50 lens you mention is for crop bodies only, and will not work on the 5D2. I would suggest deciding on the body first, and then pick which lens you will buy for a standard walk around. The choice will be much different depending on whether you end up with a 7D (crop body) and 5D2 (full frame).
Photo Gallery (external link)
hollis_f
Sep 14, 2012 07:45 |  #8
stsva wrote in post #14989659 (external link)
Er, nope. It has a larger sensor but with fewer pixels (hence a lower resolution).
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
Tsmith
Formerly known as Bluedog_XT
Sep 14, 2012 07:51 |  #9
Not quite sure how low of light your speaking about using it in but I've haven't had any issue using mine in low light with f/4 lens. Total darkness might present a problem but I'd tend to think that could be with a lot of cameras too.
IMO it holds its own against the 5D Mark II in landscape work and notice I didn't say better; 5Dii -vs- 7D for landscaping?
stsva
Gallery: 45 photos
Sep 14, 2012 08:33 |  #10
hollis_f wrote in post #14989696 (external link)
Good point. There goes the 5DII advantage for landscapes. :)
Member of the GIYF
Club and
HAMSTTR
Image Editing OK
Mornnb
Gallery: 6 photos
Joined Aug 2012
Sep 14, 2012 08:56 |  #11
Tsmith wrote in post #14989720 (external link)
Hmm. The 5D mk2 is rather obviously sharper in that thread, though I don't think you'd notice if they weren't side by side. But it's clear this is comparing two very similar cameras in capabilities, the 5D is only very slightly better. I do a lot of landscape and I decided it wasn't worth the money for the slight extra quality you get by going to 5D mk2. Especially if you consider the loss in frame rate and focus ability. Landscape might be what I enjoy most, but is not the only thing I do. Also, the smaller DOF of full frame is a disadvantage for landscape.
Canon 5D Mark III - Leica M240
EF 16-35mm F/4 IS L - EF 14mm f/2.8 L II - - EF 17mm TS-E L - EF 24-70mm f/2.8 L II - EF 70-200mm IS II f/2.8 L - Sigma 35mm f/1.4 Art - Sigma 85mm f/1.4 EX
Voigtlander 15mm III - 28mm Elmarit-M ASPH - 35mm f/1.4 Summilux-M FLE - 50mm f/1.4 Summilux-M ASPH
500px (external link)
shinksma
Joined Jul 2011
Sep 14, 2012 09:16 |  #12
Hmm, are you sure?
AFAIK:
7D: 5,184 × 3,456 (17.9 megapixels)
5DII: 5,616 × 3,744 (21.1 megapixels)
The 5DII has more pixels. The 7D has higher pixel density, though.
For landscapes, where the "target frame" is big and wide, the two cameras will be trying to capture the same field of view, so sensor size will be adjusted for by using the appropriate focal length. So the 5DII will do a better job with more pixels.
shinksma
5DII | T3i | EF 17-40 L | EF 24-105 L | EF 24 1.4 L II | EF 28 1.8 | EF 85 1.8 | EF 70-200 2.8 L IS II | EF 100-400 L | EF-S 15-85 IS USM | EF-S 17-55 2.8 IS USM | EF-S 10-22 USM | EF 100 2.8 Macro USM | EF-S 18-55 IS | EF 35-80 III | EF-S 55-250 IS | Rokinon 8mm FE | EF 75-300 non-USM III | SMC Takumar 50mm f/1.4 | Tamron 70-210 | 430EX II | Kenko 2x MC4 and 1.4x Pro300DGX TC
Mornnb
Gallery: 6 photos
Joined Aug 2012
Sep 14, 2012 09:32 |  #13
One thing to consider is the glass, with the 7D you'll be wanting the 10-22mm and perhaps the 17-55mm for landscape work. With a 5D mk2 you'll have the sensor size necessary to make use of the L series wide angle lens. Though they are not necessarily optically better than the best EF-S lenses.
Another thing is tilt shift lenses, 7D greatly restricts their angle of view.
Though your Tamron 17mm to 50mm has a good focal length for most landscape work on the 7D.
RoadPhotog
Joined Dec 2011
Sep 14, 2012 12:42 as a reply to  @ Mornnb's post |  #14
Higher Pixel Density = Higher Noise.
5D MK II, 24-105L, 70-200 f2.8L, 2X TC III,430EXII, 055ProXB, 498RC2.
stsva
Gallery: 45 photos
Sep 14, 2012 13:09 |  #15
RoadPhotog wrote in post #14991007 (external link)
Tell that to the D800. ;)
Member of the GIYF
Club and
HAMSTTR
Image Editing OK
2,902 views & 0 likes for this thread, 17 members have posted to it.
2845 guests, 175 members online
