Thread started 14 Sep 2012 (Friday) 07:46
5d mk3 memory card options
0.0f
Joined Apr 2011
Sep 14, 2012 07:46 |  #1
interested to know what memory card setup members are using on their 5d's. i currently have two sandisk extreme 60mb/s cards (from 7d) but have been reading that to get the best from the camera with respects to clearing the buffer quickly best to go for the newer 95mb/s cards.
EOS 5D MK3 - 24-70 MK2
tmalone893
Gallery: 54 photos
Sep 14, 2012 08:21 |  #2
0.0f wrote in post #14989698 (external link)
What you have will be plenty fast. I have the same ones, coming from a 7d as well, and I have no problems.
MaxPreps Profile (external link)
https://www.instagram.​com/theronmalone/ (external link)
Superdaantje
Sep 14, 2012 08:59 as a reply to  @ tmalone893's post |  #3
I also use the Sandisk Extreme cards. They are fast enough for me on the 5D III ...
Wagner.photography -  (external link) Workshops photography in the Netherlands & Indonesia -_-
Gear list (external link)
NASS ­ Photo
Sep 14, 2012 11:06 as a reply to  @ Superdaantje's post |  #4
You are ok with what you have. Just get the same type for the SD cards.
NickS
Canon 5DMIII; Canon EF35mm, f/1.4L; EF85mm, f/1.8; EF135mm, f/2.0L; EF200mm, f/2.8L.
Superdaantje
Sep 14, 2012 11:13 |  #5
The 5D III has no fast SD card slot. So an fast SD card is overkill for the camera.
Also the SD card slot speeds down the writing speed ..... for me no problem ;-)a
Wissigle
Joined Apr 2011
Sep 14, 2012 11:49 |  #6
Take a look at this. Personally I also use Sandisk Extreme and they are prefectly fast enough for me, but I don't often do long bursts. Also, forget the SD slot if you want speed, it's incredably slow compared with the CF slot.
http://www.robgalbrait​h.com …i_page.asp?cid=​6007-12452 (external link)
Wissigle
Gear
0.0f
Joined Apr 2011
Sep 14, 2012 14:16 |  #7
So the SD slot essentially acts as nothing more than just a back up to the CF slot?
Well that's what I'm interpreting it as.......
MCAsan
Joined Jun 2010
Sep 14, 2012 16:22 |  #8
I never use slow SD cards in my 5DIII. I use Lexar 32GB 1000x cards to max file transfer speeds from the camera buffer to the cards. A side benefit is the faster card downloads if you have a UDMA7 compliant reader (such as Lexar dual slot USB 3) hooked up via USB 3. I believe you can find deals on 2 packs of them at Adorama, B&H, or maybe Amazon.
Yogi ­ Bear
Sep 14, 2012 18:33 |  #9
Wissigle wrote in post #14990760 (external link)
Despite the speed ratings, SD memory is REALLY slow! Thanks for pointing this out with the data!
Canon EOS 7D | EF-S 17-55mm f/2.8 IS USM | EF-S 55-250mm f/4.0-5.6 IS |
EF 100-400mm f/4.5-5.6L IS USM | 250D | EF-S 10-22 mm f/3.5-4.5 USM | 580 EX II |
3,574 views & 0 likes for this thread
Latest registered member is Jesterj75
791 guests, 170 members online
