Thread started 19 Sep 2012 (Wednesday) 10:43
would you do it?
mike_311
Checking squirrels nuts
Gallery: 18 photos
Joined Mar 2011
Sep 19, 2012 10:43 |  #1
should i sell my 60D, 10-22 and my Tamron 28-75 for a 5d2? im hesitant becuase i love using the 10-22.
I'd still have a 50/1.4 and a 85/1.8 to use with it.
i would pick up a 17-40L eventually, just not sure when...
Canon 5d mkii | Canon 17-40/4L | Tamron 24-70/2.8 | Canon 85/1.8 | Canon 135/2L
www.michaelalestraphot​ography.com (external link)
Flickr (external link) | 500px (external link) | About me
Martin ­ Dixon
Slit-scan project master
Gallery: 59 photos
Joined Sep 2009
Sep 19, 2012 11:04 |  #2
I am trying to sell my 10-22 as I have moved FF. I plan to replace it with a Samyang 14mm f2.8 as it is wider in both senses. It is also a lot cheaper. What do you think? How much do you zoom or do you nistly use 10mm?
flickr (external link) Editing OK (external link) www.slitcam.com (free slit-scan utility) (external link)
mike_311
Gallery: 18 photos
Joined Mar 2011
Sep 19, 2012 11:10 |  #3
i use it mainly as a zoom since its on a crop right now. i dont really use the 28-75 all that much, it not being able to replace the 10-22 range i enjoy now that holding me up. if i had the extra $500-$600 to buy the 17-40L i would would have made the 5d2 purchase all ready.
but now that winter is coming i spend most of my shooting indoors where the 50 on a 5d2 will do fine, and when i do a photoshoot i mainly use my 50mm, which i would switch to the 85. the 10-22 is just my fun lens.
Scott ­ M
Gallery: 111 photos
Sep 19, 2012 13:05 |  #4
If you use the 85mm a lot on your 60D, remember that it will give a wider field of view on the 5D2, so you many find that you want a longer prime lens, too. I loved using the 85mm f/1.8 on my crop bodies, so added a 135L when I bought a 5d3. My 85mm doesn't get used now (I really do need to sell it).
Photo Gallery (external link)
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Sep 19, 2012 13:12 |  #5
It seems to me that if you enjoy shooting the UWA focal range so much, it would be a really bad idea to put yourself in a place where you can no longer do so. Be better to save up for a while until you can work out both the body and lens update.
mike_311
Gallery: 18 photos
Joined Mar 2011
Sep 19, 2012 13:31 |  #6
Scott M wrote in post #15014614 (external link)
i dont use my 85 now.
chrismarriott66
Gallery: 14 photos
Joined Jan 2012
Sep 20, 2012 04:30 |  #7
You might find the Tamron gets more use on a FF camera because obviously you get a true 28mm as opposed to a reduced field of view on the 60d... Having said that, it's still nowhere near as wide as your 10-22 on the 60d. You'll probably find the 85 more usable as well, but it depends if you can do without the UWA as you say! Good luck
Chris Marriott Photography (external link)| Facebook (external link)
Complete Gear | 1ds iii | 5d iii | 50d | EF 16-35 f2.8 L USM ii | EF 24-70 f2.8 L USM | Σ 70-200 f2.8 ii EX DG HSM | Σ 35mm f1.4 Art | EF 50mm f1.4 USM | EF 85mm f1.8 USM | EF 85mm f1.2 L USM ii | 600EX-RT | 580EX ii | 430EX ii | YN622Cs |
LostArk
Joined Apr 2012
Sep 20, 2012 04:44 |  #8
I sold my 10-22 and got a 5D2. Best decision I ever made. I say go for it!
www.unknoahble.com (external link)
Mornnb
Gallery: 6 photos
Joined Aug 2012
Sep 20, 2012 04:45 |  #9
I'd wait for the 6D. Better autofocus with more low light sensitivity, wifi and higher ISOs.
Canon 5D Mark III - Leica M240
EF 16-35mm F/4 IS L - EF 14mm f/2.8 L II - - EF 17mm TS-E L - EF 24-70mm f/2.8 L II - EF 70-200mm IS II f/2.8 L - Sigma 35mm f/1.4 Art - Sigma 85mm f/1.4 EX
Voigtlander 15mm III - 28mm Elmarit-M ASPH - 35mm f/1.4 Summilux-M FLE - 50mm f/1.4 Summilux-M ASPH
mike_311
Gallery: 18 photos
Joined Mar 2011
Sep 20, 2012 06:22 |  #10
its also only has 1/180 flash sync and 1/4000s both of which are important to me. this purchase is mainly to benefit my side business, thus i plan to go with more pro orientated camera.
boerewors
Joined Sep 2009
Sep 20, 2012 07:11 |  #11
Why do you want to go FF? I suppose it depends on what youre shooting. The 60D autofocus points are all cross type and you may miss that feature. I know i cant live without outer cross AF points. 5Dii has no built in flash and cant trigger off camera speedlights like the 60D can. 5Dii shutter sync is 1/200 vs 1/250 on the 60D makes that bit of difference in certain situations. I would personally hang onto my 60D till the day it dies but if you can justify the reason for whanting to change to FF then go ahead. The plus side of the 5Dii would be a narrower depth of field, about a stop less of noise and slightly better IQ.
The most important piece of gear you own, resides in your head and its called your brain.
chrismarriott66
Gallery: 14 photos
Joined Jan 2012
Sep 20, 2012 07:13 |  #12
mike_311 wrote in post #15018106 (external link)
If you have Canon flashguns then you have high-speed sync which partially eliminates the 1/180 issue. Don't forget you can also use ISO 50 (i know that's on both the 5d2 and the 6d), for wide apertures if that helps. I think the noise performance of the 6d will be a lot better than the 5d2, but I guess it depends what's important to you!
nburwell
Sep 20, 2012 07:39 |  #13
I would do that trade in a heartbeat! However, like you said, you would have to pick up a WA and a maybe a 24-105 or some third party equivilent.
MCAsan
Joined Jun 2010
Sep 20, 2012 08:16 |  #14
Having done something similar in years past, I would do that in a heartbeat. You can a refurbed 17-40 from Canon USA for a good price. With 17-40 on FF you will not have the distortion you get with a 10-22 on a crop body.
mike_311
Gallery: 18 photos
Joined Mar 2011
Sep 20, 2012 10:18 |  #15
i shoot mainly portraits, at least thats where my side income comes in. i shoots all sorts of stuff for fun.
the 5d2 i believe, or so i hear, has way better iso noise control than my 60D. i mainly use center point AF, but i have on occasion used the outside to compose when using a very shallow DOF. its always in good light with static subjects so lack of cross point outer AF isn't a concern.
i don't use the wireless flash control (i have radio triggers) and i rarely, if ever, use on-board flash.
im looking for better IQ out of my 50 and 85mm lenses mainly. i know I'll pick up a 17-40L eventually, just not right away, and i dont think i'll miss it now that summer is over and i dont do landscape photography all that much in the winter.
1,771 views & 0 likes for this thread, 12 members have posted to it.
would you do it?
2531 guests, 170 members online
