I received an e-mail from Phottix saying they are releasing a TTL version of the Phottix Stratto in the 4Q of 2012.
What do you think the differences will be between it and the Phottix Odin?
The Phottix StratoTM TTL Flash Trigger – the newest addition to ever-popular Strato series of flash triggers and wireless remotes.
The Strato TTL Flash Trigger provides an easy-to-use and affordable TTL flash triggering solution to photographers. High-speed and second curtain sync are supported in this 4-channel, 2.4 GHz transmitter and receiver set. Shoot at maximum shutter speeds of 1/8000 s. *
With the LCD display and quick-change buttons adjustments are fast and easy. Strato TTL versions for Canon, Nikon and Sony will be released during Q4 of 2012, adding another stellar option in Phottix’s flash trigger line-up.
Triggering hot shoe flashes is only the start of the Phottix Strato TTL’s abilities. The Strato TTL will also trigger studio lights as well as function as a wired and wireless shutter release. It’s easy to connect to light stands or other grip with a cold shoe and ? inch threaded lug.
The Strato TTL flash trigger is part of the ever-growing Phottix ecosystem and is compatible with the Phottix Strato I and Strato II Multi series of triggers as well as the Phottix Atlas II. The Strato TTL features a USB port for firmware upgrades. Don’t get left behind as camera and flash technology changes.
Strato TTL versions for Canon, Nikon and Sony will be released during Q4 2012 and Q1 2013, adding another stellar option in Phottix’s flash trigger line-up.
