Thread started 14 Sep 2012 (Friday) 15:32
Which filter for à 10-22?
DDA
Formerly foolish member. Waiting for new title.
Location: Between a cow, a clock and tons of chocolate...
Sep 14, 2012 15:32 |  #1
I've just received a 10-22 - woohooo- that will start his relationship with my 7D. I think i'll give them a filter to have some fun ;-)a Any recommendation?
I'm looking on one hand at a strong ND filter (B+W 110?)
On the other hand, a good polarizer could be great as well...
As i'm not very knowledgeable with regard to filters, i'd appreciate your opinion...
DDA - C&C welcomed and encouraged
“A technically perfect photograph can be the world’s most boring picture.” (Andreas Feininger)
An empty account and a lack of talent (external link)
markweaver
Sep 14, 2012 15:38 |  #2
A polarizer may give you some unintended results. You tend to get really ugly banding in the sky when you are at the ultra wide end.
Mark
XTi | 5D MkII | Zeiss 21/2.8 Distagon | Zeiss Jena 35/2.8 Flektogon | 24-105 L | 70-200L f4 | 10-22 f3.5-5.6 | 50 f1.4 | Samyang 14mm | 24mm f/2.8 | Sigma 15mm Fishy
www.flickr.com/photos/​marksweaver/ (external link)
frugivore
Gallery: 11 photos
Sep 14, 2012 15:47 |  #3
I went for the ND filter first. It really helps on those bright sunny days. Mine is a 4 stop ND, but I'd like something stronger as well.
DavidR
Sep 14, 2012 17:15 |  #4
What are you wanting to achieve with the filter? ND and polarizing filters are used for different applications. Unless you are taking waterfall shots I would recommend a good polarized filter, they are used for more than just darkening the sky.
Sony a9II
rick_reno
Sep 14, 2012 19:44 |  #5
I used a b+w mrc cpl on mine and had no banding or vignetting problems
DDA
Sep 15, 2012 05:31 |  #6
Thanks all for the comments.
David, i know the difference between both. That's why i'd like to get one of each, gor fifferent applications. I'm just a bit lost between all the brands/quality available...
DavidR
Sep 15, 2012 06:58 as a reply to  @ DDA's post |  #7
B+W and Hoya is all I use and can recommend, for a circular polarizer buy one that is multi-coated. There has been reports of the Hoya falling apart but this has never happened to me and I've been using Hoya for many years.
Sony a9II
Preeb
Gallery: 150 photos
Joined Sep 2011
Sep 15, 2012 07:17 |  #8
DavidR wrote in post #14992255 (external link)
The only issue I had with a polarizer on my 10-22 was not banding, but it was possible to get a wide variation in how much the sky was darkened because of the difference in the angle that the light entered the lens from. In the center it might darken as planned, but on the ends the sky would lighten as the angle of incidence moved away from 90 degrees. If you aren't including a lot of sky, then the polarizer can give you better color saturation, but just keep in mind that there can be issues, especially at the wider end of the zoom.
Rick
6D Mark II - EF 17-40 f4 L -- EF 100mm f2.8 L IS Macro -- EF 70-200 f4 L IS w/1.4 II TC
MCAsan
Joined Jun 2010
Sep 15, 2012 07:32 |  #9
The only filters I carry into the field are CPL and a VND. The CPL can very problematic on a extremely wide lens as 10-22. The VND is for droping light levels to slow moving water at streams and waterfalls. The other filter effects such as GND can all be generated in post processing tools (LR, PS, PSE). Before you spend money on filters other than a CPL and VND, try to the soft ones in your processing tools.
Denny ­ G
Joined Jul 2004
Sep 15, 2012 19:08 as a reply to  @ MCAsan's post |  #10
I have a 10-22 that I use on a 40D.
I use a B+W CPL. (non slim) No banding or Vignetting but I do get variation in the sky.
I also use a B+W ND 0.6 filter at times to kill the sun.
DDA
Sep 16, 2012 05:23 |  #11
Thanks all! So i guess i'll have to start with the nd and see later if i take a cpl as well...
Tsmith
Formerly known as Bluedog_XT
Sep 16, 2012 19:15 |  #12
markweaver wrote in post #14991824 (external link)
Hardly an issue to warrant not using one on this lens. Mine stays attached about 90% of the time when hiking. Polarizer's aren't just for making blue sky and clouds standout.
3,068 views & 0 likes for this thread, 9 members have posted to it.
672 guests, 125 members online
