Thread started 19 Sep 2012 (Wednesday) 17:41
Just got an SSD. Now what?
Ainoko
Stupidest Question Award 2008
Sep 19, 2012 17:41 |  #1
Just ordered an SSD for my computer, and it should be here Friday. I want to make it my boot drive, and then use my current boot drive as extra storage. How should I go about doing this? Can I just disconnect my current boot drive, connect the SSD, and do a clean Windows 7 install off a dvd? Then what would happen if I reconnect the old HDD with Windows 7 on it? Will it work as just an extra hard drive, or do I have to reformat it somehow? Just a little confused.
Full Gear List
https://photography-on-the.net …?p=4846834&post​count=1005
windpig
Chopped liver
Sep 19, 2012 18:47 |  #2
I used Paragon Migrate OS and migrated my OS from my HD. It' work really nice. It also sets up the SSD to work the most efficiently with regard to sectors, etc.
You can check it out and read here:
http://www.paragon-software.com …onents/migrate-OS-to-SSD/ (external link)
I've kept the other drive as a backup for now, but will reformat it for data storage.
Go ahead, spin the wheel.
ben_r_
-POTN's Three legged Support-
Sep 19, 2012 19:08 |  #3
Either mirror (copy) your old hard drives data on to the SSD or do a fresh install of Windows on the SSD and make it your main/boot drive (recommended).
RDKirk
Adorama says I'm "packed."
Joined May 2004
Sep 19, 2012 19:31 |  #4
Ainoko wrote in post #15015947 (external link)
What kind of computer and what are you going to do with it?
As the main drive for a laptop, it's a no-brainer, more from its shock robustness than anything else (although fast boot/hibernation times are very nice in a laptop).
In a desktop machine that's going to be used for serious image editing, if I had only one SSD I'd make it my Photoshop scratch disk--especially if I had less than 16 gigs of ram.
My second SSD in an editing desktop machine would go for "working image" storage--my D: drive or the drive for the windows pagefile.
I'd have to have three or four SSDs in my desktop editing computer before one became my C:.
OneJZsupra
Sep 19, 2012 20:34 |  #5
Under Bios you can select which drive you want to boot from. Run through the settings after you'll installed windows on your SSD and have it boot from that drive from now on. Then you can do what ever you want with the other drive.
Also you should consider what Ben_r stated.
Gear List | Feed Back | My Site (external link)
YN RF-603 O-ring solution
Ainoko
Sep 20, 2012 01:58 |  #6
Cool! Thanks guys. I think I was headed in the right direction.
RDKirk wrote in post #15016368 (external link)
It's my desktop. I've currently got it running off a 320gb HHD, with an addition 1TB HDD for storage. I've got everything backed up on externals. Since the SSD I got is only 60gb, I'm trying to keep what I load onto it to a minimum. Eventually I want to get another SSD slightly bigger for working image storage, and then a couple of 2TB set up in Raid 1 for storage.
Full Gear List
PimpleMaze
Joined Sep 2012
Sep 20, 2012 17:53 |  #7
My personal opinion, Put your OS on your SSD. and the most disk intensive programs. This will speed up your overall system performance a lot. Use HDD as scratchdisk. If you run into problems of Photoshop slowing down because it is reading and writing to the slower scratchdisk, ADD MORE RAM! Photoshop will only use scratchdisk if it runs out of physical memory. I didn't know what a scratchdisk was untill i made an image with over 300 layers...(and i only have 8GB ram).
SSD's seem to die faster with constant reading and writing, and dont like to be defragmented. platterdisks are still a lot cheaper, and extra RAM even cheaper than that. (and RAM is way faster).
60 GB is very small for a windows 7 instalation, but if you put all personal folders, desktop, and less important programs on a partition on another drive, you will probably manage, (untill you have more drive space). Stripping windows from everything you don't need will also help. (and use programs like ccleaner and bleachbit)
If possible I would not use a partition image to move your current installation, but just do a clean install. It's a lot more work, but it will be like your house after a big spring cleaning.
All fresh drivers and latest versions of programs, and no left over residues.
