Curtis N wrote in post #15053815
You're kidding, right?
Two strobes will consume twice as much power as one. Theoretically, the battery will only last half as long.
I suspect it is you that is kidding...
time-wise, yes, the battery will need to be charged sooner, but it will still give you the same amount of work
maybe if I explain... say the battery gives 1 strobe the ability to pop 500 times... adding a 2nd stobe will divide those 500 pops, still giving you 500 pops... but now instead of having 500 pops spread out over 500 shots, those 500 pops are spread out over 250 shots...
the # of strobes will still give you the same # of pops, this is assuming no misfires...
running off a battery pack, 2 strobes cannot use more power than one.... whether you drain the battery with 1 or 2 strobes, you've used the exact same amount of power (i.e. limited by the battery pack) and generated just as much light as you would with 1 strobe... the only different is the amount of light (or power used) by frames captured
