P.S. How do you guys get the trails to pop? I tried levels, curves, contrast...nothing made the trails brighter/pop
Levels is one of the most vile, evil, sliders in Photoshop
I use the following technique on almost everything I process and definitely everything I print.
Contrast Mask (Mac keys. For a PC, if I'm not mistaken, Ctrl = Command and Alt is Alt)
Open the image in Photoshop. I think it works in Elements too.
Make sure Channels are visible (Window -> Channels)
Command-click the RGB Channel. You should see "marching ants" on your image
Down at the bottom of the Layers palette there is a white and black circle. Alt Click that. Don't let go of Alt. When the window pops up, while still holding Alt, click the Curves selection. Then ok until you get to your image with the curves dialog displayed
Now we get to the creative part. I "usually" grab the line about 20% from the bottom and pull it slightly down. Then I "usually" grab the line about 20% from the top and drag it up. I tweak the setting by watching the image and adjusting until I like what I see. Click the eyeball icon next to the layer that is created to see with / without. That's when you really see the difference.
The only thing, other than screwing the image up by over doing it, that you have to watch for is haloing. Keep an eye on the dark edges. Zoom in. Make sure there are no halos.
When this technique was demonstrated to me the person showing me the technique grabbed the line in the middle and pulled it up. For the image that he was working on that worked fine. There is no set way to use this technique.
After I do this I follow up with a midtone contrast action. If I can figure out a way to post it I will. Loading actions, if you haven't done it, is pretty easy. Using them is even easier.
It's hard to solve an equation if every term is an unknown.
Zeros matter
73 NE5U Mike
