Thread started 20 Sep 2012 (Thursday) 12:52
Canon 9500 II vs Epson R280
SteveHS
Sep 20, 2012 12:52 |  #1
I bought a Canon 9500 mk II a couple of years ago to make larger and better prints than the Epson R280 that was bundled with my iMac. Printing from Aperture, I find that the 9500 prints are not as vivid as the R280 prints, and often seem washed out in comparison. I use high quality photo papers from the respective companies on each and select these papers when printing. Any thoughts on why this is happening and how I can improve the Canon output?
Thanks.
Steve
Gear: 7D w 24-70, 70-200 f/2.8 IS and 100-400; Fujifilm X20
tkbslc
Sep 20, 2012 12:59 |  #2
My guess would be color management and or printer profiles. I don't know Aperture enough to help you with specifics, though.
Taylor
EOS Rp | iPhone 11 Pro Max
Virto
Joined Nov 2010
Sep 20, 2012 13:14 |  #3
I'd assume the same. Make sure the program is handling the color output and use the correct ICC profiles for your papers. Red River and others offer custom ICC profiles for their papers and the 9500.
Kelly - EOS 5D - EOS 40D - Rebel XS - EOS 10D - EOS 1D - SX230 - AE-1 - OM-1n - Minolta Himatic7 - EOS-1N
ABR800 - Several flashes, remote triggers, stands, too many and yet not enough lenses
ejenner
Gallery: 98 photos
Joined Nov 2011
Sep 20, 2012 20:00 as a reply to  @ Virto's post |  #4
I would definitely check all the advanced settings in the printer menu. There are ones for making adjustments on top of the printer profile.
You also have to make sure that either the printer or Aperture is controlling the profile (although I haven't used aperture). It's not too hard in generall to apply two profiles on top of each other.
Personally I export to an adobeRGB tiff/jpeg and then use DPP to print (for Canon consistency) - even then you can quite easily apply a profile on top of another - but I find I often have to reduce saturation becasue the 9500II makes blues and greens too vivid. I've had that will all the papers and profiles I've used so far.
Edward Jenner
5DIV, M6, GX1 II, Sig15mm FE, 16-35 F4,TS-E 17, TS-E 24, 35 f2 IS, M11-22, M18-150 ,24-105, T45 1.8VC, 70-200 f4 IS, 70-200 2.8 vII, Sig 85 1.4, 100L, 135L, 400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
853 views & 0 likes for this thread, 4 members have posted to it.
1242 guests, 151 members online
