Thread started 25 Dec 2005 (Sunday) 06:44
Pixma iP8500 + PSE 3 + Colour Management
MartinL
Dec 25, 2005 06:44 |  #1
I'm getting really confused. I use the above + Canon Glossy Paper
Everything has a slight red cast on the print.
I used adobe gamma on my PCT to set the colour their.
I can't see how to turn off the printer colour (as suggested by some). I tried ticking the ICM box in manual color adjustment of the printer - no benefit
Don't fully understand colour management in PSE 3 - the image sppace refers to sRGB IEC6 1966-2.1; the print space to BJ colour printer profile 2000 which I think is correct for the above paper - no significant difference
Finally tried Adobe RGB - this seems much better - is this right thing to do
benf64
Dec 25, 2005 15:42 |  #2
i have the same printer....i am using adobe RGB profile in PS and using SP1 for the glossy paper in print preview. I also chose none in color management in the printer driver settings..
Ben
40d Extender EF 1.4x II,100-400 USM IS L, Tamaron 17-50 /2.8 EF 100mm f/2.8 USM Macro, Feisol CT-3401n, Bogen 88RC2
Kata R-102, 580ex flash
MartinL
Dec 26, 2005 02:15 as a reply to  @ benf64's post |  #3
Thanks Ben, appreciated.
Excuse my stupidity but how/where did you find colour management let alone tick none? All I can find is color adjustment & then in that box there is nothing to suggest I can turn it off.
Out of curiosity did you try any other combinations & if so (& if you got the time which ones) and why did you plump for Adobe RGB + SP1 in the end
benf64
Dec 26, 2005 08:24 |  #4
In Photoshop when u hit print preview you get a box that says print space and i choose SP1 to match the glossy paper and when i hit print the print driver box opens and i choose preferences and under color adjustment i choose manual then i choose none and also make sure under effects all are unchecked.
Ben
crn3371
Dec 26, 2005 14:13 |  #5
I'm having the same problems with my new 8500. With my old epson and printing within PSE3 I had very specific descriptions on Epson paper within the color space dialog box. With the Canon I just get color space settings such as sp1, pr1, etc. How do I match those numbers with the type of Canon paper I'm using?
benf64
Dec 26, 2005 14:45 |  #6
The color profiles listed below are for printing images that are saved in Adobe RGB color space:
MP2 is for Matte Finish with a custom quality setting of 2.
PR1 is for Photo Paper Pro with custom quality of 1.
PR2 is for Photo Paper Pro with a custom quality setting of 2.
SP1 is for Photo Paper Plus media Glossy with custom quality of 1.
SP2 is for Photo Paper Plus Glossy media with a custom Quality setting of 2.
Ben
MartinL
Dec 27, 2005 03:26 |  #7
Thanks Ben - have followed your idiots guide (referring to me not you)to the 8500 & certainly there is a definate improvement. With appreciation
M :)
crn3371
Dec 30, 2005 12:14 |  #8
I too want to send my thanks. By using the correct icc profiles (have to admit that Canon's ARE a little cryptic) and making sure that all color correction is turned off in the print driver, I am getting the best color matched prints that I've ever had, and this is only using adobe gamma for color management. Thanks again Ben. Also, for Martin, found this article @ Steve's digicams site, pretty much spells out step by step how to get good prints with your Canon printer. www.steves-digicams.com/techcorne​r/June_2005.html (external link)
MartinL
Dec 30, 2005 12:33 |  #9
Just read steves-digicam link - explains perfectly - thanks for that
M
2,062 views & 0 likes for this thread, 3 members have posted to it.
2305 guests, 135 members online
