Thread started 21 Sep 2012 (Friday) 20:43
CS4- Ugly patch Tool Artifacts: Adobe Sabotage?
S-Man
Sep 21, 2012 20:43 |  #1
Well I used to use the patch tool on my CS4 all day every day for touchups and it worked seamlessly and beautifully. However a couple of versions came and went (CS5/6) and I haven't updated.
I don't remember when I started to notice the patch tool not working as effectively as it used to. It now has some ugly artifacts and jaggys all around the patched section. Even in small patches.
I started to think that it was my computer, but a fellow photog friend of mine said she was experiencing the same thing- her patch tool used to work great but now it's too ugly to use.
Anyone know what's going on? Did Adobe sabotage older versions of PS so that you'll "Need" to upgrade to CS6?
Call me a conspiracy theorist, but they could totally have an Adobe "update" that you install which would break certain features.
Look at this janky image of what should be a simple patch job. This is after the patch has been made:
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2012/09/3/LQ_615978.jpg
Image hosted by forum (615978) © S-Man [SHARE LINK]
tonylong
...winded
Gallery: 60 photos
Sep 24, 2012 00:18 |  #2
Show us the Before???
Tony
rrblint
Gallery: 84 photos
Joined May 2012
Sep 24, 2012 00:22 as a reply to  @ tonylong's post |  #3
This is interesting...Subscrib​ed.
Mark
René ­ Damkot
Sep 24, 2012 03:45 |  #4
Nothing new: PSCS4 has done this in some cases for years.
Patch again, but use a smaller patch.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Hopelessdfilms
Sep 24, 2012 11:49 |  #5
This is not a phenomenon in just cs4. This is a outcome of using patch tool on certain surfaces, such as the one you have posted.
In cases where the surface you are using as your source, is very detailed, this will likely occur... everytime. This is a case where using the clone stamp could give better results. It is tricky to find source areas that match in the same quality in terms of its exposure, color, etc, but the surface should blend much nicer. Use some quick adjustments on the new adjustment layer that you have sampled to make it blend and voila.
just my .02c
S-Man
Sep 25, 2012 16:34 |  #6
Interesting. I have noticed the patch tool works better on smaller corrections. This was not a HUGE selection, but somewhat large. It was a red plaster wall and the texture along with the noise made it very detailed, as you guys mentioned. I'm wondering if the newer Content Aware Fill would correct this?
I could have sworn the patch tool worked better in the past though. I wonder if I do a fresh install from the disc and try it without updating would it answer my question/suspicion.
I was trying to clone out a larger section of a door on a wall.
Thanks for the replies.
tonylong
...winded
Gallery: 60 photos
Sep 25, 2012 16:42 |  #7
Maybe post a Before shot, you'd get more "informed" help?
Tony
doidinho
Sep 25, 2012 17:28 |  #8
Is there a hardness parameter w/ the patch tool? I don't recall from memory. If so, check and make sure it's set to 100%.
Robert McCadden
My Flickr (external link)
MM (external link)
5DMKII, Rebel xti, 24-105 f/4L, Canon 70-200 f/4L, Canon 17-40.
ssim
Joined Apr 2003
Sep 25, 2012 23:44 as a reply to  @ doidinho's post |  #9
Adobe secretly sending patches that breaks anything but the last couple of releases:confused:. Wow, the conspiracy theorists are alive and well.
René ­ Damkot
Sep 26, 2012 07:20 |  #10
S-Man wrote in post #15041916 (external link)
Nope. Always has and always will do this on some backgrounds.
boerewors
Joined Sep 2009
Sep 26, 2012 09:14 |  #11
I have no issues in CS5. Try fading the patch or use content aware fill, its probably more suited to what you need to achieve.
The most important piece of gear you own, resides in your head and its called your brain.
3,337 views & 0 likes for this thread, 8 members have posted to it.
1067 guests, 101 members online
