Thread started 19 Sep 2012 (Wednesday) 23:58
Compact camera is teaching me to appreciate using Manual mode.
Canajun
Sep 19, 2012 23:58 |  #1
The other day. I tried shooting a sunset with my SX40HS. I normally use Av for most of my shots as I understand how I want to use big and small aperture opening. Unfortunately f8 is the smallest opening. When I tried to shoot at this settings. The colours of the sunset were lost. The low light feature of the camera keeps taking over. So I switched to Manual mode and stepped down the shutter until the image on my Liveview was as close to what I was seeing with my eyes. I have no idea what the numbers mean but here's the example.
Av mode:
IMAGE: http://www.gregorio.ca/eyeboll/archives/640xTravel/2012/IMG_2282.jpg
Manual mode: ISO100, f8, 1/8 the settings may still be wrong. But this is as close to what I want to achieve.
IMAGE: http://www.gregorio.ca/eyeboll/archives/640xTravel/2012/IMG_2284.jpg
The point I want to make, is that I own a 40D for a number of years now. I've always avoided using Manual due to my lack of knowledge of the "triangle" (ISO, Aperture, Speed). Therefore I was thinking it would be nice if there is a way I can preview my shot before pressing down the shutter button. I would guess that the only way I can preview a shot is by using the histogram.
Anyways I thought I could really get into using Manual mode on my DSLR if I'm able to preview beforehand.
Before someone says it. I'll say it myself. Yeah I should really learn the exposure fundamentals.:o But as my sig says, I'm just a snap shooter.
Jun.Roberto.Dizon.Greg​orio
My Photographic Gears.
I Like Shooting Animals Than People.
SOK
Sep 20, 2012 00:20 |  #2
You should really learn the exposure fundamentals. :P
Seriously though, you will enjoy it so much more if can make the camera behave the way you want it to. Spend some time reading and practising...it really doesn't take long to pick up.
And while your 40D doesn't have LiveView to preview, it's got a perfectly good 'afterview' feature....namely the LCD where you can review an shot immediately after you take it!!!
Steve
SOK Images - Wedding and Event Photography Gold Coast (external link)
Tiberius
Sep 20, 2012 00:27 |  #3
Canajun wrote in post #15017456 (external link)
Check the link in my signature. It's got a tutorial on how to use all the different modes on your camera, including manual mode.
And the 40D does have a live view function.
My photography website!PHOCAL PHOTOGRAPHY (external link)
Canajun
Sep 20, 2012 00:32 |  #4
SOK wrote in post #15017513 (external link)
I know, that's what I am finding. I've been hiding behind the Av mode for too long. It's time to suck it up and learn how to use my gear properly.
What's so disheartening using Av is that. After a great day of being outdoor shooting. In my mind I had lots great shots. Only to find that the keepers are not as many as I have pictured in my mind :(
thanks for you comments.
Canajun
Sep 20, 2012 00:33 |  #5
Tiberius47 wrote in post #15017527 (external link)
will do , thanks
onona
Joined Aug 2012
Sep 20, 2012 05:13 |  #6
If you shoot with Live View on your 40D, your camera will simulate the result on the screen, much like your compact does.
Shooting in manual is really just a matter of confidence, once you understand the exposure fundamentals, that is. I shoot almost everything in manual as I like to be able to control everything as much as possible. Because ultimately that's what manual is about - control. Since you're obviously used to Av mode, perhaps it would be worth spending a little time in Tv mode to get used to shutter speeds, before diving head first into manual.
Leigh
I shoot concerts and stuff. (external link)
Seapup
Joined Aug 2012
Sep 20, 2012 06:04 |  #7
The other day. I tried shooting a sunset with my SX40HS......
A big factor in obtaining the color you were seeking in the 2nd shot was switching from Auto White Balance to Manual WB.
Canon 5D2 | 60D | A620 | SD850 IS | SD4000 IS
Canon 10-22 f/3.5-4.5 | 17-55 f/2.8 IS | 50 f/1.4 | 100 f/2.8L Macro IS | 70-200 f/2.8L IS II | 100-400 f/4.5-5.6L IS
Canajun
Sep 20, 2012 07:48 |  #8
onona wrote in post #15018013 (external link)
Confidence = Bingo!! I think it's the numbers that intimidates me. But finding out simple rules like sunny 16 etc. makes it easier for me to dive into it. Btw I read I've read Bryan Petersons exposure book but it really did not sink in.:oops:
As pointed by Steve. It's more like Afterview. It's after the fact. I was thinking the compact is more real time. I can see how it's affecting my shot even before I shoot. In my brain I can relate to these changes. Just like my example, I know I wanted to have small aperture to capture the details. But the camera was giving me completely different results than what I had in mind. Therefore when I change the speed. I can see I was getting closer to what I was trying to achieve. In this particular case I did not even realize that the ISO was set at 100.
I guess I made this thread to illustrate that using a compact cameras can be a useful learning tool.
Seapup wrote in post #15018072 (external link)
I've always viewed WB as a secondary after exposure. I mean once you have the correct exposure, but you are not happy with the tones/colours. Then you adjust the WB. Then again this is just my perceptions.
alpinevisions
Joined Nov 2005
Sep 20, 2012 07:59 |  #9
I'm not the only one! This is exactly how I learned about f stop and exposure on my S2IS. Basically what you see on the screen of the cam is what the pic is and any changes you make appear almost instantly. I don't want to tell you how many images on my T2i I've screwed up because what appears in the view finder isn't what is captured! My time spent with my first camera was invaluable for me as a photographer.
T2I 18-55mm Kit lens, Canon EF-S 17-55mm f/2.8
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Sep 20, 2012 08:47 |  #10
Canajun wrote in post #15018284 (external link)
Live view might be better for sunsets, but this is what I usually use: Need an exposure crutch?
Why?: Post #47
Sorarse
Sep 21, 2012 07:32 |  #11
I usually find with sunsets, assuming you can't be bothered messing about trying to get the right manual setting, is to exclude the foreground and just meter the sky. Recompose as necessary and take the shot.
At the beginning of time there was absolutely nothing. And then it exploded! Terry Pratchett
http://www.scarecrowim​ages.com (external link)
Canon PowerShot G2
Canajun
Sep 21, 2012 07:53 |  #12
Sorarse wrote in post #15022842 (external link)
Metering is another subject that I haven't explored much :o
That's why I love this hobby. Now that I had fun shooting semi-auto. It's time to really get down and dirty:D
2,631 views & 0 likes for this thread, 8 members have posted to it.
1586 guests, 137 members online
