Thread started 14 Sep 2012 (Friday) 17:34
Avoiding umbrella reflection in glass
Christopher ­ Steven ­ b
Sep 14, 2012 17:34 |  #1
Hello all--I have a wedding tomorrow on the top floor of a hotel with a rotating restaurant with an outer wall that is all window.
I'd love to be able to expose for the view of the city beyond the glass whilst exposing the family (via group shots) with my off-camera flash + umbrella.
Is there a way to do these group photos that would avoid both the glare created by my flash as well as the reflection of the umbrella ?
If it wasn't clear, this 'window' is round and forms a complete circle (horizontally) around the hub of the restaurant.
Thanks !
christopher steven b. - Ottawa Wedding Photographer
www.christopherstevenb​.com (external link)| Blog (external link)
Submariner
Joined May 2012
Sep 14, 2012 19:14 |  #2
Christopher Steven b wrote in post #14992316 (external link)
Thanks !
Hmmm Challenging!
Is it day or evening reception [assuming daytime].
We have a PO tower like that in London - even without a flash the curvature reflects a lot of reflected 'landscape' youre going too have to get that flash quite a way to the side. Or you need advice from someone real good.
Canon EOS 5DS R, Canon EF 70-200 F2.8 L Mk II IS USM, Canon EF 70-300 F4-5.6 L IS USM, EF 40mm F2.8 STM , RC6 Remote. Canon STE-3 Radio Flash Controller, Canon 600 EX RT x4 , YN 560 MkII x2 ; Bowens GM500PRO x4 , Bowens Remote Control. Bowens Pulsar TX, RX Radio Transmitter and Reciever Cards. Bowens Constant 530 Streamlights 600w x 4 Sold EOS 5D Mk III, 7D, EF 50mm F1.8, 430 EX Mk II, Bowens GM500Rs x4
Sep 14, 2012 20:38 |  #3
^ Good point. Ceremony starts at 7ish; formals will start around 8ish. The outdoors will still be lit up reasonably, so it might not be as much of an issue as I first thought.
Far to the side is how I'd normally shoot anyway (I push as far off axis as I can until i'm out of Rembrandt lighting zone). It's possible i could also flag (block) the umbrella in this case (but with what !?).
Alternatively I could position my light nearer to on-axis (a couple of feet to my left e.g.) and then the reflection / glare will largely be occluded / hidden by the people in the photo. Of course the downside there is that the lighting just isn't as nice.
KirkS518
Joined Apr 2012
Sep 14, 2012 20:55 as a reply to  @ Christopher Steven b's post |  #4
I'm thinking layers in post will be easiest.
IMAGE: http://www.bdwf.net/forum/images/smilies/smiley_shrug[1].gif
If steroids are illegal for athletes, should PS be illegal for models?
Digital - 50D, 20D IR Conv, 9 Lenses from 8mm to 300mm
Analog - Mamiya RB67 Pro-SD, Canon A-1, Nikon F4S, YashicaMat 124G, Rollei 35S, QL17 GIII, Zeiss Ikon Ikoflex 1st Version, and and entire room full of lenses and other stuff
lazer-jock
Don't mess
Sep 14, 2012 21:42 |  #5
Circular polarizer to cut the reflection would be my first reaction...
I'm off lining my cage with newspaper.
My Gear List
windpig
Chopped liver
Sep 14, 2012 21:51 |  #6
Angle of incident equals the angle of reflectance. It is what it is.
Go ahead, spin the wheel.
Aressem
Gallery: 39 photos
Sep 15, 2012 03:42 |  #7
Circular polarizer as mentioned above
Ryan Mackay WEBSITE (external link) | FACEBOOK (external link) | GEAR LIST | Buy & Sell Feedback: 1, 2, 3, 4, 5
munzzzzzzz
Sep 15, 2012 07:07 |  #8
Make a composite shot in post. Camera on tripod, first shoot with no people and expose for outside. Then shoot your family shots without moving the camera. Now combine as separate layers in PS.
