Thread started 22 Sep 2012 (Saturday) 01:30
Two 5dmkii and different iso quality
rapurimanka
Gallery: 6 photos
Joined Apr 2012
Sep 22, 2012 01:30 |  #1
I've got two different 5d mark ii cameras, on both i took picture with closed lens on the same setting on hi iso. And mine is more noisy then my partners :(
Take a look:
me
https://dl.dropbox.com​/u/5020311/Compare/640​0.JPG (external link)
friends
https://dl.dropbox.com …mpare/6400%28vi​ach%29.JPG (external link)
raw
https://dl.dropbox.com​/u/5020311/Compare/640​0.zip (external link)
What is it? (((
I really need these iso's
Can anyone with latest firmware preset same photo with closed lens and viewfinder. On iso 3200-6400-12800. Raw files
6D | Canon 85 1.8 | Canon 24-105 4 | Lightroom 4
https://www.flickr.com​/photos/27393138@N08/ (external link)
-dave-m-
Gallery: 6 photos
Joined Sep 2011
Sep 22, 2012 01:45 |  #2
If you are going to compare bodies you should at least make sure all the settings are the same. One body has long exposure noise reduction set to auto and high iso noise reduction on, the other body has both disabled.
5D MkII Gripped | 7D MkII Gripped | 200 f/2.8L | 17-40 f/4L | Σ 24-105 OS f/4 Art | Σ 50 f/1.4 Art | Σ 150-600 OS f/5-6.3 C | 430EX II
rapurimanka
Gallery: 6 photos
Joined Apr 2012
Sep 22, 2012 01:48 |  #3
I converted files from raw where i disabled these things. This settings affect only camera jpg, not raw files.
I was converting via dpp
evilr00t
Sep 22, 2012 04:55 as a reply to  @ rapurimanka's post |  #4
Long exposure noise reduction affects the raw file. Disable it on both and try again.
FWIW noise should increase if you use LENR because you're doubling read noise -> banding noise. You do get one thing: removal of hot pixels, but you can do this in software post-capture. Whether it's worth the extra noise is up to you (or the convenience of not having to do dark frame subtraction).
EDIT: Checked pictures. Yep, the one with LENR enabled is noisier. SCIENCE
XTi, 1D3, 2x SB-28, 580EX, 550EX, Tamron 28-75, 50/1.8, "EF" 18-55 II, "EF" 18-55 IS, 85/1.8, 75-300 III USM, 70-200/4L
hbomb69
Sep 22, 2012 06:07 as a reply to  @ evilr00t's post |  #5
No, I agree...the In camera NR does Not affect the Raw Files...
CANON 5D MKIII x 2 / CANON 50D / CANON 550D
http://www.michaelhard​castle.co.uk (external link)
Facebook.com/michaelha​rdcastlephotography
John ­ Sheehy
Sep 22, 2012 06:25 |  #6
hbomb69 wrote in post #15027212 (external link)
LENR and high-ISO NR are two completely different things. LENR affects the RAW, because it is actually 2 RAWs, one subtracted from the other, the second with the shutter closed. This increases random noise by 41.4%, but kills the effect of thermal noise that is the same in every frame.
TSchrief
Joined Aug 2012
Sep 22, 2012 06:31 |  #7
Both of these cameras are complete junk. Send them to me immediately.
rapurimanka
Gallery: 6 photos
Joined Apr 2012
Sep 22, 2012 09:51 |  #8
Tried with LENR set to off, same picture.
babel_fish
Sep 22, 2012 12:46 |  #9
Reload firmware on both and reset all custom and user settings and try again.
"The time you enjoy wasting is not wasted time." -Bertrand Russell
"dude, are you even paying attention!,
Mike
Todd ­ Lambert
I don't like titles
Sep 22, 2012 12:56 |  #10
I think the noise pattern is the same on both, it's just that yours has a magenta cast while your friends is more purple. The purple isn't as visible as the magenta, and so it appears noisier. This could be from difference in White Balance, too.
I think your camera is fine, but that you may need to adjust your PP to account for this magenta cast.
TSchrief
Joined Aug 2012
Sep 22, 2012 14:51 |  #11
Todd Lambert wrote in post #15028316 (external link)
I'm pretty sure WB settings do not affect the .cr2 file.
John ­ Sheehy
Sep 22, 2012 14:55 |  #12
TSchrief wrote in post #15028636 (external link)
It doesn't affect the RAW image, just the metadata; however, the OP has never seen the RAW files. The OP has seen conversions, which may be affected differently by different metadata.
JohnB57
Sep 22, 2012 15:11 |  #13
John Sheehy wrote in post #15028653 (external link)
You can't see raw files - they have to be converted to view them. That doesn't mean your point about camera settings is incorrect, but it could be worth using another program such as PS to convert the raw files for comparison.
Pekka
El General Moderator
Gallery: 35 photos
Best ofs: 7
Joined Mar 2001
Sep 22, 2012 15:12 |  #14
If you try it again, make sure both cameras are let to cool and are put on at the same moment before comparison shoot. The difference could simply be motherboard heat level.
The Forum Boss, El General Moderator
AMASS 2.1 Changelog (installed here now)
TSchrief
Joined Aug 2012
Sep 22, 2012 15:54 |  #15
Yes. Of course. I did not think of that aspect.
3,048 views & 0 likes for this thread
Latest registered member is masoudyas
925 guests, 329 members online
