Thread started 20 Sep 2012 (Thursday) 06:25
Why don't cameras micro adjust themselves?
TweakMDS
Sep 20, 2012 06:25 |  #1
So, I was just thinking. Since the newer generations of DSLRs all have live view with contrast detect AF as well as phase detect, it would be relatively easy to implement the following:
  • User places the camera on a tripod and points it at a certain distance where the focus is most critical (let's say at 4m for something like a 85mm prime - wouldn't matter much, but the misalignment might not be linear so multiple distance measurements could be done.).
  • User places a stationary high contrast object in front of the camera.
  • User selects the "Auto Calibrate AF" function.
  • Camera uses phase detect AF to focus on the object
  • Once focus is achieved, the camera switches to live view and checks the set focus. The camera then uses contrast detect to set the focus.
  • If contrast detect focus is not equal to phase detect focus, it puts an entry for that amount of micro adjust for that lens.
I believe this would work because the contrast detect AF is the "real world focus", through the lens and onto the sensor, thus is always the same to the end result, whereas the phase detect occasionally needs to be corrected.
Some of my lenses focus beyond infinity...!
~Michael
Gear | Flickr (external link)
"My featured shots" (external link)
boerewors
Joined Sep 2009
Sep 20, 2012 06:59 |  #2
Sounds logical and can be implimented by a mere firmware update, but look at canon... They dont seem to be listening to us. We should somehow ask the magic lantern guys to help us out. My 60D sadly misses any form of AF correction.
The most important piece of gear you own, resides in your head and its called your brain.
TweakMDS
Sep 20, 2012 07:00 |  #3
boerewors wrote in post #15018163 (external link)
All my cameras do as well, but yeah, magic lantarn could possibly use this as a feature.
~Michael
LowriderS10
Sep 20, 2012 08:46 |  #4
Easy answer: Canon already knows how to do this...they're rolling it out slowly, to be able to keep adding "new features" to future bodies...
-=Facebook=- (external link)
-=Flickr=- (external link)
-=Gear=-
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Sep 20, 2012 09:59 |  #5
Previous discussions over the past few years to help address this question, or related to it. Short answer, there is no reason why not, other than it would be Canon's decision. ;)
https://photography-on-the.net …php?p=8833318#p​ost8833318
https://photography-on-the.net …ight=auto+micro​adjustment
https://photography-on-the.net …?t=1225334&high​light=step
TweakMDS
Sep 20, 2012 11:22 |  #6
TeamSpeed wrote in post #15018736 (external link)
Ah, and here I though I was on to something new :o Thanks for the links :)
~Michael
sapearl
Gallery: 243 photos
Sep 20, 2012 11:26 |  #7
LowriderS10 wrote in post #15018481 (external link)
Makes perfect "marketting" sense if that's the case. Pay extra for the new optional feature which then becomes standard equipment on the next version; sort of like self-adjusting brakes ;).
MY WEBSITE (external link)- MY GALLERIES (external link)- MY BLOG (external link)
Artists Archives of the Western Reserve (external link) - Board
Bill ­ Boehme
Enjoy being spanked
Gallery: 39 photos
Sep 20, 2012 11:45 as a reply to  @ TeamSpeed's post |  #8
Sounds to me like this proposed solution is at least, if not more, work on the user's part than doing it manually. Besides that, let's not lose sight of the primary reason for having focus bias adjustments -- fabrication tolerances that results in different path lengths to the AF sensor and the image sensor. The real solution is to improve the high precision fabrication tolerances to do away with the need for having focus bias adjustments in the first place. If anything, I suspect that is Canon's approach.
Atmospheric haze in images? Click for Tutorial to Reduce Atmospheric Haze with Photoshop.
Gear List .... Gallery: Woodturner Bill (external link)
Donate to Support POTN Operating Costs
drive_75
Sep 20, 2012 11:48 |  #9
Canon already performed micro-adjustment. It's call "Calibration". You really want it to be done manually. This will take the AF issue or any other issue out of the equation and that include software. They perform calibration and set it in the center. Now every lens is going to have a small variation. It's not that big deal to do micro-adj.
Some of you want auto-micro adjustment. Some want Wifi, gps, 10fps, 41Mpixels, huge DR, 80 AF points, etc.... then to throw in what I want...I want a 1% spot metering that is tie to the AF point and not just the center. I'm sure Canon can build this camera for us but are we all willing to pay the price? I'm sure I will hear people complaining about value and that they don't need bunch feature just the one they want and want to pay $1700 for it and not $12K. You can't make everyone happy.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Sep 20, 2012 12:03 |  #10
drive_75 wrote in post #15019152 (external link)
Considering that Canon already listened to the complaints about a single MFA value and how it really doesn't help zoom lenses, they made a change that allows 2 MFA values per lens provided it is not a prime. Give it enough time, and Canon will continue to tweak already existing functions into better functions, like auto-ISO, auto-calibration, etc.
Can this function exist? Absolutely yes. Will Canon add it? Who's to say, time will only tell.
drive_75
Sep 20, 2012 12:13 |  #11
TeamSpeed wrote in post #15019215 (external link)
Yeah I suppose you are correct. Maybe I need to be more vocal about the fact that I like to have a spot metering that is tie to the AF point on the next 5D model:D
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Sep 20, 2012 12:29 |  #12
drive_75 wrote in post #15019241 (external link)
That is reserved for the 1D series. ;)
drive_75
Sep 20, 2012 13:20 |  #13
TeamSpeed wrote in post #15019305 (external link)
Yeah but if complain enough and post enough on the forum complaining then it might just happen right?;)
Preeb
Gallery: 150 photos
Joined Sep 2011
Sep 22, 2012 08:58 |  #14
drive_75 wrote in post #15019496 (external link)
I get the tongue in cheek smilie, but your request is right in line with those who seem to think that the 6d should have everything the 5dIII has but for $1000 less. The trouble is, those guys seem to be serious about it, and they are incensed that Canon has so blatantly ignored the outcry.
It's like buying a car - if you don't like the option package available for the Toyota Corolla, you either move up to a Camry or you learn to do without - or maybe buy a Honda (of course, changing automobile brands is easier than changing a body from Canon to Nikon).
Rick
6D Mark II - EF 17-40 f4 L -- EF 100mm f2.8 L IS Macro -- EF 70-200 f4 L IS w/1.4 II TC
pulsar123
Gallery: 82 photos
Sep 22, 2012 09:14 |  #15
I've been using Magic Lantern on my 50D for a while, with a recent stable release it became much more useful (e.g. it can take a shot when the image comes into focus - works even with chipped MF lenses, and lenses with extension tubes - macro shots with hand-held nifty-fifty + 62mm tubes are as sharp as you can do that manually with a tripod!). But last time I heard about tweaking/improving/ena​bling focus MA, the developers mentioned that it's at the edge of the realm of possible.
6D (normal), 6D (full spectrum), Tamron 24-70 f2.8 VC, 135L, 70-200 f4L, 50mm f1.8 STM, Samyang 8mm fisheye, home studio, Fast Stacker
2,899 views & 0 likes for this thread, 11 members have posted to it.
1482 guests, 186 members online