6D | 40mm f/2.8 | 50mm f/1.4 | 70-200mm f/4L IS | 580EXII | 2x PCB Einstein | Various Modifiers
drvnbysound
Sep 15, 2012 07:26 |  #9
munzzzzzzz wrote in post #14994309 (external link)
What would actually really be good about this is that you could selectively choose exactly what you want in the background of your image (easier). As the OP mentioned, the restaurant is actually turning, so the background would constantly be different for the group shot. However, to shoot the BG with the intention of it being a separate layer would allow you to wait and choose what's out there without forcing the group to wait as well.
That said, I think it would be easier to setup the group shot first, and the BG shot second... ensuring that your frame doesn't change would make the post-processing easier. I certainly don't know how well I would be able to predict the frame of a group shot before hand - I would get them all placed and then end up having to make an adjustment to fit in Uncle Bob ;) then my layers wouldn't match.
I use manual exposure settings on the copy machine
..::Gear Listing::.. --==Feedback==--
...A few umbrella brackets I own...
windpig
Chopped liver
Sep 15, 2012 09:00 |  #10
Good luck with a CPL. Aside from not really eliminating the reflection, It's not food for rendering skin.
saea501
... spilled over a little on the panties
Gallery: 43 photos
Sep 15, 2012 09:45 |  #11
windpig wrote in post #14994527 (external link)
I think this will be correct under these lighting conditions.
Remember what the DorMouse said.....feed your head.
Bob
https://www.flickr.com​/photos/147975282@N06 (external link)
Whortleberry
Joined Dec 2011
Sep 15, 2012 10:45 |  #12
Forget polarisers, t'won't work in this context at all. In addition to not removing flash hotspots effectively, they will reduce your ambient light by maybe a couple of f/stops and genreally make life very awkward indeed.
Is the glass simply curved in one plane (ie it curves round the circumference of the building) and straight vertically? If so, the best option (by no means a perfect solution but probably the best you'll get) is to place the flash as high as you can get it - probably directly above the camera and touching the ceiling. No good moving it to the side with the curve running round - you'll get a hotspot somewhere no matter what you do.
Phil ǁ Kershaw Soho Reflex: 4¼" Ross Xpres, 6½" Aldis, Super XX/ABC Pyro in 24 DDS, HP3/Meritol Metol in RFH, Johnson 'Scales' brand flash powder. Kodak Duo Six-20/Verichrome Pan. Other odd bits over the decades, simply to get the job done - not merely to polish and brag about cos I'm too mean to buy the polish!
FlickR (external link) ◄► "The Other Yongnuo User Guide v4.12" by Clive Bolton (external link) ◄► UK Railway Photographs 1906-79 (external link)
Sep 15, 2012 12:58 |  #13
Thanks everyone for the suggestions.
I hadn't even considered a polarizing filter (though have used one before). I'm game for losing a couple of stops of light but I'm concerned about flare issues and other weirdness that might crop up with light pouring in in front of my lens. Shoot-if I had one to experiment with, i might have tried it.
The glass is only curved in one plane, yes (as far as I know !). So you're right, that placing the flash up high may be the ticket.
I'm going to try way off axis to see how badly it shows up in the reflection (I'll take mediocre light + hotspot over good light + hotspot if given the choice); if it's bad I'll try bouncing without the umbrella--this will render my light source (a large swatch of ceiling) basically invisible from the perspective of its impact on the window.
I wish I could let you know how this went but the wedding involves military folk who have asked for discretion. Maybe I'll grab a few non-peopled shots for demonstration, though..
flowrider
Gallery: 127 photos
Sep 15, 2012 13:28 |  #14
windpig wrote in post #14993288 (external link)
+1 for this and getting the light up as high as possible and I would suggest shooting down ever so slightly to eliminate reflection even more.
~Steve~
~ My Website-stevelowephoto.com (external link) ~ Facebook (external link)
Feedback Feedback Feedback
LBaldwin
Sep 15, 2012 13:51 |  #15
raise your strobe head 8 feet over the subject point from the floor. shoot from a small ladder that get you at least 3 feet off the floor.
have the subject with glasses drop their chins until you can't see any reflections through the camera, or on a test shot.
Les Baldwin
http://www.fotosfx.com (external link)
7,995 views & 0 likes for this thread, 15 members have posted to it.
1686 guests, 141 members online
