Thread started 20 Sep 2012 (Thursday) 13:59
My Av/Tv mode broken on Canon 30D?
atl5
Joined Jun 2010
Sep 20, 2012 13:59 |  #1
Hi guys, recently got a second hand Canon 30D. When it arrive, I tried it out and set it to Av mode, f/2.8 on my Tamron lense and the shutter would snap and hold for 8-10 seconds, overexposing my shot. I then tried the same thing in Tv mode and again the shutter would seem to be stuck and hold for 8-10 seconds. On auto mode, the flash would pop up all the time even if I was outdoor and it was bright. Anyone had this issue before? When I'm on manual mode and set my Aperture, Shutter and ISO, everything is fine, but I want to use Av mode when I'm outdoor.
Body: 5D mkII | 40D
Prime: 28mm f/1.8 | Sigma 50mm f/1.4 | 85mm f/1.8
Zoom: 17-40mm f/4L | Tamron 28-75mm f/2.8 | 80-200mm f/2.8L
Irfan
Sep 20, 2012 14:03 |  #2
you didnt have the lens cap on during the Av test did you?
ksbal
Gallery: 374 photos
Best ofs: 9
Sep 20, 2012 14:03 |  #3
I'd try a different lens on the camera first.
Second I'd swap out the date battery.. there is the battery you charge and change all the time, and another smaller one, probably like a small watch battery that I'd change as well.
Got to eliminate easy battery problems first, on the quest to figure out what is going on.
Godox/Flashpoint r2 system, plus some canon stuff.
tkbslc
Sep 20, 2012 14:06 |  #4
Did you do a factory reset of all the settings?
Taylor
EOS Rp | iPhone 11 Pro Max
atl5
Joined Jun 2010
Sep 20, 2012 14:06 |  #5
Irfan wrote in post #15019651 (external link)
Yes, I have remove the lens cap and was starting to shoot. I also have reset the camera and remove all custom settings. The time seems to be correct on the camera, so I have not change the date battery. Was thinking maybe just reflashing the firmware next.
Body: 5D mkII | 40D
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Sep 20, 2012 14:08 |  #6
What kind of light and what apertures were you testing this at?
atl5
Joined Jun 2010
Sep 20, 2012 14:14 |  #7
gonzogolf wrote in post #15019674 (external link)
Indoor, I set the aperture at 2.8 in my living room. Last Sunday I was out on a bright day and try from 2.8-8 aperture and every attempt, the shutter would open for 8-10 seconds.
Body: 5D mkII | 40D
ksbal
Gallery: 374 photos
Best ofs: 9
Sep 20, 2012 14:31 |  #8
Does it have this problem with the 50mm?
atl5
Joined Jun 2010
Sep 20, 2012 14:35 |  #9
Have not gotten it yet. Picking it up after work, but added it to my sig at work. Will test it out with the 50mm first and then reflash the firmware to see if that helps. I guess none of you has had something similar happen then.
Body: 5D mkII | 40D
Irfan
Sep 20, 2012 15:11 as a reply to  @ atl5's post |  #10
when you are in Av mode, does the back dial change the exposure compensation like it should?
atl5
Joined Jun 2010
Sep 20, 2012 17:54 |  #11
Got home and have tried all the following:
1) remove and re-insert date/time battery
2) Change to Canon 50mm lens from Tamron
3) reflash the firmware
None of it worked, looks like it is definitely the camera. When I change it to Tv mode, no matter what I set the shutter, camera always pick f\1.4. Called a camera repair shop and even they said they have not seen this issue before. Weird!
Body: 5D mkII | 40D
tkbslc
Sep 20, 2012 18:02 |  #12
If you shoot manual does it work right? Does the meter in manual seem to be indicating proper exposure? It sounds like maybe the meter is toast
Taylor
atl5
Joined Jun 2010
Sep 20, 2012 18:17 |  #13
tkbslc wrote in post #15020534 (external link)
I'm still new to this, so don't know how to read the meter in manual mode. But I did say I think there is something wrong with the sensor/meter. How much would it cost do you think to replace the meter on one of these?
Body: 5D mkII | 40D
atl5
Joined Jun 2010
Sep 20, 2012 18:22 |  #14
The meter is it on the lcd, with a value from 2 to -2? If so, my meter is flashing at -2 no matter what the lighting is.
Body: 5D mkII | 40D
Irfan
Sep 20, 2012 20:36 |  #15
and the scroll wheel in AV or TV mode does or does not move the exposure setting?
3,662 views & 0 likes for this thread, 5 members have posted to it.
1175 guests, 175 members online