(Keeping a backup image of your current system drive is still a good idea though, I use Clonezilla to clone harddrives and partitions).
(unless of course you have a Z68 board, then I would choose to use a 60 GB SSD, or a big part of it, for Intel Smart Response Technology. you won't get ssd performance, but a big overall performance gain anyway).
I never saw the use of Raid 1. You lose 50% of diskspace, and it's never safer than keeping regular external backups.
RDKirk
Joined May 2004
Sep 20, 2012 21:57 |  #8
Depends on what you're doing. There are some Photoshop plugins that use the scratch disk regardless of the amount of ram you're using (specifically, those that are still 32-bit in nature, even if you run them on a 64-bit system).
But, I do use an SSD in my laptop, and I've been able to put everything I need to edit images, movies, and create content neatlly within 40 gigs of space.
RichSoansPhotos
Sep 22, 2012 12:33 |  #9
I would do a clone of your current windows installation. Its not clear whether your SSD comes with software that allows you do that, my first SSD came with cloning software. Doing a clean installation of Windows would use one more of your allowable Windows activations.
If you decide to go down that road, and if your BIOS allows it, then I would enable AHCI first before installing Windows. This will allow for Windows to go into proper SATA mode...hence faster boot up etc....This is of course if you know how to fiddle around with the BIOS, not for the non nerdy types, lol.
RDKirk
Joined May 2004
Sep 22, 2012 12:42 |  #10
There is not a limit to Windows installations as long as you do not raise the "different computer" flag. Installing on a new hard drive with the same motherboard and processor will not raise the "different computer" flag.
Ainoko
Sep 22, 2012 15:11 |  #11
RichSoansPhotos wrote in post #15028257 (external link)
I just installed Windows, is there a way to change it? Or would I need to reinstall windows?
Full Gear List
RichSoansPhotos
Sep 22, 2012 16:00 |  #12
Ainoko wrote in post #15028695 (external link)
Go to your BIOS and check to see if your BIOS can support AHCI if not, just ignore the next bit
Restart, go to BIOS where if AHCI is mentioned, should look like something like this http://www.badalis.it …ads/2011/10/bio​s-ahci.png (external link)
or this http://www.toocool2bet​rue.com …2/03/Ahci-Mod-For-SSD.jpg (external link)
This, http://smallvoid.com …/winnt-sata-achi-ncq.html (external link)
but back up this registry bit to desktop
HKEY_LOCAL_MACHINE \System \CurrentControlSet \Services \Msahci
by right clicking it and export key to desktop, should you mess things up, you've got to go to safe mode double click it
Once you've changed the Start bit up here ----> http://smallvoid.com …/winnt-sata-achi-ncq.html (external link)
RichSoansPhotos
Sep 22, 2012 16:23 |  #13
One further note, when you save your settings from IDE to AHCI and restart the computer, check that the SSD is the boot drive, from personal experience and I am good with computers I forgot about this and nearly died, lol
John ­ Sheehy
Sep 22, 2012 16:30 |  #14
That's close to my philosophy. Swap and scratchdisk first, internet cache next, and then system boot drive further down the list of priorities. However, I tend to reboot only a few times a year only for software upgrades that require it, so booting Windows is not an issue.
solara
Sep 23, 2012 11:39 |  #15
Open the command prompt and type:
fsutil behavior query disabledeletenotify
If you get a 0 (zero) then TRIM is enabled and Windows likely correctly detected the SSD. If it's a 1, then TRIM is disabled.
To check if your drive is in AHCI mode, go to Control Panel > Device manager > IDE ATA/ATAPI controllers > and look for an AHCI controller. If you don't see an AHCI controller, it's likely in IDE mode.
Here are some simple tips for SSD newbs: http://blog.ocztechnol​ogy.com/?p=178 (external link)
5D III, 7D | 17-55 f/2.8 | 16-35 f/4 | 24-105 f/4 | 85 f/1.8 | 135 f/2 | 70-200 f/4 IS | 580EX II | YN-560 | Manfrotto 190XPROB+498RC2
8,088 views & 0 likes for this thread, 11 members have posted to it.
1584 guests, 139 members online
