denbeau wrote in post #15004230
Could I be letting in light from the view finder? I ware glasses and my face doesnt press into the view finder cup and if I had them off...I'll test that!
Dark Knight, I cannot change cameras now, as I just got this T3i last week. And to me it was a good sized investment. I'll learn how to use it....
No, light does not enter the camera from the viewfinder, only through the lens
so you don't need to worry about your glasses!
It takes time and practice. Just keep playing with the camera, its a good camera and capable of taking amazing pictures - but you can't expect it to do so on Auto mode without any help from you. Cameras are intelligent, but colours trick them. They see "black" as a lack of light, and will therefore over expose the surrounding colours to compensate for what it thought was dark (like the forest in your first image). When they see "white" they believe it is a LOT of light, so they will underexpose. While AUTO mode means the camera will try to balance all of the settings for you to result in a properly exposed image, it could be taking away from the SS (shutter speed) in order to do so, unless you have a limiter set on how slow it can go. If it is dropping to slow shutter speeds, like 1/30th, to let in more light, then you are stuck dealing with camera shake and blur from your end. If your lens has IS this can help, but there is a limit on how far that can go. Taking it off of Auto and putting it on M allows you to dictate what balance you need. There are quite a few books out there if you're the type who learns from reading. If you learn from experience like I do, take it off auto and switch it to M, and learn by trial and error. Or look into local classes
