Thread started 24 Sep 2012 (Monday) 14:46
Smaller HSS capable flashes
John_N
Joined Sep 2009
Sep 24, 2012 14:46 |  #1
Hi,
Despite having a Nissin Di866 II I don't find I use it all that much and I'm thinking it may be down to the physical size.
When I'm out that I often use the 70-200 2.8 but for whatever reason seem to end up doing a lot of post production work to light the face, to me the obvious choice here is to use flash fill, especially as my kids move about ALOT!! That would be the reason for wanting HSS too.
Sadly a simple reflector is out of the question unless someone can figure out a way to tether it to the kids and keep it out of shot while they rush about like nutters :D
Can you suggestion a good flash for this and also with the studio setup as a slave (to be mounted on YN 622C's)
Thanks.
flickr (external link) (magsnorton)
: Google+ (external link) : My Site (external link) : 5oopx (external link)
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Sep 24, 2012 14:51 |  #2
You lose so much power using HSS that its almost impractical on a full sized full power flash, using a smaller less powerful flash in HSS mode would be nearly useless. You must have some amazingly fast kids that 1/200 sync speed plus flash duration wont stop.
John_N
Joined Sep 2009
Sep 24, 2012 14:59 |  #3
lol, you'd be amazed... or more likely I don't know how to use my flash properly ;)
I've heard it said that flash will freeze action, but under non-flash circumstances 200 and below will result in unwanted blur.
John_N
Joined Sep 2009
Sep 24, 2012 15:09 |  #4
Heres an example of the sort of thing I would want to do:
IMAGE: http://farm9.staticflickr.com/8177/7996508076_c68bc4ed9c_b.jpg
IMAGE LINK: http://www.flickr.com/​photos/magsnorton/7996​508076/  (external link)
120915_2145 (external link) by magsnorton (external link), on Flickr
gonzogolf
Gallery: 561 photos
Sep 24, 2012 15:19 |  #5
With no exif its difficult to say. That shot might be a candidate for HSS flash, but it would require a full sized full power one to do the trick. HSS costs you at least a stop of power, and then more so as shutter speed goes up. You have to be close and you need all the power you can get. Time to man up and use your larger flash.
btmlinedan
Sep 24, 2012 15:23 |  #6
id say... 580ex, 580exII, 430ex, 430exII, YN568ex
*dan l *Flickr (external link) l *cars: dkfx Photography (external link) l weddings: Blue Martini Photography (external link) l YN622C tranceiver review (external link)
John_N
Joined Sep 2009
Sep 24, 2012 15:41 |  #7
Sorry, I only recently disabled the exif having added the bit at the bottom of the image.
Maybe you;re right - time to man up, but its still a pain to log about.
dmward
Gallery: 29 photos
Sep 24, 2012 16:18 |  #8
I was shooting a wedding outside Saturday.
600EX-RT in HSS was showing a usable range out to about 40ft at ISO 100, Av F5.6 and the shutter speed was floating around 1/320. I was using 24-105 and 700-200.
580EXII should accomplish the same thing.
ksbal
Gallery: 374 photos
Best ofs: 9
Sep 24, 2012 17:19 |  #9
HSS is one idea, another idea is to turn the kids into a white walled/ceiling room and use the bounce of the flash - it does make for some great light, and you don't have to tether the kids or anything else down.. just lock the door. :) If you can find a nice light wall next to a play area in the shade, this also may work, with some trial and error (and a white balance setting)
Godox/Flashpoint r2 system, plus some canon stuff.
John_N
Joined Sep 2009
Sep 25, 2012 03:03 |  #10
Just to clarify for al the people PMing me - yes the above image is mine.
John_N
Joined Sep 2009
Sep 28, 2012 09:43 |  #11
gonzogolf wrote in post #15036565 (external link)
Well I tried using flash at a slower speed to freeze the action and this was the result :(
IMAGE: http://www.talkphotography.co.uk/gallery/data/500/120928_3061.jpg
The settings were:
Focal length: 165.0mm
Exposure time: 0.0080 s (1/125)
Aperture: f/8.0
ISO equiv.: 100
Flash used: Yes (manual)
Whitebalance: Auto
Metering Mode: pattern
Exposure: Manual
Exposure Mode: Manual
gonzogolf
Gallery: 561 photos
Sep 28, 2012 09:50 |  #12
John_N wrote in post #15053713 (external link)
The settings were:
Aperture: f/8.0
ISO equiv.: 100
Whitebalance: Auto
Exposure: Manual
Yes, when I said that I was assuming flash as the primary light. Flash duration only helps when its about 2 stops brighter than the ambient. For fill it doesnt work.
John_N
Joined Sep 2009
Sep 28, 2012 10:24 |  #13
I think I'm beginning to see why there are so few good pictures of kids running!
1,972 views & 0 likes for this thread, 5 members have posted to it.
1460 guests, 129 members online
