Thread started 16 Sep 2012 (Sunday) 15:08
7D Red Eye Reduction light can it affect Monolight triggering?
Submariner
Joined May 2012
Sep 16, 2012 15:08 |  #1
I only asked this as it does not seem to effect my Bowens ie. when you have it on and 1/2 press the shutter it does not trigger the Bowens [which is good for me using both camera and flash in manual mode. I use the onboard 7D flash to trigger the Bowens 2x 500R's optically].
I only asked as if I put the Bowens in self learning mode ( where it technically can count the number of preflashes and correspondingly ignore them thus firing on the last fire command) it sees this as a flash.
Eg if you set up wireless flash with red eye reduction it counts 5 flashes, if you turn off the red eye reduction it sees 4 flashes.
Don't worry I long since given up trying to mix speedlights wirelessly and monolights - it can't be done.
I was just wondering if the red eye reduction [when and only when one actually presses the shutter completely] could trigger the flash ever so slightly prematurely.
NB I don't have any evidence of this happening just intrigued that the self learning mode can pick it up everytime as a preflash but somehow does seem to trigger the Bowens optical slaves - just wierd?
Any views?
Canon EOS 5DS R, Canon EF 70-200 F2.8 L Mk II IS USM, Canon EF 70-300 F4-5.6 L IS USM, EF 40mm F2.8 STM , RC6 Remote. Canon STE-3 Radio Flash Controller, Canon 600 EX RT x4 , YN 560 MkII x2 ; Bowens GM500PRO x4 , Bowens Remote Control. Bowens Pulsar TX, RX Radio Transmitter and Reciever Cards. Bowens Constant 530 Streamlights 600w x 4 Sold EOS 5D Mk III, 7D, EF 50mm F1.8, 430 EX Mk II, Bowens GM500Rs x4
483 views & 0 likes for this thread.
2845 guests, 175 members online
